Könnt ihr mir sagen was hier abgeschmiert ist?
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\121111-12448-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03268000 PsLoadedModuleList = 0xfffff800`034ad670
Debug session time: Sun Dec 11 23:41:55.830 2011 (UTC + 1:00)
System Uptime: 0 days 11:56:58.674
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\drivers\dxgkrnl.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa8009580010, fffff8800fd7d330, ffffffffc000009a, 4}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : nvlddmkm.sys ( nvlddmkm+cfe330 )
Followup: MachineOwner
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
FAULTING_MODULE: fffff80003268000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4ecd9f33
FAULTING_IP:
nvlddmkm+cfe330
fffff880`0fd7d330 4883ec28 sub rsp,28h
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`03747a48 fffff880`06a5e000 : 00000000`00000116 fffffa80`09580010 fffff880`0fd7d330 ffffffff`c000009a : nt+0x7cc40
fffff880`03747a50 00000000`00000116 : fffffa80`09580010 fffff880`0fd7d330 ffffffff`c000009a 00000000`00000004 : dxgkrnl+0x5d000
fffff880`03747a58 fffffa80`09580010 : fffff880`0fd7d330 ffffffff`c000009a 00000000`00000004 00000000`00000001 : 0x116
fffff880`03747a60 fffff880`0fd7d330 : ffffffff`c000009a 00000000`00000004 00000000`00000001 fffffa80`09580010 : 0xfffffa80`09580010
fffff880`03747a68 ffffffff`c000009a : 00000000`00000004 00000000`00000001 fffffa80`09580010 fffff880`06a31867 : nvlddmkm+0xcfe330
fffff880`03747a70 00000000`00000004 : 00000000`00000001 fffffa80`09580010 fffff880`06a31867 fffff880`0fd7d330 : 0xffffffff`c000009a
fffff880`03747a78 00000000`00000001 : fffffa80`09580010 fffff880`06a31867 fffff880`0fd7d330 fffffa80`093f2000 : 0x4
fffff880`03747a80 fffffa80`09580010 : fffff880`06a31867 fffff880`0fd7d330 fffffa80`093f2000 00000000`00000000 : 0x1
fffff880`03747a88 fffff880`06a31867 : fffff880`0fd7d330 fffffa80`093f2000 00000000`00000000 ffffffff`c000009a : 0xfffffa80`09580010
fffff880`03747a90 fffff880`0fd7d330 : fffffa80`093f2000 00000000`00000000 ffffffff`c000009a fffffa80`09388410 : dxgkrnl+0x30867
fffff880`03747a98 fffffa80`093f2000 : 00000000`00000000 ffffffff`c000009a fffffa80`09388410 ffffffff`f70f2e80 : nvlddmkm+0xcfe330
fffff880`03747aa0 00000000`00000000 : ffffffff`c000009a fffffa80`09388410 ffffffff`f70f2e80 fffffa80`09c98350 : 0xfffffa80`093f2000
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+cfe330
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: nvlddmkm+cfe330
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
BUCKET_ID: WRONG_SYMBOLS
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
FAULTING_IP:
nvlddmkm+cfe330
BUGCHECK_STR: 0x116
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+cfe330
