Alsa sound problem
ganjamike
Nov. 2005
hallo zusammen,
ich habe die seperaten alsa-driver emerged und dann alsaconf laufen lassen. alsaconf gibt zwar zum schluss die meldung es würde alles passen .. allerdings kommt vorher diese meldung:
Code:
Running modules-update...
 * Please run 'update-modules' from now on; 'modules-update' is going away
Loading driver...
 * Loading ALSA modules ...
 *   Loading: snd-card-0 ...
WARNING: Error inserting snd (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/snd.ko): Unknown symbol in module, or unknown parameter (see dmesg)
WARNING: Error inserting snd_hwdep (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/snd-hwdep.ko): Unknown symbol in module, or unknown parameter (see dmesg)
WARNING: Error inserting snd_timer (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/snd-timer.ko): Unknown symbol in module, or unknown parameter (see dmesg)
WARNING: Error inserting snd_pcm (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/snd-pcm.ko): Unknown symbol in module, or unknown parameter (see dmesg)
FATAL: Error inserting snd_hda_intel (/lib/modules/2.6.23-gentoo-r6/alsa-driver/pci/hda/snd-hda-intel.ko): Unknown symbol in module, or unknown parameter (see dmesg)        [ !! ]
 *   Loading: snd-seq-oss ...
WARNING: Error inserting snd_seq_device (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/seq/snd-seq-device.ko): Unknown symbol in module, or unknown parameter (see dmesg)
WARNING: Error inserting snd_seq (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/seq/snd-seq.ko): Unknown symbol in module, or unknown parameter (see dmesg)
WARNING: Error inserting snd_seq_midi_event (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/seq/snd-seq-midi-event.ko): Unknown symbol in module, or unknown parameter (see dmesg)
FATAL: Error inserting snd_seq_oss (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/seq/oss/snd-seq-oss.ko): Unknown symbol in module, or unknown parameter (see dmesg)        [ !! ]
 *   Loading: snd-pcm-oss ...
WARNING: Error inserting snd_mixer_oss (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/oss/snd-mixer-oss.ko): Unknown symbol in module, or unknown parameter (see dmesg)
FATAL: Error inserting snd_pcm_oss (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/oss/snd-pcm-oss.ko): Unknown symbol in module, or unknown parameter (see dmesg)        [ !! ]
 *   Loading: snd-mixer-oss ...
FATAL: Error inserting snd_mixer_oss (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/oss/snd-mixer-oss.ko): Unknown symbol in module, or unknown parameter (see dmesg)        [ !! ]
 *   Loading: snd-seq ...
FATAL: Error inserting snd_seq (/lib/modules/2.6.23-gentoo-r6/alsa-driver/acore/seq/snd-seq.ko): Unknown symbol in module, or unknown parameter (see dme  [ !! ]
 *   ERROR: Failed to load necessary drivers                              [ ok ]
 * ALSA failed to load.                                                   [ !! ]
Setting default volumes...
amixer: Mixer attach default error: No such device
 Now ALSA is ready to use.
 For adjustment of volumes, use your favorite mixer.
 Have a lot of fun!
also meine frage was muss ich machen um das zu beheben?
soundcard ist:
Code:
 Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
dist: gentoo
(wär von den zeichen her zu lang daher noch ein Post)
dmseg output:
davor kommt auch noch was .. allerdings wär der post sonst zu lang ...
