Guten Tag,
hab seit mehreren Tagen immer einen Bluescreen, kann es am Netzteil liegen ?
Weil ein Bekannter meintes es bricht immer die Stromzufuhr ab.
Microsoft (R) Windows Debugger Version 6.10.0003.233 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\chris\Desktop\101314-40747-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16792.amd64fre.win7_gdr.110408-1633
Machine Name:
Kernel base = 0xfffff800`02e02000 PsLoadedModuleList = 0xfffff800`0303fe50
Debug session time: Mon Oct 13 02:34:04.377 2014 (GMT+1)
System Uptime: 0 days 0:01:15.718
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 101, {21, 0, fffff880009b1180, 4}
Unable to load image \SystemRoot\system32\drivers\fltmgr.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for fltmgr.sys
*** ERROR: Module load completed but symbols could not be loaded for fltmgr.sys
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
Unable to load image \SystemRoot\system32\drivers\fileinfo.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for fileinfo.sys
*** ERROR: Module load completed but symbols could not be loaded for fileinfo.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe
Followup: MachineOwner
0: kd> !analyze -v
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000021, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffff880009b1180, The PRCB address of the hung processor.
Arg4: 0000000000000004, 0.
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
MODULE_NAME: nt
FAULTING_MODULE: fffff80002e02000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fdd34
BUGCHECK_STR: CLOCK_WATCHDOG_TIMEOUT_6_PROC
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`03158528 fffff800`02e20473 : 00000000`00000101 00000000`00000021 00000000`00000000 fffff880`009b1180 : nt+0x70700
fffff880`03158530 00000000`00000101 : 00000000`00000021 00000000`00000000 fffff880`009b1180 00000000`00000004 : nt+0x1e473
fffff880`03158538 00000000`00000021 : 00000000`00000000 fffff880`009b1180 00000000`00000004 0000001b`00000000 : 0x101
fffff880`03158540 00000000`00000000 : fffff880`009b1180 00000000`00000004 0000001b`00000000 00000004`00000000 : 0x21
fffff880`03158548 fffff880`009b1180 : 00000000`00000004 0000001b`00000000 00000004`00000000 00000005`00000000 : 0x0
fffff880`03158550 00000000`00000004 : 0000001b`00000000 00000004`00000000 00000005`00000000 fffff880`03158568 : 0xfffff880`009b1180
fffff880`03158558 0000001b`00000000 : 00000004`00000000 00000005`00000000 fffff880`03158568 fffffa80`048e5860 : 0x4
fffff880`03158560 00000004`00000000 : 00000005`00000000 fffff880`03158568 fffffa80`048e5860 00000000`00000001 : 0x1b`00000000
fffff880`03158568 00000005`00000000 : fffff880`03158568 fffffa80`048e5860 00000000`00000001 00000000`00000004 : 0x4`00000000
fffff880`03158570 fffff880`03158568 : fffffa80`048e5860 00000000`00000001 00000000`00000004 fffff880`031586f0 : 0x5`00000000
fffff880`03158578 fffffa80`048e5860 : 00000000`00000001 00000000`00000004 fffff880`031586f0 00000000`0000000c : 0xfffff880`03158568
fffff880`03158580 00000000`00000001 : 00000000`00000004 fffff880`031586f0 00000000`0000000c fffff800`02fece80 : 0xfffffa80`048e5860
fffff880`03158588 00000000`00000004 : fffff880`031586f0 00000000`0000000c fffff800`02fece80 fffff780`00000320 : 0x1
fffff880`03158590 fffff880`031586f0 : 00000000`0000000c fffff800`02fece80 fffff780`00000320 00000000`000012f5 : 0x4
fffff880`03158598 00000000`0000000c : fffff800`02fece80 fffff780`00000320 00000000`000012f5 fffff800`02e7ade7 : 0xfffff880`031586f0
fffff880`031585a0 fffff800`02fece80 : fffff780`00000320 00000000`000012f5 fffff800`02e7ade7 00000000`00000000 : 0xc
fffff880`031585a8 fffff780`00000320 : 00000000`000012f5 fffff800`02e7ade7 00000000`00000000 fffff800`00000004 : nt+0x1eae80
fffff880`031585b0 00000000`000012f5 : fffff800`02e7ade7 00000000`00000000 fffff800`00000004 00000000`00026160 : 0xfffff780`00000320
fffff880`031585b8 fffff800`02e7ade7 : 00000000`00000000 fffff800`00000004 00000000`00026160 00000000`00000000 : 0x12f5
fffff880`031585c0 00000000`00000000 : fffff800`00000004 00000000`00026160 00000000`00000000 00000000`00040004 : nt+0x78de7
fffff880`031585c8 fffff800`00000004 : 00000000`00026160 00000000`00000000 00000000`00040004 00000000`0000002c : 0x0
fffff880`031585d0 00000000`00026160 : 00000000`00000000 00000000`00040004 00000000`0000002c 00000000`00000000 : 0xfffff800`00000004
fffff880`031585d8 00000000`00000000 : 00000000`00040004 00000000`0000002c 00000000`00000000 00000000`00000000 : 0x26160
fffff880`031585e0 00000000`00040004 : 00000000`0000002c 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
fffff880`031585e8 00000000`0000002c : 00000000`00000000 00000000`00000000 00000000`00000000 fffff6fc`00040004 : 0x40004
fffff880`031585f0 00000000`00000000 : 00000000`00000000 00000000`00000000 fffff6fc`00040004 00000000`00000012 : 0x2c
fffff880`031585f8 00000000`00000000 : 00000000`00000000 fffff6fc`00040004 00000000`00000012 00000000`00000000 : 0x0
fffff880`03158600 00000000`00000000 : fffff6fc`00040004 00000000`00000012 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158608 fffff6fc`00040004 : 00000000`00000012 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158610 00000000`00000012 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00040004 : 0xfffff6fc`00040004
fffff880`03158618 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00040004 00000000`0000002c : 0x12
fffff880`03158620 00000000`00000000 : 00000000`00000000 00000000`00040004 00000000`0000002c 00000000`00000000 : 0x0
fffff880`03158628 00000000`00000000 : 00000000`00040004 00000000`0000002c 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158630 00000000`00040004 : 00000000`0000002c 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158638 00000000`0000002c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x40004
fffff880`03158640 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00040001 : 0x2c
fffff880`03158648 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00040001 00000000`00000004 : 0x0
fffff880`03158650 00000000`00000000 : 00000000`00000000 00000000`00040001 00000000`00000004 fffffa80`049228e0 : 0x0
fffff880`03158658 00000000`00000000 : 00000000`00040001 00000000`00000004 fffffa80`049228e0 00000000`00000000 : 0x0
fffff880`03158660 00000000`00040001 : 00000000`00000004 fffffa80`049228e0 00000000`00000000 fffff880`03158720 : 0x0
fffff880`03158668 00000000`00000004 : fffffa80`049228e0 00000000`00000000 fffff880`03158720 fffff880`0107d32e : 0x40001
fffff880`03158670 fffffa80`049228e0 : 00000000`00000000 fffff880`03158720 fffff880`0107d32e 00000000`00000001 : 0x4
fffff880`03158678 00000000`00000000 : fffff880`03158720 fffff880`0107d32e 00000000`00000001 00000000`00001000 : 0xfffffa80`049228e0
fffff880`03158680 fffff880`03158720 : fffff880`0107d32e 00000000`00000001 00000000`00001000 00000000`00000000 : 0x0
fffff880`03158688 fffff880`0107d32e : 00000000`00000001 00000000`00001000 00000000`00000000 00000000`00000001 : 0xfffff880`03158720
fffff880`03158690 00000000`00000001 : 00000000`00001000 00000000`00000000 00000000`00000001 fffff800`02fece80 : fltmgr+0x432e
