Castiel
- Okt. 2011
Hallo Leute,
nachdem ich den CCC 14.2 AMD Treiber runtergeladen habe, bekomme ich in unregelmäßigen Abständen Bluescreens. Manchmal während ich mir Videos anschaue oder Spiele zocke.
Ich habe mir mal das Programm "WhoCrashed" runtergeladen. Und folgendes kam dabei raus.
On Thu 06.03.2014 19:37:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030614-40014-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0xC483B)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8801312083B, 0xFFFFF880027E8368, 0xFFFFF880027E7BC0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
crash dump file: C:\Windows\memory.dmp
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF8801312083B, 0xFFFFF880027E8368, 0xFFFFF880027E7BC0)
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
Was genau bedeutet das ?
Mit freundlichem Gruß Castiel
