Könnte mal bitte jemand meine Smartwerte überprüfen, ob Fehler vorhanden, und
wenn, auf welcher SSD (2 Stück) oder Festplatte (4 Stück). Ich habe von der Materie keine Ahnung.
Daten im Anhang.
Der Aufgabenplaner hat eine geplante Aufgabe abgeschlossen.
Aufgabe: Smartwerte Script
Start: Tue, 04 Feb 2025 12:46:05 +0100
Ende: Tue, 04 Feb 2025 12:46:06 +0100
Aktueller Status: 0 (Normal)
Standardausgabe/Fehler:
Health status of internal HDD's:
Drive /dev/sda:
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: Samsung SSD 870 EVO 1TB
Firmware Version: SVT02B6Q
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: Unknown(0x09fc), ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 4 12:46:05 2025 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Error Log Version: 1
No Errors Logged
ID | Attribute | (1) | (2) | (3) | (4)
5 | Reallocated_Sector_Ct | 100 | 100 | 010 | 0 <!
9 | Power_On_Hours | 097 | 097 | 000 | 13777
12 | Power_Cycle_Count | 099 | 099 | 000 | 93
177 | Wear_Leveling_Count | 099 | 099 | 000 | 2 <!
179 | Used_Rsvd_Blk_Cnt_Tot | 100 | 100 | 010 | 0 <!
181 | Program_Fail_Cnt_Total | 100 | 100 | 010 | 0
182 | Erase_Fail_Count_Total | 100 | 100 | 010 | 0
183 | Runtime_Bad_Block | 100 | 100 | 010 | 0 <!
187 | Uncorrectable_Error_Cnt | 100 | 100 | 000 | 0
190 | Airflow_Temperature_Cel | 070 | 054 | 000 | 30
195 | ECC_Error_Rate | 200 | 200 | 000 | 0
199 | CRC_Error_Count | 100 | 100 | 000 | 0
235 | POR_Recovery_Count | 099 | 099 | 000 | 21
241 | Total_LBAs_Written | 099 | 099 | 000 | 7467195958
252 | Added_Bad_Flash_Blk_Ct | 100 | 100 | 000 | 317
(1) Value, (2) Worst, (3) Threshold, (4) Raw, <! Pre-fail value
Drive /dev/sdb:
Firmware Version: SVT01B6Q
ATA Error Count: 18 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 18 occurred at disk power-on lifetime: 14788 hours (616 days + 4 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 40 00 2a 8c 40 Error: WP at LBA = 0x008c2a00 = 9185792
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 58 40 00 2a 8c 40 08 15d+23:47:23.816 WRITE FPDMA QUEUED
61 08 38 38 37 d3 40 07 15d+23:47:23.816 WRITE FPDMA QUEUED
60 08 30 b0 68 2e 40 06 15d+23:47:23.816 READ FPDMA QUEUED
60 08 28 a8 68 2e 40 05 15d+23:47:23.816 READ FPDMA QUEUED
60 08 20 a0 68 2e 40 04 15d+23:47:23.816 READ FPDMA QUEUED
Error 17 occurred at disk power-on lifetime: 14788 hours (616 days + 4 hours)
40 51 50 30 68 2e 40 Error: UNC at LBA = 0x002e6830 = 3041328
60 08 50 30 68 2e 40 0a 15d+23:47:23.410 READ FPDMA QUEUED
60 08 48 28 68 2e 40 09 15d+23:47:23.410 READ FPDMA QUEUED
60 08 40 20 68 2e 40 08 15d+23:47:23.410 READ FPDMA QUEUED
60 08 38 18 68 2e 40 07 15d+23:47:23.410 READ FPDMA QUEUED
60 08 30 10 68 2e 40 06 15d+23:47:23.410 READ FPDMA QUEUED
Error 16 occurred at disk power-on lifetime: 14788 hours (616 days + 4 hours)
40 51 18 b8 67 2e 40 Error: UNC at LBA = 0x002e67b8 = 3041208
60 08 18 b8 67 2e 40 03 15d+23:47:23.005 READ FPDMA QUEUED
61 08 08 48 44 45 40 01 15d+23:47:23.005 WRITE FPDMA QUEUED
60 08 00 b0 67 2e 40 00 15d+23:47:23.005 READ FPDMA QUEUED
ec 00 00 00 00 00 40 19 15d+23:47:23.005 IDENTIFY DEVICE
60 08 c8 a8 67 2e 40 19 15d+23:47:23.005 READ FPDMA QUEUED
Error 15 occurred at disk power-on lifetime: 14788 hours (616 days + 4 hours)
40 51 e0 c0 39 34 40 Error: UNC at LBA = 0x003439c0 = 3422656
60 08 e0 c0 39 34 40 1c 15d+23:47:22.710 READ FPDMA QUEUED
60 28 d8 e0 13 33 40 1b 15d+23:47:22.710 READ FPDMA QUEUED
60 00 d0 e0 12 33 40 1a 15d+23:47:22.710 READ FPDMA QUEUED
60 b8 c8 58 61 32 40 19 15d+23:47:22.710 READ FPDMA QUEUED
60 00 c0 58 60 32 40 18 15d+23:47:22.710 READ FPDMA QUEUED
Error 14 occurred at disk power-on lifetime: 14788 hours (616 days + 4 hours)
40 51 e0 98 68 2e 40 Error: UNC at LBA = 0x002e6898 = 3041432
60 40 e0 98 68 2e 40 1c 15d+23:47:22.431 READ FPDMA QUEUED
60 00 d8 70 85 2e 40 1b 15d+23:47:22.431 READ FPDMA QUEUED
60 00 d0 70 86 2e 40 1a 15d+23:47:22.431 READ FPDMA QUEUED
60 10 c8 70 87 2e 40 19 15d+23:47:22.431 READ FPDMA QUEUED
60 00 c0 88 93 2e 40 18 15d+23:47:22.431 READ FPDMA QUEUED
5 | Reallocated_Sector_Ct | 076 | 076 | 010 | 270 <!
9 | Power_On_Hours | 096 | 096 | 000 | 15157
12 | Power_Cycle_Count | 099 | 099 | 000 | 141
177 | Wear_Leveling_Count | 099 | 099 | 000 | 7 <!
179 | Used_Rsvd_Blk_Cnt_Tot | 076 | 076 | 010 | 270 <!
183 | Runtime_Bad_Block | 076 | 076 | 010 | 270 <!
187 | Uncorrectable_Error_Cnt | 099 | 099 | 000 | 18
190 | Airflow_Temperature_Cel | 068 | 051 | 000 | 32
195 | ECC_Error_Rate | 199 | 199 | 000 | 18
235 | POR_Recovery_Count | 099 | 099 | 000 | 22
241 | Total_LBAs_Written | 099 | 099 | 000 | 9349742459
Drive /dev/sdc:
Model Family: Western Digital Gold
Device Model: WDC WD161KRYZ-01AGBB0
Firmware Version: 01.01H01
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: Unknown(0x0ffc) (unknown minor revision code: 0x009c)
No Errors Logged
1 | Raw_Read_Error_Rate | 100 | 100 | 001 | 0 <!
2 | Throughput_Performance | 135 | 135 | 054 | 100 <!
3 | Spin_Up_Time | 083 | 083 | 001 | 349 <!
4 | Start_Stop_Count | 100 | 100 | 000 | 131
5 | Reallocated_Sector_Ct | 100 | 100 | 001 | 0 <!
7 | Seek_Error_Rate | 099 | 099 | 001 | 65536 <!
8 | Seek_Time_Performance | 140 | 140 | 020 | 15 <!
9 | Power_On_Hours | 098 | 098 | 000 | 16097
10 | Spin_Retry_Count | 100 | 100 | 001 | 0 <!
12 | Power_Cycle_Count | 099 | 099 | 000 | 131
22 | Helium_Level | 100 | 100 | 025 | 100 <!
