ATITool 0.0.23 released!
Day.wal.ker
Commodore
Jan. 2004
Seit gestern Nacht ist eine neue Version des ATITools verfügbar. Unter anderem lässt sich nun auch ein Temperaturgraph anzeigen. Den Downloadlink gibt's unten :)
Version 0.0.23
- Added memory timings editor support for R430 and R480
- From this version on the installer will be able to detect a running ATITool instance
- Button "Mem" is now disabled when no ATI card detected
- "Delta of 0 in 0 (- avg). No errors for mm:ss.xx" message reworded to "No errors for mm:ss.xx"
- Logo is shown in the main window when temp. monitoring is inactive
- Fixed broken X800SE temp. monitoring
- Added save file dialog to dump bios
- Added support for M28, R430, R480, R423GL
- Added temp. monitoring option "show default icon in tray"
- Added hw monitoring support for Abit uGuru (AA8, AG8, AI7, AN7, AS8, AV8, KV8)
- Added support for Abit RX600
- Added hw monitoring support for LM87, ADM1022, ADM1024, ADM1025, ADM1028, THMC50, FMS2701, NE1619
- Added option to use "old scanning method"
- Fixed issues in "Startup" settings
- Added Catalyst AI support for 4.9 drivers
- Added detection/overclocking/mem timings support for X800 SE AGP
- Fixed crash issue on non-ATI cards
- Added support for changing Catalyst AI settings
- Fix for incorrect TAA detection with ATI Catalyst Control Center
- Installer will now detect running ATIToolHooks.dll and mark it to be replaced at reboot
- Installer will now detect running ATITool and ask to close it
- Added M10 support to memory timings editor
- Minor improvements to artifact scanning and detection
- Added removal of Macrovision detection from analog input recording driver
- Fixed crash when year>2038 (#81)
- Added GPU temp. graph to main window
- Reorganized user interface and 2D/3D profiles, feedback please
- Added Catalyst version display
- Fixed artifacts sometimes not cleared between scans
- Added minimize on close option
- Minor changes to the Hardware Monitoring page
- Added experimental Hardware Monitoring settings page
- Added HDD temperature to AAM page
- More fixes and informational messages to HDD AAM
- Fixed GPF when no suitable 3D device was found
- Fixes to 3D detection .. seems that 3DMark01 and Warcraft 3 problems are fixed now
- Rendering window can no longer be resized, there's no stress gained from a bigger window anyways
- Selection defaults to first HDD in AAM page
- Added Harddisk Acoustic Management - yeah I know, not ATI related
- Improved artifact detection on X800
- Improved scanning on PS2.0 cards, you should get much higher temperatures now. Please verify that ATITool still works on non-ps2.0 cards.
- Revamped memory timings editor: added support for R300, R350, R360, R420, RV350, RV360, RV370, RV380, RV410
- Fixed RV410 detection and overclocking
- The clock rate input boxes now allow "," as decimal seperator, too
- Fixed multiple "Scan for artifacts running 00:00:00" messages
- Normal users can now use ATITool and get the settings the Administrator has chosen when he ran ATITool with his account, changes to settings made by normal users are not saved.
- Could not write to log file message will no longer pop up multiple times.
- If MBM is not running, but is needed to send temp. data to it, ATITool will try to connect to MBM every 10 seconds.
- Added "Click here to change" to font display in Settings -> Temp. Monitoring
- Fixed AIW TV Tuner broken when ATITool is installed on the system (#8)
- 2D Profile will be set to "disabled" after changing video cards.
- Fixed race condition which resulted in a crash at quit sometimes
- Reenabled Fan Control for 9600, seems to work on some cards.
- Fixed wrong logging of set clock rates (#42)
Quelle: techpowerup.com
Download ATITool 0.0.23
na schaut doch schoneimal vielversprechend aus.
werde es gleich einmal probieren!
Wieso wird denn bitte in einem Grafikkarten-Übertaktungs-Programm die Möglichkeit eingebunden, das Acoustic Management seiner Hdd einzustellen? Das will mir einfach nicht in den Kopf.
Abgesehn von der Tatsache, dass es in meinen Augen Schwachsinn ist, funktioniert das Feature beim AtiTool zumindest bei meiner Ibm/Hitachi Platte nicht. Obwohl diese Platte definitiv AAM beherrscht, habe es schon selbst mit Hilfe des IBM Feature-Tools umgestellt .
Trotzdem danke für die Info ;)
Bei denen, die einen Tempsensor/-chip verbaut haben.
Das sind bei älteren Modellen die XT-Varianten, sprich 9600xt, 9800xt (unter Umständen auch die 9800pro, wenn sie über den r360 verfügt und im XT-layout daher kommt). Ich glaube, die neuen x800-Modelle verfügen alle über einen solchen Sensor, sicher bin ich mir da aber nicht.
bei allen die einen temp.sensor besitzen:
9600xt,9800xt...x800er reihe wohl fast alle wenn ich mich nicht täusche.
Vollkommen korrekt!
in der Regel sind alle ATI Radeon ..XT und alle ATI Radeon X800 Karten mit einem Temperatursensor ausgestattet :)
Jepp,dass hat mich auch verwirrt beim ausprobiern der neuen Version .. sehr komisch :confused_alt:
DenTemperaturgraphen, find ich sehr schick ;) bzw. nach der neuen Rechtschreibung chick *lach*
Hat eine MSI X800SE 256MB auch einen Temp-Chip?
Hab mal bei einem Freund einen Rechner mit dieser Karte zusammengebaut, aber ich konnte mit keinem der bekannten Tools die Temps auslesen. Auch mit dieser Version des ATI-Tools klappts nicht!
Also scheinen doch nicht alle X800 Karten einen Temp-Chip verbaut zu haben! :confused_alt:
