Multi-Protokoll-Messenger: Miranda NG 0.96.5 bringt eine Fülle an Verbesserungen
Frank Meyer
19 Kommentare
Bild: Hersteller
Der Multi-Protokoll-Messenger Miranda NG ist für Windows in Version 0.96.5 mit etlichen Verbesserungen, Optimierungen und Fehlerkorrekturen erschienen. An vorderster Front haben die Entwickler in der aktuellen Ausgabe Fehler an unterschiedlichen Stellen behoben. Aber auch kleine Aktualisierungen bei Paketen sind enthalten.
Großes Update-Paket mit wenigen Neuerungen
Die größten Änderungen an Miranda NG 0.96.5 umfassen Updates von „libtox library“, „SQLite library auf 3.45.2“, „libcurl library auf 8.7.1“ und „OpenSSL auf 3.3.0“.
Core and libraries
  • added "Remove cached files when an event is deleted" option to file transfer settings.
  • updated libtox library.
  • updated SQLite library to 3.45.2.
  • updated libcurl library to 8.7.1.
  • update OpenSSL to 3.3.0.
  • Issue #4197 moved icons and sounds options to Options → Customize.
  • Issue #4198 expanded options' tree width and option's window width.
  • Issue #4188 fixed a bug due to which contact was placed in the wrong group.
  • Issue #4189 fixed a bug that prevented deleting an empty group.
  • Issue #4190 fixed the work of the "New subgroup" menu item.
  • Issue #4203 erasing groups.json no longer causes groups to disappear.
  • Issue #4210 from now on it is forbidden to create accounts with the same names.
  • Issue #4209 fixed crash.
  • Issue #4217 the options tree no longer steals focus when switching between tabs.
  • Issue #4271 clearing contact history now removes the "you have unread message" icon from the contact list.
  • Issue #4275 a message is no longer marked as read if it arrives in an inactive tab.
  • Issue #4291 fixed a bug where the names of custom menu items were not saved.
  • Issue #4292 moving a submenu in the menu editor no longer causes submenu items to be disabled.
  • Issue #4353 fixed "All networks" search.
Miranda NG 0.96.5 – Release Notes
Eine genaue Auflistung aller Optimierungen sowie der umfangreichen Fehlerkorrekturen wie beispielsweise bei den Protokollen und Plugins ist in den offiziellen Release Notes hinterlegt.
Multi-Protokoll-Messenger für diverse soziale Netzwerke
Miranda NG ist ein Multi-Protokoll-Messenger für Windows, der etliche Protokolle, wie Facebook, Twitter, Steam, Gadu-Gadu, ICQ, IRC, Jabber und viele weitere unterstützt. Als Abspaltung des inzwischen eingestellten Miranda IM ermöglicht Miranda NG einen Umzug des alten Miranda-IM-Profils. Auf der Miranda NG-Website findet sich eine detaillierte Liste mit allen Features.
Download auf ComputerBase
Miranda NG kann in der aktualisierten Fassung 0.96.5 wie gewohnt direkt unterhalb dieser Meldung aus dem Download-Bereich von ComputerBase heruntergeladen werden.
Downloads
  • Miranda NG Download
    4,5 Sterne
    Miranda NG ist ein Multi-Protokoll-Messenger für Windows, der eine Vielzahl von Protokollen unterstützt.
    • Version 0.96.6 Deutsch
Nicht verpassen: Unser Festtagsprogramm 2025/2026 blickt hinter die Kulissen und lädt noch immer zum Mitmachen ein!
