Kunststoffhans
- Mai 2017
mehrfache Versuche den Fehler zu lösen und auch den Rechner neu aufzusetzen schlugen fehl.
Trotz nutzen der Suchfunktion konnte ich den Fehler so nicht lösen. Beim Ausführen von
Sysprep entsteht unten stehende Fehlermeldung im Setupact.log.
Danke für die Hilfe.
Gruß Hans
2017-05-26 13:59:31, Info SYSPRP ========================================================
2017-05-26 13:59:31, Info SYSPRP === Beginning of a new sysprep run ===
2017-05-26 13:59:31, Info [0x0f004d] SYSPRP The time is now 2017-05-26 13:59:31
2017-05-26 13:59:31, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\system32\sysprep\Panther
2017-05-26 13:59:31, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
2017-05-26 13:59:31, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\system32\sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything
2017-05-26 13:59:31, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE'
2017-05-26 13:59:31, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'SHUTDOWN'
2017-05-26 13:59:31, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE'
2017-05-26 13:59:31, Info [0x0f00d7] SYSPRP WinMainre-validing 'cleanup' internal providers.
2017-05-26 13:59:31, Info SYSPRP RunExternalDlls:Running platform actions specified in action file for phase 3
2017-05-26 13:59:31, Info [0x0f00ba] SYSPRP SysprepSession::CreateSession: Successfully created instance with mount path C:, action file C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml, and mode <null>
2017-05-26 13:59:31, Info SYSPRP SysprepSession::Validate: Beginning action execution from C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml
2017-05-26 13:59:31, Info SYSPRP ActionPlatform::GetStringValue: Getting REG_SZ value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep
2017-05-26 13:59:31, Info SYSPRP ActionPlatform::GetValue: Getting value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep
2017-05-26 13:59:31, Warning SYSPRP ActionPlatform::GetValue: Error from RegQueryValueEx on value SysprepMode under key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Sysprep; dwRet = 0x2
2017-05-26 13:59:31, Info SYSPRP SysprepSession::CreateXPathForSelection: Sysprep mode in registry is <null>
2017-05-26 13:59:31, Info SYSPRP ActionPlatform::GetStringValue: Getting REG_SZ value PROCESSOR_ARCHITECTURE under key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
2017-05-26 13:59:31, Info SYSPRP ActionPlatform::GetValue: Getting value PROCESSOR_ARCHITECTURE under key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
2017-05-26 13:59:31, Info SYSPRP SysprepSession::CreateXPathForSelection: Processor architecture in registry is AMD64
2017-05-26 13:59:31, Info [0x0f0080] SYSPRP ActionPlatform::LaunchModule: Found 'Sysprep_Clean_Validate_Opk' in C:\Windows\System32\spopk.dll; executing it
2017-05-26 13:59:31, Info [0x0f0081] SYSPRP ActionPlatform::LaunchModule: Successfully executed 'Sysprep_Clean_Validate_Opk' from C:\Windows\System32\spopk.dll without error
2017-05-26 13:59:31, Info [0x0f00d7] SYSPRP WinMainre-validing 'generalize' internal providers.
2017-05-26 13:59:31, Info SYSPRP RunExternalDlls:Running platform actions specified in action file for phase 1
2017-05-26 13:59:31, Info [0x0f00ba] SYSPRP SysprepSession::CreateSession: Successfully created instance with mount path C:, action file C:\Windows\System32\Sysprep\ActionFiles\Generalize.xml, and mode <null>
2017-05-26 13:59:31, Info SYSPRP SysprepSession::Validate: Beginning action execution from C:\Windows\System32\Sysprep\ActionFiles\Generalize.xml
2017-05-26 13:59:31, Info [0x0f0080] SYSPRP ActionPlatform::LaunchModule: Found 'SysprepGeneralizeValidate' in C:\Windows\System32\AppxSysprep.dll; executing it
2017-05-26 13:59:31, Info SYSPRP Entering SysprepGeneralizeValidate (Appx) - validating whether all apps are also provisioned.
2017-05-26 13:59:31, Error SYSPRP Failed to remove apps for the current user: 0x80070003.
2017-05-26 13:59:31, Error SYSPRP Exit code of RemoveAllApps thread was 0x3.
2017-05-26 13:59:31, Error [0x0f0082] SYSPRP ActionPlatform::LaunchModule: Failure occurred while executing 'SysprepGeneralizeValidate' from C:\Windows\System32\AppxSysprep.dll; dwRet = 0x3
2017-05-26 13:59:31, Error SYSPRP SysprepSession::Validate: Error in validating actions from C:\Windows\System32\Sysprep\ActionFiles\Generalize.xml; dwRet = 0x3
2017-05-26 13:59:31, Error SYSPRP RunPlatformActions:Failed while validating SysprepSession actions; dwRet = 0x3
2017-05-26 13:59:31, Error [0x0f0070] SYSPRP RunExternalDlls:An error occurred while running registry sysprep DLLs, halting sysprep execution. dwRet = 0x3
2017-05-26 13:59:31, Error [0x0f00d8] SYSPRP WinMain:Hit failure while pre-validate sysprep generalize internal providers; hr = 0x80070003
2017-05-26 13:59:33, Info [0x0f0052] SYSPRP Shutting down SysPrep log
2017-05-26 13:59:33, Info [0x0f004d] SYSPRP The time is now 2017-05-26 13:59:33
Gruß Hans
