accessibility.typeaheadfind.flashBar 0
browser.cache.disk.capacity 358400
browser.cache.disk.enable false
browser.cache.disk.filesystem_reported 1
browser.cache.disk.smart_size.first_run false
browser.cache.frecency_experiment 4
browser.cache.memory.enable false
browser.download.importedFromSqlite true
browser.places.smartBookmarksVersion 7
browser.privatebrowsing.autostart true
browser.sessionstore.upgradeBackup.latestBuildID 20160905130425
browser.startup.homepage
http://www.google.de/
browser.startup.homepage_override.buildID 20160905130425
browser.startup.homepage_override.mstone 45.4.0
browser.urlbar.autocomplete.enabled false
browser.urlbar.suggest.bookmark false
browser.urlbar.suggest.history false
browser.urlbar.suggest.openpage false
dom.apps.reset-permissions true
dom.enable_performance false
dom.enable_resource_timing false
dom.enable_user_timing false
dom.event.clipboardevents.enabled false
dom.event.contextmenu.enabled false
dom.mozApps.used true
dom.server-events.enabled false
extensions.lastAppVersion 45.4.0
gfx.crash-guard.d3d11layers.appVersion 45.4.0
gfx.crash-guard.d3d11layers.deviceID 0x1616
gfx.crash-guard.d3d11layers.driverVersion 10.18.15.4268
gfx.crash-guard.d3d11layers.feature-d2d true
gfx.crash-guard.d3d11layers.feature-d3d11 true
gfx.crash-guard.status.d3d11layers 2
gfx.crash-guard.status.d3d9video 2
gfx.direct3d.last_used_feature_level_idx 0
media.getusermedia.browser.enabled false
media.getusermedia.screensharing.enabled false
media.gmp-eme-adobe.abi x86_64-msvc-x64
media.gmp-eme-adobe.lastUpdate 1482501116
media.gmp-eme-adobe.version 16
media.gmp-gmpopenh264.abi x86_64-msvc-x64
media.gmp-gmpopenh264.lastUpdate 1482501118
media.gmp-gmpopenh264.version 1.6
media.gmp-manager.buildID 20160905130425
media.gmp-manager.lastCheck 1484334353
media.hardware-video-decoding.failed false
media.navigator.enabled false
media.peerconnection.default_iceservers
media.peerconnection.enabled false
media.peerconnection.turn.disable true
media.peerconnection.use_document_iceservers false
media.peerconnection.video.enabled false
media.video_stats.enabled false
network.allow-experiments false
network.cookie.cookieBehavior 2
network.cookie.lifetime.days 3
network.cookie.lifetimePolicy 2
network.cookie.prefsMigrated true
network.dns.disablePrefetch true
network.dnsCacheEntries 0
network.http.keep-alive false
network.http.max-connections 32
network.http.max-persistent-connections-per-proxy 16
network.http.proxy.keep-alive false
network.http.speculative-parallel-limit 0
network.predictor.cleaned-up true
network.predictor.max-resources-per-entry 0
network.predictor.max-uri-length 0
network.predictor.preconnect-min-confidence 0
network.predictor.preresolve-min-confidence 0
network.prefetch-next false
network.tcp.keepalive.enabled false
places.database.lastMaintenance 1483994110
places.history.expiration.transient_current_max_pages 104858
plugin.disable_full_page_plugin_for_types application/pdf
privacy.donottrackheader.enabled true
privacy.donottrackheader.value 1
privacy.sanitize.migrateFx3Prefs true
security.csp.experimentalEnabled true
storage.vacuum.last.index 1
storage.vacuum.last.places.sqlite 1482509718
ui.osk.debug.keyboardDisplayReason IKPOS: Touch screen not found.
webgl.min_capability_mode true