Code:
snd_seq: Unknown symbol snd_timer_open
snd_seq: Unknown symbol snd_timer_start
snd_seq: Unknown symbol snd_iprintf
snd_seq: Unknown symbol snd_timer_resolution
snd_seq: Unknown symbol snd_timer_pause
snd_seq: Unknown symbol snd_ecards_limit
snd_seq: Unknown symbol snd_unregister_device
snd_seq: Unknown symbol snd_seq_device_load_drivers
snd_seq: Unknown symbol snd_register_device_for_dev
snd_seq_midi_event: Unknown symbol snd_seq_expand_var_event
snd_seq_oss: Unknown symbol snd_seq_kernel_client_enqueue
snd_seq_oss: Unknown symbol snd_info_register
snd_seq_oss: Unknown symbol snd_seq_set_queue_tempo
snd_seq_oss: Unknown symbol snd_info_create_module_entry
snd_seq_oss: Unknown symbol snd_seq_delete_kernel_client
snd_seq_oss: Unknown symbol snd_seq_autoload_lock
snd_seq_oss: Unknown symbol snd_seq_kernel_client_dispatch
snd_seq_oss: Unknown symbol snd_info_free_entry
snd_seq_oss: Unknown symbol snd_seq_root
snd_seq_oss: Unknown symbol snd_seq_kernel_client_enqueue_blocking
snd_seq_oss: Unknown symbol snd_unregister_oss_device
snd_seq_oss: Unknown symbol snd_seq_autoload_unlock
snd_seq_oss: Unknown symbol snd_verbose_printk
snd_seq_oss: Unknown symbol snd_register_oss_device
snd_seq_oss: Unknown symbol snd_seq_device_register_driver
snd_seq_oss: Unknown symbol snd_midi_event_free
snd_seq_oss: Unknown symbol snd_iprintf
snd_seq_oss: Unknown symbol snd_midi_event_no_status
snd_seq_oss: Unknown symbol snd_oss_info_register
snd_seq_oss: Unknown symbol snd_use_lock_sync_helper
snd_seq_oss: Unknown symbol snd_seq_device_unregister_driver
snd_seq_oss: Unknown symbol snd_seq_event_port_detach
snd_seq_oss: Unknown symbol snd_midi_event_new
snd_seq_oss: Unknown symbol snd_midi_event_decode
snd_seq_oss: Unknown symbol snd_seq_create_kernel_client
snd_seq_oss: Unknown symbol snd_seq_kernel_client_write_poll
snd_seq_oss: Unknown symbol snd_midi_event_encode_byte
snd_seq_oss: Unknown symbol snd_seq_kernel_client_ctl
snd: Unknown symbol unregister_sound_special
snd: Unknown symbol register_sound_special_device
snd: Unknown symbol sound_class
snd_mixer_oss: Unknown symbol snd_info_register
snd_mixer_oss: Unknown symbol snd_info_free_entry
snd_mixer_oss: Unknown symbol snd_info_get_str
snd_mixer_oss: Unknown symbol snd_unregister_oss_device
snd_mixer_oss: Unknown symbol snd_ctl_find_id
snd_mixer_oss: Unknown symbol snd_verbose_printk
snd_mixer_oss: Unknown symbol snd_register_oss_device
snd_mixer_oss: Unknown symbol snd_card_file_add
snd_mixer_oss: Unknown symbol snd_mixer_oss_notify_callback
snd_mixer_oss: Unknown symbol snd_iprintf
snd_mixer_oss: Unknown symbol snd_cards
snd_mixer_oss: Unknown symbol snd_ctl_notify
snd_mixer_oss: Unknown symbol snd_oss_info_register
snd_mixer_oss: Unknown symbol snd_lookup_oss_minor_data
snd_mixer_oss: Unknown symbol snd_info_create_card_entry
snd_mixer_oss: Unknown symbol snd_card_file_remove
snd_mixer_oss: Unknown symbol snd_ctl_find_numid
snd_mixer_oss: Unknown symbol snd_info_get_line
snd_timer: Unknown symbol snd_info_register
snd_timer: Unknown symbol snd_info_create_module_entry
snd_timer: Unknown symbol snd_info_free_entry
snd_timer: Unknown symbol snd_verbose_printk
snd_timer: Unknown symbol snd_iprintf
snd_timer: Unknown symbol snd_ecards_limit
snd_timer: Unknown symbol snd_oss_info_register
snd_timer: Unknown symbol snd_unregister_device
snd_timer: Unknown symbol snd_device_new
snd_timer: Unknown symbol snd_register_device_for_dev
snd_pcm: Unknown symbol snd_info_register
snd_pcm: Unknown symbol snd_info_create_module_entry
snd_pcm: Unknown symbol snd_timer_notify
snd_pcm: Unknown symbol snd_timer_interrupt
snd_pcm: Unknown symbol snd_info_free_entry
snd_pcm: Unknown symbol snd_add_device_sysfs_file
snd_pcm: Unknown symbol snd_info_get_str
snd_pcm: Unknown symbol snd_verbose_printk
snd_pcm: Unknown symbol snd_ctl_register_ioctl
snd_pcm: Unknown symbol snd_card_file_add
snd_pcm: Unknown symbol snd_iprintf
snd_pcm: Unknown symbol snd_major
snd_pcm: Unknown symbol snd_unregister_device
snd_pcm: Unknown symbol snd_timer_new
snd_pcm: Unknown symbol snd_device_new
snd_pcm: Unknown symbol snd_ctl_unregister_ioctl
snd_pcm: Unknown symbol snd_lookup_minor_data
snd_pcm: Unknown symbol snd_info_create_card_entry
snd_pcm: Unknown symbol snd_power_wait
snd_pcm: Unknown symbol snd_device_free
snd_pcm: Unknown symbol snd_card_file_remove
snd_pcm: Unknown symbol snd_register_device_for_dev
snd_pcm: Unknown symbol snd_device_register
snd_pcm: Unknown symbol snd_info_get_line
snd_pcm_oss: Unknown symbol snd_pcm_lib_read
snd_pcm_oss: Unknown symbol snd_pcm_hw_param_first
snd_pcm_oss: Unknown symbol snd_info_register
snd_pcm_oss: Unknown symbol snd_pcm_kernel_ioctl
snd_pcm_oss: Unknown symbol snd_info_free_entry
snd_pcm_oss: Unknown symbol snd_pcm_format_unsigned
snd_pcm_oss: Unknown symbol _snd_pcm_hw_params_any
snd_pcm_oss: Unknown symbol snd_info_get_str
snd_pcm_oss: Unknown symbol snd_interval_refine
snd_pcm_oss: Unknown symbol snd_pcm_format_physical_width
snd_pcm_oss: Unknown symbol snd_pcm_format_little_endian
snd_pcm_oss: Unknown symbol snd_unregister_oss_device
snd_pcm_oss: Unknown symbol snd_pcm_format_silence_64
snd_pcm_oss: Unknown symbol snd_verbose_printk
snd_pcm_oss: Unknown symbol snd_pcm_open_substream
snd_pcm_oss: Unknown symbol snd_register_oss_device
snd_pcm_oss: Unknown symbol snd_pcm_lib_readv
snd_pcm_oss: Unknown symbol snd_card_file_add
snd_pcm_oss: Unknown symbol snd_pcm_lib_writev
snd_pcm_oss: Unknown symbol snd_mixer_oss_ioctl_card
snd_pcm_oss: Unknown symbol snd_iprintf
snd_pcm_oss: Unknown symbol snd_pcm_format_linear
snd_pcm_oss: Unknown symbol snd_pcm_mmap_data
snd_pcm_oss: Unknown symbol snd_oss_info_register
snd_pcm_oss: Unknown symbol snd_pcm_hw_param_last
snd_pcm_oss: Unknown symbol snd_pcm_hw_param_value
snd_pcm_oss: Unknown symbol snd_pcm_format_signed
snd_pcm_oss: Unknown symbol snd_pcm_link_rwlock
snd_pcm_oss: Unknown symbol snd_lookup_oss_minor_data
snd_pcm_oss: Unknown symbol snd_pcm_hw_refine
snd_pcm_oss: Unknown symbol snd_info_create_card_entry
snd_pcm_oss: Unknown symbol snd_pcm_format_big_endian
snd_pcm_oss: Unknown symbol snd_pcm_notify
snd_pcm_oss: Unknown symbol snd_pcm_release_substream
snd_pcm_oss: Unknown symbol snd_card_file_remove
snd_pcm_oss: Unknown symbol snd_pcm_format_set_silence
snd_pcm_oss: Unknown symbol snd_info_get_line
snd_pcm_oss: Unknown symbol snd_pcm_format_width
snd_seq_device: Unknown symbol snd_info_register
snd_seq_device: Unknown symbol snd_info_create_module_entry
snd_seq_device: Unknown symbol snd_info_free_entry
snd_seq_device: Unknown symbol snd_seq_root
snd_seq_device: Unknown symbol snd_verbose_printk
snd_seq_device: Unknown symbol snd_iprintf
snd_seq_device: Unknown symbol snd_device_new
snd_seq: Unknown symbol snd_timer_stop
snd_seq: Unknown symbol snd_info_register
snd_seq: Unknown symbol snd_info_create_module_entry
snd_seq: Unknown symbol snd_request_card
snd_seq: Unknown symbol snd_seq_autoload_lock
snd_seq: Unknown symbol snd_info_free_entry
snd_seq: Unknown symbol snd_seq_root
snd_seq: Unknown symbol snd_timer_close
snd_seq: Unknown symbol snd_seq_autoload_unlock
snd_seq: Unknown symbol snd_verbose_printk
omg
wen du mall schreiben würdest welche distri du nutzt.
