Windows 10 Tweaks blokiern RDP nur welche?
ICHBINDA
Nov. 2007
HI
Welche der folgenden Tweaks Blokiert die RDP verbindung ?
Code:
REM ======================= Registry tweaks =======================
ECHO.
:regstart
set /p registry="Apply Registry tweaks? y/n: "
if '%registry%' == 'n' goto servstart
if /i "%registry%" neq "y" goto regstart
:reg0start
set /p reg0="Replace Magnify with CMD? y/n: "
if '%reg0%' == 'n' goto reg1start
if /i "%reg0%" neq "y" goto reg0start
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Magnify.exe" /v "Debugger" /t REG_SZ /d "cmd.exe" /f > NUL 2>&1
:reg1start
set /p reg1="Disable Quick Access as default view in Explorer? y/n: "
if '%reg1%' == 'n' goto reg2start
if /i "%reg1%" neq "y" goto reg1start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /f /v "LaunchTo" /t REG_DWORD /d 0 > NUL 2>&1
:reg2start
set /p reg2="Show computer shortcut on desktop? y/n: "
if '%reg2%' == 'n' goto reg3start
if /i "%reg2%" neq "y" goto reg2start
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" /v "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg3start
set /p reg3="Show file extensions? y/n: "
if '%reg3%' == 'n' goto reg4start
if /i "%reg3%" neq "y" goto reg3start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "HideFileExt" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg4start
set /p reg4="Disable lockscreen? y/n: "
if '%reg4%' == 'n' goto reg5start
if /i "%reg4%" neq "y" goto reg4start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Personalization" /v "NoLockScreen" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg5start
set /p reg5="Enable classic control panel view? y/n: "
if '%reg5%' == 'n' goto reg6start
if /i "%reg5%" neq "y" goto reg5start
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" /v "ForceClassicControlPanel" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg6start
set /p reg6="Hide indication for compressed NTFS files? y/n: "
if '%reg6%' == 'n' goto reg7start
if /i "%reg6%" neq "y" goto reg6start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "ShowCompColor" /t RED_DWORD /d 0 /f > NUL 2>&1
:reg7start
set /p reg7="Disable Windows Update sharing? y/n: "
if '%reg7%' == 'n' goto reg8start
if /i "%reg7%" neq "y" goto reg7start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DODownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg8start
set /p reg8="Remove Pin to start? y/n: "
if '%reg8%' == 'n' goto reg9start
if /i "%reg8%" neq "y" goto reg8start
reg delete "HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
reg delete "HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
reg delete "HKEY_CLASSES_ROOT\mscfile\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
:reg9start
set /p reg9="Classic vertical icon spacing? y/n: "
if '%reg9%' == 'n' goto reg10start
if /i "%reg9%" neq "y" goto reg9start
reg add "HKCU\Control Panel\Desktop\WindowMetrics" /v "IconVerticalSpacing" /t REG_SZ /d "-1150" /f > NUL 2>&1
:reg10start
set /p reg10="Remove versioning tab from properties? y/n: "
if '%reg10%' == 'n' goto reg11start
if /i "%reg10%" neq "y" goto reg10start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer" /v NoPreviousVersionsPage /t REG_DWORD /d 1 /f > NUL 2>&1
:reg11start
set /p reg11="Disable jump lists? y/n: "
if '%reg11%' == 'n' goto reg12start
if /i "%reg11%" neq "y" goto reg11start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "Start_TrackDocs" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg12start
set /p reg12="Remove telemetry and data collection? y/n: "
if '%reg12%' == 'n' goto reg13start
if /i "%reg12%" neq "y" goto reg12start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Device Metadata" /v PreventDeviceMetadataFromNetwork /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\MRT" /v DontOfferThroughWUAU /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\SQMClient\Windows" /v "CEIPEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "AITEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "DisableUAR" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!dss-winrt-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-event_8ac43a41e5030538" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-inter_58073761d33f144b" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg13start
set /p reg13="Apply Internet Explorer 11 tweaks? y/n: "
if '%reg13%' == 'n' goto reg14start
if /i "%reg13%" neq "y" goto reg13start
