Assassin Creed Oddyssey - flickering on 2080 ti
sew333
Juli 2017
Hello. I am getting something like this,but not intense like on youtube. My problem is that it will flicker for 1 second very often after starting a game and it stop.
It looks like this:
Not exactly and continuosly like on video. I start game play 4 minutes, then i see a flicker ( random weird object or block ) for 1 second and no issue again,and its fine.
My pc:
9900K stock 60C
2x16GB DDR4 GSKILL 3000mhz
Aorus 2080 Ti Rtx Waterforce 59C on game, no oc,stock all.
Windows 10 1903.
Drivers up to date 431.60.
Any ideas?
I tested all benchmarks firestrike,ungine,metro,tomb raider,wolfenstein,battlefield 5 and no issues .
Upto-date drivers are not always the best, before upgrading im always reading the thread onto a version and decide a week later if i may upgrade.
https://forums.guru3d.com/forums/videocards-nvidia-geforce-drivers-section.21/
This way im upgrading not every build number but maybe once a month or 2, but all games are very stable.
If you instantly upgrade to any new build number dont expect all games running perfectly.
Either try a stable older version, im on 430.86 as it is rock stable(and im using the cleaned ones without any crap or telemetry using NvSlimmer).
Or you try the 431.68 Hotfix or 435.80 preview.
it will flicker once for 1 second . Flicker something like texture or other weird object like triangle etc. And then its fine 24 hours. And that happens in one particular place in game. So propably game fluke not card?
I found incidentally on youtube with other user, it is something like that ! look:
But he have Rtx 2080
807299
1:26
Also my game is not updated,maybe just update game? There was release on update notes about lightning and textures issues