oder andere zusatzt infos , könnte man dir auch helfen aber so .
solltest du ubuntu nutzten (was mir MEINE glass kugel sagt) den gehe auf http://wiki.ubuntuusers.de/ ins fourm bzw im wikki stehen viele sachen innen über alsa, ich muste zb irgend was in der Linux config um ändern und aus ner 1 ne 2 machen für HD sound karte von "MAxsound"
aber ist zu lange her , steht aber alles im wikki .
sollte meine glass kugel recht haben ;-)
@SpyKill
Es gibt nur ein System, dass 'emerge' verwendet: Gentoo + Derivate
Außerdem steht da ja in den Logs auch Gentoo im Pfad.
@ganjamike
Der Treiber geht wohl nicht. Vllt falsch kompiliert? Hast du eventuell zu scharfe CFlags eingestellt? Bei O3 könnte ich mir derartige Fehler schon vorstellen.
Emerge das nochmal, aber dieses Mal mit anderen Einstellungen.
http://www.alsa-project.org/main/index.php/Matrix:Module-hda-intel
Müsstest die Vorgehensweise bei dir noch anpassen, damit du das über Portage laufen lassen kannst.
Der Fehler kann einige Ursachen haben. Zeigt der Symlink /usr/src/linux auf die Quellen des aktuell laufenden Kernels? Oder hast Du vielleicht einen anderen, älteren gebootet? Hast Du alle alsa Treiber im Kernel deaktiviert?
Was mich aber eher interessiert, warum überhaupt die separaten Treiber? Ich nehme mal an, daß es sich um Onboard Sound handelt, Intel HD Audio deutet darauf hin, die Chips werden alle auch von den Treibern im Kernel unterstützt. Ich nutze den Treiber auch (Realtec Soundchip auf Gigabyte GA-X38-DS5), er läuft problemlos, seit Linux 2.6.24 (aktuell unter Gentoo ist 2.6.24-gentoo-r2) ist im Kernel auch Support für die einzelnen Chips als Option beim Intel Treiber auswählbar.
erst mal danke für die antworten.
@Spykill: führ dich nicht so auf
omg
schau im 1. Post ganz unten (dist=distribution^^)
womit deine "Glaskugel" falsch liegt ;)
@ e-Laurin:falsch compiled den ich mal nicht, und emerged hab ich es auch schon öfters .. was meinst du mit O3?
@frankpr: Die Symlink quellen laufen alle auf den aktuellen Kernel. Ich habe heute auf den 23-r9 upgedated kann aber darüber noch nichts sagen.. werd es aber sobald ich geschaut habe machen. Im Kernel ist mit absicht nur der sound card support aktiviert. Was auch der grund für die seperaten treiber ist, da mein freund n macbook hat und am anfang genau das selbe problem hatte, was er aber nach mehreren monaten gefix hat. Das selbe hab ich jetzt auch probiert, allerdings kommt da eben diese meldung ... braucht ihr noch irgendwelche infos oder so?
danke noch mal für eure hilfe
edit
mmhh noch mal danke für die mühen .. nach dem kernelupdate ging es mit den seperaten treibern, somit war einfach nur der kernel zu alt.. trotzdem danke für die post (bis auf spykill :P .. solche leute mag ich nicht)
Ich mag Doppelposts nicht
mfg aki
closed
Thema O3:
Na ich meine das hier
CHOST="i686-pc-linux-gnu"
CFLAGS="-march=native -O3 -pipe"
CXXFLAGS="${CFLAGS}"
(Das hast du doch sicher schon mal gesehen, oder?)
O3 kann sehr schnelle Programme erzeugen. Die können dann aber möglicherweise nicht richtig funktionieren. Drum wird O2 empfohlen.
Die Betonung liegt auf kann. Durch O3 werden Anwendungen aber auch größer, wodurch das Laden von der Festplatte und der Speicherverbrauch steigt. In der Regel macht O3 wenig Sinn, O2 reicht völlig aus.
