Android ScrollView passt sich nicht richtig an
lucas2018
Okt. 2018
Code:
package com.example.spiel;
import android.content.Context;
import android.view.Gravity;
import android.view.ViewGroup;
import android.widget.EditText;
import android.widget.LinearLayout;
import android.widget.ScrollView;
import android.widget.TextView;
import org.w3c.dom.Text;
public class PunkteFeld extends LinearLayout {
    ScrollTabelle scrollTabelle;
    public PunkteFeld(Context context) {
        super(context);
        setOrientation(VERTICAL);
        LayoutParams layout = new LayoutParams(ViewGroup.LayoutParams.MATCH_PARENT, ViewGroup.LayoutParams.WRAP_CONTENT, 1);
        setLayoutParams(layout);
        LayoutParams flparms = new LayoutParams(ViewGroup.LayoutParams.MATCH_PARENT, ViewGroup.LayoutParams.WRAP_CONTENT);
        TextView spielerName = new TextView(context);
        spielerName.setText("Spieler1");
        spielerName.setLayoutParams(flparms);
        addView(spielerName);
        scrollTabelle = new ScrollTabelle(context);
        addView(scrollTabelle);
        EditText ed = new EditText(context);
        ed.setLayoutParams(flparms);
        addView(ed);
class ScrollTabelle extends ScrollView {
    public ScrollTabelle(Context context) {
        super(context);
        LayoutParams layout = new LayoutParams(ViewGroup.LayoutParams.WRAP_CONTENT, ViewGroup.LayoutParams.WRAP_CONTENT, 1);
        layout.gravity = Gravity.RIGHT;//Funktioniert auch nicht
        LayoutParams layoutLinerar = new LayoutParams(ViewGroup.LayoutParams.WRAP_CONTENT, ViewGroup.LayoutParams.WRAP_CONTENT);
        LinearLayout l = new LinearLayout(context);
        l.setLayoutParams(layoutLinerar);
        l.setOrientation(LinearLayout.VERTICAL);
        for (int i = 0; i < 10; i++) {
            TextView t = new TextView(context);
            t.setLayoutParams(new LayoutParams(ViewGroup.LayoutParams.MATCH_PARENT, ViewGroup.LayoutParams.WRAP_CONTENT));
            t.setText("Test");
            l.addView(t);
        addView(l);
Layout:
XML:
<?xml version="1.0" encoding="utf-8"?>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="wrap_content"
    tools:context="com.example.spiel.SpielActivity">
    <LinearLayout
        android:id="@+id/punkteTabelle"
        android:layout_width="542dp"
        android:layout_height="210dp"
        android:layout_marginStart="47dp"
        android:layout_marginTop="97dp"
        android:layout_marginEnd="77dp"
        android:orientation="horizontal"
        app:layout_constraintBottom_toBottomOf="parent"
        app:layout_constraintEnd_toEndOf="parent"
        app:layout_constraintStart_toStartOf="parent"
        app:layout_constraintTop_toTopOf="parent">
        <LinearLayout
            android:layout_height="match_parent"
            android:layout_weight="1"
            android:orientation="horizontal">
            <LinearLayout
                android:orientation="vertical">
                <TextView
                    android:id="@+id/textView5"
                    android:text="Spieler1" />
                <ScrollView
                    android:layout_width="wrap_content"
                    android:clipToPadding="false"
                    android:scrollbarStyle="insideOverlay">
                    <LinearLayout
                        <TextView
                            android:id="@+id/textView"
                            android:text="TextView" />
                        <TextView
                            android:id="@+id/textView16"
                        <TextView
                            android:id="@+id/textView17"
                        <TextView
                            android:id="@+id/textView18"
                        <TextView
                            android:id="@+id/textView19"
                        <TextView
                            android:id="@+id/textView7"
                        <TextView
                            android:id="@+id/textView8"
                        <TextView
                            android:id="@+id/textView9"
                        <TextView
                            android:id="@+id/textView4"
                    </LinearLayout>
                </ScrollView>
                <EditText
                    android:id="@+id/editTextNumberSigned"
                    android:ems="10"
                    android:inputType="numberSigned" />
            </LinearLayout>
            <LinearLayout
                <TextView
                    android:id="@+id/textView15"
                <TextView
                <ScrollView
                    android:layout_weight="1">
                    <LinearLayout
                        <TextView
                        <TextView
                            android:id="@+id/textView10"
                        <TextView
                            android:id="@+id/textView11"
                        <TextView
                            android:id="@+id/textView12"
                        <TextView
                            android:id="@+id/textView13"
                        <TextView
                            android:id="@+id/textView14"
                        <TextView
                        <TextView
                        <TextView
                    </LinearLayout>
                </ScrollView>
                <EditText
                    android:ems="10"
            </LinearLayout>
        </LinearLayout>
    </LinearLayout>
</androidx.constraintlayout.widget.ConstraintLayout>
Ich habe Folgendes Problem:
Ich habe ein ScrollView das soll immer mehr Einträge erhalten (als PunkteTabelle)
Alerdings bedeckt sie ihre Elemente unter ihr.
Ich habe das ganze im Designer erstellt da funktioniert es problemlos.
Wenn ich das ganze in Java anstelle leider nicht. Ich habe das Layout nachgestellt.
