Avira Launcher Pfad herausfinden mit VB-Scribt
Status
nierewa
Juni 2008
Hallo Leute,
ich suche einen Weg den Avira Launcher zu deinstallieren und zwar silent über die Kommandozeile.
Auf dieser Seite habe ich einen Weg per Phyton gefunden:
Code:
import os
import re
import random
import socket
import _winreg
import re
from subprocess import PIPE, Popen
import shutil
rK = _winreg.HKEY_LOCAL_MACHINE
sK = r'SYSTEM\CurrentControlSet\Control\Session Manager\Environment'
openedKey = _winreg.OpenKey(rK, sK, 0, _winreg.KEY_READ)
arch, bla = _winreg.QueryValueEx(openedKey, 'PROCESSOR_ARCHITECTURE')
arch = str(arch)
def ExecuteCMD(CMD, OUT = False):
    import ctypes
    class disable_file_system_redirection:
        _disable = ctypes.windll.kernel32.Wow64DisableWow64FsRedirection
        _revert = ctypes.windll.kernel32.Wow64RevertWow64FsRedirection
        def __enter__(self):
            self.old_value = ctypes.c_long()
            self.success = self._disable(ctypes.byref(self.old_value))
        def __exit__(self, type, value, traceback):
            if self.success:
                self._revert(self.old_value)
    with disable_file_system_redirection():
        OBJ = Popen(CMD, shell = True, stdout = PIPE, stderr = PIPE)
    out, err = OBJ.communicate()
    RET = OBJ.returncode
    if RET == 0:
        if OUT == True:
            if out != '':
                return out.strip()
            else:
                return True
        else:
            return True
    return False
def agentuninstall(agentpath):
        agentpath=agentpath+r"\setup.exe"
        CMD='"'+agentpath+'"' + " /remsilentnoreboot "
if arch == 'AMD64':
        agentpath1=r"C:\Program Files (x86)\Avira"
        agentpath=r"C:\Program Files (x86)\Avira\Antivirus"
        if os.path.exists(agentpath):
            print "Avira is successfully uninstalled in endpoint"
        else:
            print "Avira is not installed in endpoint"
else:
        agentpath1=r"C:\Program Files\Avira"
        agentpath=r"C:\Program Files\Avira\Antivirus"
        else:
CMD='tasklist | find "Avira"'
Ki=ExecuteCMD(CMD, OUT = True)
if Ki!=False:
    Ki=re.findall("(.*).exe",Ki)
    if len(Ki)>0:
        for i in Ki:
            Taskname='"'+i+'.exe"'
            CMD=Taskname
            print ExecuteCMD(CMD, OUT = True)
import os
exe = 'Avira.OE.Setup.Bundle.exe'
for root, dirs, files in os.walk(r'C:\ProgramData\Package Cache'):
    for name in files:
        if name == exe:
            Path=os.path.abspath(os.path.join(root, name))
try:
    CMD='"'+Path+'"' + " /uninstall /quiet "
    ExecuteCMD(CMD)
    ExecuteCMD("shutdown /a")
except:
    pass
if os.path.exists(agentpath1):
            try:
                shutil.rmtree(agentpath1)
            except:
                pass
Für mich wäre wohl das hier interessant, da Avira selbst schon deinstalliert ist:
Code:
import os
    for name in files:
        if name == exe:
try:
    ExecuteCMD(CMD)
except:
    pass
            try:
            except:
                pass
Ich muß also "nur" den Pfad für die Datei Avira.OE.Setup.Bundle.exe herausfinden und die dann mit /uninstall /quiet
deinstallieren. Klingt einfach, Problem: ich brauche das ganz schnell als vb-scribt
Kann mir jemand helfen oder fix was schreiben?
Danke :D
Mag ja sein, dass es jemand anders sieht, aber ich möchte nicht deine Arbeit erledigen. Dir helfen, wenn Du ein Problem hast gerne, aber ich bau Dir das nicht ohne Eigeninitiative.
Außerdem ist dein Ansatz merkwürdig. Warum deinstallierst Du Avira nicht einfach über das Admin Panel und weiß der kompletten Gruppe einfach einen Uninstall zu?
Reaktionen: adAstra
Schließe mich da @tRITON an. Gibt da ja noch andere Wege "drumherum". Warum also per VBS...
Reaktionen: adAstra
Und warum schnell und fix? Brauchst du das gerade für etwas bestimmtes?
Warum keine Eigenleistung?
Da es nach Fragen, Hausaufgaben & Co. riecht, ist deswegen auch zu.
Reaktionen: Kleiner69
Status
