Arma 3
Pascal67
Aug. 2008
Crash fehler beim Schreiben in den Speicher
Wie öffnet man eine Arma 3 dmp datei?
Microsoft (R) Windows Debugger Version 6.3.9600.17237 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\B-Tight23\AppData\Local\Arma 3\arma3_2015-01-15_22-08-04.mdmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 8 Version 9600 MP (8 procs) Free x86 compatible
Product: WinNt, suite: SingleUserTS Personal
Built by: 6.3.9600.17031 (winblue_gdr.140221-1952)
Machine Name:
Debug session time: Thu Jan 15 22:42:09.000 2015 (UTC + 1:00)
System Uptime: not available
Process Uptime: 0 days 0:34:05.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(d7c.534): Access violation - code c0000005 (first/second chance not available)
*** WARNING: Unable to verify timestamp for ntdll.dll
*** ERROR: Module load completed but symbols could not be loaded for ntdll.dll
eax=00000000 ebx=196d8a80 ecx=00000000 edx=00000000 esi=196d8a38 edi=196d8a48
eip=77acd74c esp=220de964 ebp=220de970 iopl=0 nv up ei pl nz na po nc
cs=0023 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000202
ntdll+0x3d74c:
77acd74c c20800 ret 8
Das ist das einzigste was die Ereignissanzeigee dazu sagt:
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2015-01-17T19:19:56.000000000Z
EventRecordID 14806
Channel Application
Computer B-Tight
Security
- EventData
arma3.exe
1.36.128.579
5480321d
arma3.exe
1.36.128.579
5480321d
c0000005
0074ece3
1044
01d0327e54963ea7
E:\SteamLibrary\steamapps\common\Arma 3\arma3.exe
d1a1d13e-9e7d-11e4-bf7f-08606ed73605
Google ist dein Freund !
Programme zur Absturzanalyse gibts bei Microsoft oder im sonstigen Netz.
Ob das was bringt ist die Frage.
Bei Abstürzen mal in die Windows-Ereignisanzeige schauen - da stehen Uhrzeiten und Fehlermeldungen womit man das Problem evtl. eingrenzen kann.
Allg. Speicherfehler - das kann leider alles mögliche sein. Schau in meine Sig, da gibt es Infos.
UNd bitte, formuliere mal Deine Fragen konkreter, nicht nur C&P!!.
Dumpfiles kannst Du nur direkt zu Bohemia zur Fehleranalyse senden, nicht selber auswerten, da fehlen Dir die Tools. ;)
Wie mein Vorredner jedoch schon sagte, Google gibt Dir alle Antworten. :D
Witzig klar,aber die arma dump datei ging damit nicht auf,deswegen hab ich hier gefragt.Aber die Antwort habe ich ja nun.
