Acer Aspire5 - WLAN-Probleme
ManBla
Mai 2016
meine neues Notebook - hier Grundinformationen:
Code:
System:    Host: localhost.localdomain Kernel: 5.1.5-300.fc30.x86_64 x86_64 bits: 64 Desktop: KDE Plasma 5.15.5
           Distro: Fedora release 30 (Thirty)
Machine:   Type: Laptop System: Acer product: Aspire A517-51 v: V1.22 serial: NXGSUEG00784901CBA3400
           Mobo: KBL model: Dragonite_KL v: V1.22 serial: NBGSU1100384977DE03400 UEFI: Insyde v: 1.22 date: 10/09/2018
Battery:   ID-1: BAT1 charge: 30.5 Wh condition: 49.7/48.9 Wh (101%)
CPU:       Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP L2 cache: 3072 KiB
           Speed: 800 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 620 driver: i915 v: kernel
           Display: x11 server: Fedora Project X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa resolution: 1600x900~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 19.0.5
Audio:     Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.1.5-300.fc30.x86_64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp1s0f1 state: up speed: 1000 Mbps duplex: full mac: 98:28:a6:31:54:e7
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter driver: ath10k_pci
           IF: wlp2s0 state: up mac: 00:f4:8d:9a:69:7f
           Device-3: Realtek 802.11ac WLAN Adapter type: USB driver: usb-network
Drives:    Local Storage: total: 931.51 GiB used: 14.15 GiB (1.5%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB
Partition: ID-1: / size: 19.56 GiB used: 6.69 GiB (34.2%) fs: ext4 dev: /dev/sda12
           ID-2: swap-1 size: 4.02 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 204 Uptime: 8m Memory: 7.67 GiB used: 1.13 GiB (14.8%) Shell: bash inxi: 3.0.34
Auf diesem Notebook sind einige Linux-Distributionen installiert, u.a.
ArchLinux, Sabayon, Gentoo, Mageia7, PCLinuxOS, Fedora30.
WLAN funtkioniert bei ArchLinux, Sabayon, Fedora30.
Deshalb schreibe ich das hier unter Fedora30.
Alle anderen Distributionen bekommen kein WLAN, nicht einmal, wenn ich ein Kabel anschließe,
das an der ConnectBox von Unitymedia hängt.
Dabei ist mir ein Hinweis aufgefallen bei Mageia7, wenn ich dort WLAN anklicke:
ath10k_pci fehlt. Daher kein Zugriff auf WLAN.
Was kann ich da tun? Ich habe den Eindruck, daß WLAN bei diesem Acer-Notebook etwas komplizierter ist
als bei meinem vorherigen Lenovo-Notebook.
Vielleicht hat hier jemand Erfahrung mit Acer und kann mir auf die Sprünge helfen.
Danke jedenfalls schon einmal im voraus.
Manfred
Ergänzung:
Ich habe eben unter Fedora30 einmal auf Konsole folgendes eingegeben:
dnf search qualcomm
Ergebnis:
Code:
gobi_loader.x86_64 : Firmware loader for Qualcomm Gobi WWAN devices
libqmi.x86_64 : Support library to use the Qualcomm MSM Interface (QMI) protocol
libqmi.i686 : Support library to use the Qualcomm MSM Interface (QMI) protocol
Kann das ein erster Hinweis sein auf das Problem?
gobi_loader scheint das Programm zu sein, mit dem Fedora WLAN bekommt.
Aber das ist nur eine Vermutung, kein Wissen ;:-)
Manfred
Unter z. B. Debian ist der Treiber im Atheros-Firmwarepaket enthalten.
Ist die notwendige Firmware bei dir installiert?
Das muß/werde ich überprüfen.
Danke erst einmal für diesen Tipp.
Manfred
Nun kann ich doch für Mageia7 Erfolg melden.
Das modul für WLAN ath10k_pci ist nämlich dort vorhanden,
es hat nur der kernel-firmware-nonfree gefehlt.
Nachdem ich den installiert hatte, war das Problem gelöst.
Danke für die Hilfe und die Hinweise.
Nun kann ich bei den anderen Distributionen schauen, was fehlt.
Manfred
Will ja keinen Shitstorm lostreten von wg. Windows vs. Linux -der Eingangspost vom TE inhaltlich echt super -würde mir derartige Details bei so manchem Windows Post wünschen :daumen:
IT_Nerd
