ich habe ein B150I Pro Gaming Mainboard von Asus mit Windows 10. Neuste Bios Version.
Trotzdem zeigt mir CPU -Z diesen Wert aus dem Bild an.
Desweiteren hier alle Daten:
Wie kann ich das fixen, dass die auf 2400mhz laufen?
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name Intel Core i7 6700K
Codename Skylake
Specification Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Package (platform ID) Socket 1151 LGA (0x1)
CPUID 6.E.3
Extended CPUID 6.5E
Core Stepping R0
Technology 14 nm
TDP Limit 95.0 Watts
Tjmax 100.0 °C
Core Speed 797.8 MHz
Multiplier x Bus Speed 8.0 x 99.7 MHz
Stock frequency 4000 MHz
Max frequency 4200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 4-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000016h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 40x
Max turbo ratio 42x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 42x
Ratio 2 cores 40x
Ratio 3 cores 40x
Ratio 4 cores 40x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 95.0 W @ 40x
Temperature 0 37 degC (98 degF) (Package)
Temperature 1 33 degC (91 degF) (Core #0)
Temperature 2 33 degC (91 degF) (Core #1)
Temperature 3 30 degC (86 degF) (Core #2)
Temperature 4 32 degC (89 degF) (Core #3)
Voltage 0 0.79 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 00 5.21 W (Package)
Power 01 1.73 W (IA Cores)
Power 02 n.a. (GT)
Power 03 3.48 W (Uncore)
Power 04 0.98 W (DRAM)
Clock Speed 0 797.85 MHz (Core #0)
Clock Speed 1 797.85 MHz (Core #1)
Clock Speed 2 797.85 MHz (Core #2)
Clock Speed 3 1396.23 MHz (Core #3)
Core 0 max ratio 42.0 (effective 42.0)
Core 1 max ratio 42.0 (effective 42.0)
Core 2 max ratio 42.0 (effective 42.0)
Core 3 max ratio 42.0 (effective 42.0)
Chipset
Northbridge Intel Skylake rev. 07
Southbridge Intel B150 rev. 31
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR4
Memory Size 16 GBytes
Channels Dual
Memory Frequency 1063.9 MHz (1:16)
CAS# latency (CL) 16.0
RAS# to CAS# delay (tRCD) 16
RAS# Precharge (tRP) 16
Cycle Time (tRAS) 39
Row Refresh Cycle Time (tRFC) 278
Command Rate (CR) 2T
Uncore Frequency 1396.2 MHz
Host Bridge 0x191F
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format UDIMM
Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000000000)
Size 8192 MBytes
Max bandwidth DDR4-2400 (1200 MHz)
Part number BLS8G4D240FSC.16FB
Serial number A11C82EA
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 9.0-9-9-22-31 @ 675 MHz
JEDEC #2 10.0-10-10-25-35 @ 750 MHz
JEDEC #3 11.0-11-11-27-38 @ 825 MHz
JEDEC #4 12.0-12-12-29-41 @ 900 MHz
JEDEC #5 13.0-13-13-32-45 @ 975 MHz
JEDEC #6 14.0-14-14-34-48 @ 1050 MHz
JEDEC #7 15.0-16-16-37-52 @ 1126 MHz
JEDEC #8 16.0-16-16-39-55 @ 1200 MHz
JEDEC #9 18.0-16-16-39-55 @ 1200 MHz
JEDEC #10 20.0-16-16-39-55 @ 1200 MHz
XMP profile XMP-2400
Specification DDR4-2400
Voltage level 1.200 Volts
Min Cycle time 0.833 ns (1200 MHz)
Max CL 16.0
Min tRP 13.20 ns
Min tRCD 13.20 ns
Min tRAS 31.95 ns
Min tRC 45.32 ns
Min tRRD 3.30 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 7.0-7-7-17-25-n.a @ 530 MHz (1.200 Volts)
XMP #2 8.0-8-8-20-28-n.a @ 606 MHz (1.200 Volts)
XMP #3 9.0-9-9-22-31-n.a @ 682 MHz (1.200 Volts)
XMP #4 10.0-10-10-25-35-n.a @ 757 MHz (1.200 Volts)
XMP #5 11.0-11-11-27-38-n.a @ 833 MHz (1.200 Volts)
XMP #6 12.0-12-12-30-42-n.a @ 909 MHz (1.200 Volts)
XMP #7 13.0-13-13-32-45-n.a @ 985 MHz (1.200 Volts)
XMP #8 14.0-14-14-34-49-n.a @ 1060 MHz (1.200 Volts)
XMP #9 15.0-16-16-37-52-n.a @ 1136 MHz (1.200 Volts)
XMP #10 16.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
XMP #11 17.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
XMP #12 18.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
XMP #13 19.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
XMP #14 20.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Size 8192 MBytes
Serial number A62242A4
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 13.20 ns
Min tRCD 13.20 ns
Min tRAS 31.95 ns
Min tRC 45.32 ns
Min tRRD 3.30 ns
Monitoring
Mainboard Model B150I PRO GAMING/WIFI/AURA (0x000006BB - 0x599A7A66)