192 | Power-Off_Retract_Count | 100 | 100 | 000 | 819
193 | Load_Cycle_Count | 100 | 100 | 000 | 819
194 | Temperature_Celsius | 051 | 051 | 000 | 42
196 | Reallocated_Event_Count | 100 | 100 | 000 | 0
197 | Current_Pending_Sector | 100 | 100 | 000 | 0
198 | Offline_Uncorrectable | 100 | 100 | 000 | 0
199 | UDMA_CRC_Error_Count | 100 | 100 | 000 | 0
Drive /dev/sdd:
ATA Error Count: 3
Error 3 occurred at disk power-on lifetime: 2002 hours (83 days + 10 hours)
40 43 00 00 00 00 00 Error: UNC at LBA = 0x00000000 = 0
60 08 d0 e8 2a 44 40 08 2d+05:21:39.403 READ FPDMA QUEUED
61 08 d8 28 df 21 40 08 2d+05:21:36.874 WRITE FPDMA QUEUED
60 08 c8 e0 2a 44 40 08 2d+05:21:36.857 READ FPDMA QUEUED
61 08 c0 e0 2a 44 40 08 2d+05:21:36.857 WRITE FPDMA QUEUED
ea 00 00 00 00 00 a0 08 2d+05:21:36.851 FLUSH CACHE EXT
Error 2 occurred at disk power-on lifetime: 2002 hours (83 days + 10 hours)
60 08 e0 e0 2a 44 40 08 2d+05:21:36.694 READ FPDMA QUEUED
61 40 e8 e8 05 48 40 08 2d+05:21:34.433 WRITE FPDMA QUEUED
60 08 d8 d8 2a 44 40 08 2d+05:21:34.124 READ FPDMA QUEUED
60 08 d0 d0 2a 44 40 08 2d+05:21:34.124 READ FPDMA QUEUED
60 08 c8 c8 2a 44 40 08 2d+05:21:34.124 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 2002 hours (83 days + 10 hours)
60 50 58 a0 28 44 40 08 2d+05:21:33.803 READ FPDMA QUEUED
60 b0 60 f0 2d 44 40 08 2d+05:21:31.318 READ FPDMA QUEUED
60 00 50 a0 20 44 40 08 2d+05:21:31.315 READ FPDMA QUEUED
60 60 48 40 18 44 40 08 2d+05:21:31.313 READ FPDMA QUEUED
60 a0 40 a0 10 44 40 08 2d+05:21:31.312 READ FPDMA QUEUED
3 | Spin_Up_Time | 083 | 083 | 001 | 352 <!
7 | Seek_Error_Rate | 100 | 100 | 001 | 0 <!
192 | Power-Off_Retract_Count | 100 | 100 | 000 | 818
193 | Load_Cycle_Count | 100 | 100 | 000 | 818
194 | Temperature_Celsius | 050 | 050 | 000 | 43
Drive /dev/sde:
Model Family: Red
Device Model: WDC WD120EFAX-68UNTN0
Firmware Version: 81.00A81
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 4 12:46:06 2025 CET
No Errors Logged
1 | Raw_Read_Error_Rate | 100 | 100 | 016 | 0 <!
2 | Throughput_Performance | 129 | 129 | 054 | 104
3 | Spin-up_Time | 163 | 163 | 024 | 34386149779 <!
4 | Start/Stop_Count | 100 | 100 | 000 | 959
5 | Re-allocated_Sector_Count | 100 | 100 | 005 | 0 <!
7 | Seek_Error_Rate | 100 | 100 | 067 | 0
8 | Seek_Time_Performance | 128 | 128 | 020 | 18
9 | Power-on_Hours_Count | 097 | 097 | 000 | 24678
10 | Spin_Retry_Count | 100 | 100 | 060 | 0
12 | Drive_Power_Cycle_Count | 100 | 100 | 000 | 254
22 | Internal_Environment_Status_He... | 100 | 100 | 025 | 100 <!
192 | Power_Off_Restart_Count | 099 | 099 | 000 | 1797
193 | Load/Unload_Cycles | 099 | 099 | 000 | 1797
194 | Temperature | 158 | 158 | 000 | 41
196 | Relocation_Event_Count | 100 | 100 | 000 | 0
197 | Current_Pending_Sector_Count | 100 | 100 | 000 | 0
198 | Off-Line_Scan_Uncorrectable_Se... | 100 | 100 | 000 | 0
199 | Ultra_DMA_CRC_Error_Count/Fram... | 200 | 200 | 000 | 0
Drive /dev/sdf:
Model Family: Red
No Errors Logged
2 | Throughput_Performance | 127 | 127 | 054 | 112
3 | Spin-up_Time | 159 | 159 | 024 | 34386870686 <!
192 | Power_Off_Restart_Count | 099 | 099 | 000 | 1799
193 | Load/Unload_Cycles | 099 | 099 | 000 | 1799
194 | Temperature | 171 | 171 | 000 | 38
Von Diskstation1618
Danke
Gr. Reinhold
Daten im Anhang.
Drive /dev/sda:
No Errors Logged
Drive /dev/sdb:
Drive /dev/sdc:
No Errors Logged
Drive /dev/sdd:
ATA Error Count: 3
Drive /dev/sde:
Model Family: Red
No Errors Logged
Drive /dev/sdf:
Model Family: Red
No Errors Logged
Von Diskstation1618
Danke
Gr. Reinhold