fffff880`03158698 00000000`00001000 : 00000000`00000000 00000000`00000001 fffff800`02fece80 fffff800`033e8895 : 0x1
fffff880`031586a0 00000000`00000000 : 00000000`00000001 fffff800`02fece80 fffff800`033e8895 fffff800`0340d460 : 0x1000
fffff880`031586a8 00000000`00000001 : fffff800`02fece80 fffff800`033e8895 fffff800`0340d460 fffff880`03158770 : 0x0
fffff880`031586b0 fffff800`02fece80 : fffff800`033e8895 fffff800`0340d460 fffff880`03158770 fffff800`0340d460 : 0x1
fffff880`031586b8 fffff800`033e8895 : fffff800`0340d460 fffff880`03158770 fffff800`0340d460 00000000`00000000 : nt+0x1eae80
fffff880`031586c0 fffff800`0340d460 : fffff880`03158770 fffff800`0340d460 00000000`00000000 00000000`1093f1bd : hal+0xa895
fffff880`031586c8 fffff880`03158770 : fffff800`0340d460 00000000`00000000 00000000`1093f1bd fffff800`02e6ebf3 : hal+0x2f460
fffff880`031586d0 fffff800`0340d460 : 00000000`00000000 00000000`1093f1bd fffff800`02e6ebf3 00000000`108c56ce : 0xfffff880`03158770
fffff880`031586d8 00000000`00000000 : 00000000`1093f1bd fffff800`02e6ebf3 00000000`108c56ce fffff800`02fece80 : hal+0x2f460
fffff880`031586e0 00000000`1093f1bd : fffff800`02e6ebf3 00000000`108c56ce fffff800`02fece80 00000000`00000000 : 0x0
fffff880`031586e8 fffff800`02e6ebf3 : 00000000`108c56ce fffff800`02fece80 00000000`00000000 00000000`00000000 : 0x1093f1bd
fffff880`031586f0 00000000`108c56ce : fffff800`02fece80 00000000`00000000 00000000`00000000 fffffa80`06b74800 : nt+0x6cbf3
fffff880`031586f8 fffff800`02fece80 : 00000000`00000000 00000000`00000000 fffffa80`06b74800 00001f80`002d0cc0 : 0x108c56ce
fffff880`03158700 00000000`00000000 : 00000000`00000000 fffffa80`06b74800 00001f80`002d0cc0 00000000`00000001 : nt+0x1eae80
fffff880`03158708 00000000`00000000 : fffffa80`06b74800 00001f80`002d0cc0 00000000`00000001 fffff880`031588c0 : 0x0
fffff880`03158710 fffffa80`06b74800 : 00001f80`002d0cc0 00000000`00000001 fffff880`031588c0 fffff880`03158980 : 0x0
fffff880`03158718 00001f80`002d0cc0 : 00000000`00000001 fffff880`031588c0 fffff880`03158980 fffff880`03158980 : 0xfffffa80`06b74800
fffff880`03158720 00000000`00000001 : fffff880`031588c0 fffff880`03158980 fffff880`03158980 ffffffff`fffffff7 : 0x1f80`002d0cc0
fffff880`03158728 fffff880`031588c0 : fffff880`03158980 fffff880`03158980 ffffffff`fffffff7 00000000`00000008 : 0x1
fffff880`03158730 fffff880`03158980 : fffff880`03158980 ffffffff`fffffff7 00000000`00000008 fffff800`02e84ec0 : 0xfffff880`031588c0
fffff880`03158738 fffff880`03158980 : ffffffff`fffffff7 00000000`00000008 fffff800`02e84ec0 fffff880`010c6000 : 0xfffff880`03158980
fffff880`03158740 ffffffff`fffffff7 : 00000000`00000008 fffff800`02e84ec0 fffff880`010c6000 00000000`00000000 : 0xfffff880`03158980
fffff880`03158748 00000000`00000008 : fffff800`02e84ec0 fffff880`010c6000 00000000`00000000 00000000`00000000 : 0xffffffff`fffffff7
fffff880`03158750 fffff800`02e84ec0 : fffff880`010c6000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x8
fffff880`03158758 fffff880`010c6000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt+0x82ec0
fffff880`03158760 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : fileinfo+0x1000
fffff880`03158768 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158770 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
fffff880`03158778 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x0
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
Machine Name:
*** work. ***
*** work. ***
*** work. ***
0: kd> !analyze -v
Arguments:
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
MODULE_NAME: nt
CURRENT_IRQL: 0
STACK_TEXT:
