Nachdem Du mir dazu geraten hattest, den Haken reinzumachen, tat ich das. Dieser ist nun seit 4 Versuchen angehakt. :-)
General
Unique ID : 248241008806770329984192037164545442678 (0xBAC17AAEB97DD1B79C01345BD6678376)
Complete name : C:\Games\Movies\Movies_Final\Morchok_neu_mux.mkv
Format : Matroska
Format version : Version 2
File size : 662 MiB
Duration : 7mn 6s
Overall bit rate mode : Variable
Overall bit rate : 13.0 Mbps
Encoded date : UTC 2012-03-16 18:56:30
Writing application : mkvmerge v5.4.0 ('Piper') built on Mar 10 2012 13:34:39
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 7mn 6s
Width : 2 560 pixels
Height : 1 600 pixels
Display aspect ratio : 1.600
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 122 r2184 5c85e0a
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 7mn 6s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Default : Yes
Forced : No
- Die FLAC habe ich soeben encodiert.
Wieso sollte man eine .flac nochmals encodieren, wenn sie bereits mit Audacity erstellt wurde? Habe ich davor auch nie gemacht. P.S.
Woran erkenne ich, dass es Stereo ist? Dazu gibt es keine spezifische Option ausser den 44.1 kHz und 16 bit in Audacity zum Einstellen in den Optionen.
- Ich benutze nachwievor die 1.3.14 BETA von Audacity.
Zu guter Letzt habe ich die neuencodierte .flac, zusammen mit dem neugemuxten Video und dem Intro zusammengefuehrt. Siehe
morchok_mit_neu_audio_mux.mkv
Morchok_neu_mux.mkv ist die Datei, die komplett einzeln neu gemuxt wurde. Allerdings
ohne der neuen .flac, die ich encodieren sollte.
morchok_mit_neu_audio_mux.mkv die eben hochgeladen wird, ist jene Datei die ebenfalls komplett neu gemuxt wurde, allerdings
mit der neuen, encodierten .flac!
Morchok (2).mkv ist gleich der ersten nur mit Originalton, ohne .flac.
Ich habe gerade 3 neue Dateien erstellt und geuploaded (werden gerade hochgeladen). Die Unterscheiden sich dadurch, dass die erste Datei
Morchok (2).mkv mit Originalsound aus dem Teamspeak ist. Dadurch wollte ich sichergehen, ob es tatsaechlich an der .flac liegt oder nicht. Die beiden anderen Dateien
Morchok_neu_mux.mkv sowie
morchok_mit_neu_audio_mux.mkv sind zwar komplett neu gemuxt aber letztere mit encodierter .flac.