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DoNotTrack" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Search Page" /t REG_SZ /d "http://www.google.es" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Start Page Redirect Cache" /t REG_SZ /d "http://www.google.es" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg14start
set /p reg14="Disable Cortana, Bing Search and Searchbar? y/n: "
if '%reg14%' == 'n' goto reg15start
if /i "%reg14%" neq "y" goto reg14start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Search" /v "AllowCortana" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "CortanaEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "SearchboxTaskbarMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "BingSearchEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg15start
set /p reg15="Change Logon screen background with accent color? y/n: "
if '%reg15%' == 'n' goto reg16start
if /i "%reg15%" neq "y" goto reg15start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\System" /v "DisableLogonBackgroundImage" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg16start
set /p reg16="Disable Windows Error Reporting? y/n: "
if '%reg16%' == 'n' goto reg17start
if /i "%reg16%" neq "y" goto reg16start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Error Reporting" /v "Disabled" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg17start
set /p reg17="Disable automatic Windows Updates? y/n: "
if '%reg17%' == 'n' goto reg18start
if /i "%reg17%" neq "y" goto reg17start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update" /v "AUOptions" /t REG_DWORD /d 2 /f > NUL 2>&1
:reg18start
set /p reg18="Disable Hibernation? y/n: "
if '%reg18%' == 'n' goto servstart
if /i "%reg18%" neq "y" goto reg18start
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Power" /v "HiberbootEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
ECHO Done...
REM ======================= Removing services =======================
ECHO.
:servstart
set /p services="Apply Registry tweaks? y/n: "
if '%services%' == 'n' goto schedstart
if /i "%services%" neq "n" if /i "%services%" neq "y" goto servstart
:serv0start
set /p serv0="Disable tracking services? y/n: "
if '%serv0%' == 'n' goto serv1start
if /i "%serv0%" neq "y" goto serv0start
sc config DiagTrack start= disabled > NUL 2>&1
sc config diagnosticshub.standardcollector.service start= disabled > NUL 2>&1
sc config TrkWks start= disabled > NUL 2>&1
sc config WMPNetworkSvc start= disabled > NUL 2>&1
:serv1start
set /p serv1="Disable WAP Push Message Routing Service? y/n: "
if '%serv1%' == 'n' goto serv2start
if /i "%serv1%" neq "y" goto serv1start
sc config dmwappushservice start= disabled > NUL 2>&1
:serv2start
set /p serv2="Disable Windows Search? y/n: "
if '%serv2%' == 'n' goto serv3start
if /i "%serv2%" neq "y" goto serv2start
sc config WSearch start= disabled > NUL 2>&1
del "C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Windows.edb" /s > NUL 2>&1
:serv3start
set /p serv3="Disable Superfetch? y/n: "
if '%serv3%' == 'n' goto serv4start
if /i "%serv3%" neq "y" goto serv3start
sc config SysMain start= disabled > NUL 2>&1
:serv4start
set /p serv4="Disable Windows Defender? y/n: "
if '%serv4%' == 'n' goto schedstart
if /i "%serv4%" neq "y" goto serv4start
sc config WinDefend start= disabled > NUL 2>&1
sc config WdNisSvc start= disabled > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows Defender" /v "DisableAntiSpyware" /t REG_DWORD /d 1 /f > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cleanup" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Verification" /Disable > NUL 2>&1
del "C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache*" /s > NUL 2>&1
ECHO Done...
REM ======================= Removing scheduled tasks =======================
ECHO.
:schedstart
set /p schedules="Removing scheduled tasks? y/n: "
if '%schedules%' == 'n' goto winappstart
if /i "%schedules%" neq "n" if /i "%schedules%" neq "y" goto schedstart
schtasks /Change /TN "Microsoft\Windows\AppID\SmartScreenSpecific" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\Consolidator" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\UsbCeip" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\NetTrace\GatherNetworkInfo" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Error Reporting\QueueReporting" /Disable > NUL 2>&1
ECHO Done...
REM ======================= Removing Windows default apps =======================
ECHO.
:winappstart
set /p winapps="Removing Windows default apps? y/n: "
if '%winapps%' == 'n' goto odrivestart
if /i "%winapps%" neq "n" if /i "%winapps%" neq "y" goto winappstart
powershell "Get-AppxPackage *3d* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *bing* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *zune* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *photo* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *communi* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *solit* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *phone* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *soundrec* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *camera* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *people* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *office* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *xbox* | Remove-AppxPackage" > NUL 2>&1
ECHO Done...
REM ======================= Disable / Remove OneDrive =======================
ECHO.
:odrivestart
set /p onedrive="Disable OneDrive? y/n: "
if '%onedrive%' == 'n' goto hoststart
if /i "%onedrive%" neq "y" goto odrivestart
reg add "HKLM\Software\Policies\Microsoft\Windows\OneDrive" /v DisableFileSyncNGSC /t REG_DWORD /d 1 /f > NUL 2>&1
ECHO Done...
REM ======================= Blocking Telemetry Servers =======================
ECHO.
:hoststart
set /p hostsblock="Blocking Telemetry Servers? y/n: "
if '%hostsblock%' == 'n' goto finish
if /i "%hostsblock%" neq "n" if /i "%hostsblock%" neq "y" goto hoststart
copy "%WINDIR%\system32\drivers\etc\hosts" "%WINDIR%\system32\drivers\etc\hosts.bak" > NUL 2>&1
attrib -r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
FIND /C /I "vortex.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-win.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-win.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "redir.metaservices.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 redir.metaservices.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "reports.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 reports.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "services.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 services.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.ppe.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.ppe.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.urs.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.urs.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net:443" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net:443>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "settings-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 settings-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
attrib +r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
Danke für die hilfe
ich verzweifel nämlich gerade
Auf den ersten Blick keiner.
Von wo nach wo möchtest du denn rdp machen und was passiert dann?
Dazu hätte ich ein paar klitzekleine Fragen:
1. Warum verwendest du "Tweaks" ohne zu wissen, was diese zur Folge haben? (Okay, Antwort kann ich mir denken... $Person oder $Software sagt, die seien super)
2. Was sagen $Person oder $Software-Anbieter zu dem Problem? Sind immerhin die Verursacher?
3. Funktionierte RDP vor den "Tweaks" sauber?
4. Verwendest du diese Änderungen auf dem RDP-Client oder RDP-Server oder beiden? Falls Client: RDP funktioniert also von anderem identischen Client ohne Tweaks?
Ich würde dies wie folgt (automatisiert) testen:
Alle "Tweaks" auskommentieren und ein frisches System nehmen an dem nix "optimiert" wurde.
for i liste-der-tweaks
> check rdp connection (tcp connect auf ziel:3389)
> if successful remove # at beginning of line i
> if not successful -> quit
> i++
Die zuletzt aktivierte Einstellung blockiert dementsprechend RDP.
@fatal_error @d2boxSteve
Vor den Tweaks ging die RDP einwandfrei.
Ich bin über VPN mit daheim verbunden. und dan RDP auf die IP adresse. es kommt das fenster (kein anmeldebildschirm) wie immer zur Benutzer und PW eingabe aber danach pasiert nix keine fehlermeldung kein Fenster.
Darum kann es nur an den Tweaks liegen.
jetzt komm ich nicht mehr drauf bin noch in der arbeit da ich daheim nicht dazu komme.
es ist keine Firewall auf dem rechner aktiv.
@snaxilian
Ich habe die bat datei geprüft und nix entdecken können was mich stören würde:freak::evillol: kenn mich ja selber aus was des so macht:D. nur RDP bin ich leihe was des so braucht:king:!
viel leicht weis es doch jemand welcher scheiß eintrag es ist.
MFG
Hört sich für mich an als würde lokal etwas das RDP-Protokoll, oder Dienst, ausbremsen.
Verwechsle bitte nicht Einträge wie wie ein Verkehrsschild wirken - man kann dran vorbeikommen und es wirkt wenn es da ist (bzw. nicht) - mit Schaltern die 1x ungelegt bzw. in eine Stellung gebracht werden und bei denen es nutzlos ist ob ich Schaltbefehl erneut gebe oder jeweils weglasse da das den Zustand nicht ändert.
Nimm einen Wiederherstellungspunkt von wo dem Unfall und dann lass diesen Tweak-Quatsch auf immer und ewig weg.
CN8
