OuT.Of.rEAcH
- Feb. 2008
Ich kann mit keinem Brennprogramm mehr DVDs oder CDs brennen. Beim Brennvorgang bricht es immer ab
Hier mal mein nero LOG:
bekomme immer einen Access-Fehler
Weiß jem rat?
Code:
Windows Vista 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 8.3.13.0
Internal Version: 8, 3, 13, 0
Recorder: <TSSTcorp CDDVDW SH-S203N>Version: SB02 - HA 1 TA 0 - 8.3.13.0
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <MagicISO Virtual DVD-ROM >Version: 1.0A - HA 1 TA 1 - 8.3.13.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : MagicISOVirtual DVD-ROM 1.0A mcdbus Port 6 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S203N J: CdRom0
MagicISO Virtual DVD-ROM I: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4093MB (4191816kB)
Free physical memory: 2456MB (2515544kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.6.2009
ISO Zusammenstellung
18:38:50 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:38:50 #2 Text 0 File Isodoc.cpp, Line 6714
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:38:50 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
18:38:50 #4 Text 0 File Burncd.cpp, Line 3639
Turn on Disc-At-Once, using DVD media
18:38:50 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
18:38:50 #6 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2178719 (484:09.44, 4255MB)
18:38:50 #7 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
18:38:50 #8 Text 0 File DlgWaitCD.cpp, Line 2946
Recorder: TSSTcorp CDDVDW SH-S203N, Media type: DVD-R
Disc Manufacturer ID: <DDTRG0> <01>
Disc Application Code: 64, Disc Physical Code: 193
18:38:50 #9 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
18:38:50 #10 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2178720 (2178720) = #2178720/484:9.45
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2178720 blocks [J: TSSTcorp CDDVDW SH-S203N]
18:38:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [J: TSSTcorp CDDVDW SH-S203N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4462018560, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2178720 | 0 | 0x00
2178720 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:39:10 #12 Text 0 File SCSIPTICommands.cpp, Line 264
Error on LockVolume: Zugriff verweigert
18:39:10 #13 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:39:11 #14 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:39:11 #15 Text 0 File Burncd.cpp, Line 4430
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:39:11 #16 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
18:39:11 #17 Text 0 File Burncd.cpp, Line 4552
Cache writing successful.
18:39:11 #18 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
18:39:11 #19 Text 0 File Burncd.cpp, Line 498
Advanced Automatic Write Strategy (A-AWS) is supported. Current status is disabled
18:39:11 #20 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 4x (5.540 KB/s)
18:39:11 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:39:11 #22 Text 0 File DVDR.cpp, Line 3297
Recording mode: Sequential Recording Mode
18:39:11 #23 Text 0 File DVDR.cpp, Line 3451
Start write address at LBA 0
DVD high compatibility mode: Yes
18:39:11 #24 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0, Extended part version: 0
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
18:39:11 #25 Text 0 File DVDR.cpp, Line 3589
Reserved Track size: 2178720 (213EA0h, 4255MB) -> return code 0
18:39:11 #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
18:43:07 #27 SPTI -1046 File SCSIPassThrough.cpp, Line 214
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
CDB Data: 0x2A 00 00 00 00 40 00 00 20 00 00 00
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 30 05
Buffer x190d00c0: Len x10000
0xF0 A8 A2 D6 E5 3F 28 CA 50 6B 3F E5 A9 AC 91 B5
0x41 AC 20 09 07 28 E9 05 92 E3 51 EB 8C 52 ED 42
0xF5 2D 7C D0 1E FC 39 EA 67 E5 BD DF 7D C7 9B CC
18:43:07 #28 CDR -1046 File Writer.cpp, Line 306
Illegal disc
18:43:10 #29 Text 0 File DVDR.cpp, Line 3857
EndDAO: Last written address was 63 (3Fh)
18:43:11 #30 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 4x (5.540 KB/s)
18:43:11 #31 Text 0 File SCSIPTICommands.cpp, Line 287
18:43:15 #32 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
18:43:15 #33 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Weiß jem rat?
