oneblord
- Okt. 2020
hab einen BSOD bekommen und zwar
meine Daten
HWiNFO64 Version 7.06-4500
DESKTOP-23QVBVH -----------------------------------------------------------
[Current Computer]
Computer Name: DESKTOP-23QVBVH
[Operating System]
Operating System: Microsoft Windows 10 Professional (x64) Build 19043.1165 (21H1)
UEFI Boot: Present
Secure Boot: Not Present
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 4
Number Of Logical Processors: 8
Intel Core i7-3770 --------------------------------------------------------
[General Information]
Processor Name: Intel Core i7-3770
Original Processor Frequency: 3400.0 MHz
Original Processor Frequency [MHz]: 3400
Motherboard ---------------------------------------------------------------
[Computer]
[Motherboard]
Motherboard Model: FUJITSU D3161-A1
[PCH Features]
[BIOS]
Intel ME ------------------------------------------------------------------
[ME Host Status]
[Intel Manageability Engine Features]
[ME Firmware Capabilities]
[ME Firmware Feature State]
[ME Firmware Platform Type]
Memory --------------------------------------------------------------------
[General information]
[Current Performance Settings]
Drives --------------------------------------------------------------------
(S)ATA/ATAPI Drives -------------------------------------------------------
JAJS600M512C --------------------------------------------------------------
Drive Controller: Serial ATA 6Gb/s @ 6Gb/s
Host Controller: Intel Panther Point PCH - SATA AHCI Controller [C1]
Drive Model: JAJS600M512C
Drive Firmware Revision: S0222A0
Drive Serial Number: AA201907000000002081
Drive Capacity: 488,386 MBytes (512 GB)
Drive Capacity [MB]: 488386
Media Rotation Rate: SSD Drive (Non-rotating)
Nominal Form Factor: 2.5"
ATA Major Version Supported: ATA/ATAPI-5, ATA/ATAPI-6, ATA/ATAPI-7, ATA8-ACS, ACS-2
ATA Minor Version Supported: ACS-2 Revision 3
ATA Transport Version Supported: SATA 3.2
[Drive Geometry]
Number of Cylinders: 16383
Number of Heads: 16
Sectors Per Track: 63
Number of Sectors: 16514064
Total 32-bit LBA Sectors: 268435455
Total 48-bit LBA Sectors: 1000215216
Logical Sector Size: 512 Bytes
Cache Buffer Size: N/A
[Transfer Modes]
Sectors Per Interrupt: Total: 1, Active: 1
Max. PIO Transfer Mode: 4
Multiword DMA Mode: Total: 2, Active: -
Singleword DMA Mode: Total: -, Active: -
Ultra-DMA Mode: Total: 6 (ATA-133), Active: 5 (ATA-100)
Max. Multiword DMA Transfer Rate: 16.7 MBytes/s
Max. PIO with IORDY Transfer Rate: 16.7 MBytes/s
Max. PIO w/o IORDY Transfer Rate: 16.7 MBytes/s
Native Command Queuing: Supported, Max. Depth: 32
TRIM Command: Supported (Deterministic Read After TRIM, Words = 0)
[Device flags]
Fixed Drive: Present
Removable Drive: Not Present
Magnetic Storage: Present
LBA Mode: Supported
DMA Mode: Supported
IORDY: Supported
IORDY Disableable: Supported
[Features]
Write Cache: Present, Active
S.M.A.R.T. Feature: Present, Active
Security Feature: Present, Inactive
Removable Media Feature: Not Present, Disabled
Power Management: Present, Active
Advanced Power Management: Present, Active
Packet Interface: Not Present, Disabled
Look-Ahead Buffer: Present, Active
Host Protected Area: Present, Enabled
Power-Up In Standby: Not Suppported, Inactive
Automatic Acoustic Management: Not Suppported, Inactive
48-bit LBA: Supported, Active
Host-Initiated Link Power Management: Not Supported
Device-Initiated Link Power Management: Not Supported
In-Order Data Delivery: Not Supported
Hardware Feature Control: Not Supported
Software Settings Preservation: Supported, Enabled
NCQ Autosense: Not Supported
Link Power State Device Sleep: Not Supported
Hybrid Information Feature: Not Supported
Rebuild Assist: Not Supported
Power Disable: Not Supported
All Write Cache Non-Volatile: Not Supported
Extended Number of User Addressable Sectors: Not Supported
CFast Specification: Not Supported
NCQ Priority Information: Not Supported
Host Automatic Partial to Slumber Transitions: Not Supported
Device Automatic Partial to Slumber Transitions: Not Supported
NCQ Streaming: Not Supported
NCQ Queue Management Command: Not Supported
DevSleep to Reduced Power State: Not Supported
Out Of Band Management Interface: Not Supported
Extended Power Conditions Feature: Not Supported
Sense Data Reporting Feature: Not Supported
Free-Fall Control Feature: Not Supported
Write-Read-Verify Feature: Not Supported
[Security]
Security Feature: Supported
Security Status: Disabled
Security Locked: Disabled
Security Frozen: Enabled
Enhanced Security Erase: Supported
Sanitize Feature: Supported
Sanitize Device - Crypto Scramble: Not Supported
Sanitize Device - Overwrite: Not Supported
Sanitize Device - Block Erase: Supported
Sanitize Device - Antifreeze Lock: Not Supported
Device Encrypts All User Data: Not Supported
Trusted Computing: Not Supported
[Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.)]
[01] Raw Read Error Rate: 100/50, Worst: 100
[05] Reallocated Sector Count: 100/50, Worst: 100
[09] Power-On Hours/Cycle Count: 100/50, Worst: 100 (2264 hours / 94.3 days)
[0C] Power Cycle Count: 100/50, Worst: 100 (Data = 729,0)
[A0] Initial Bad Block Count: 100/50, Worst: 100
[A1] Current Bad Block Count: 100/50, Worst: 100 (Data = 100,0)
[A3] Max PE Cycle: 100/50, Worst: 100 (Data = 18,0)
[A4] Average Erase Count: 100/50, Worst: 100 (Data = 75879,0)
[A5] Initial Bad Block Count: 100/50, Worst: 100 (Data = 247,0)
[A6] Min W/E Cycle: 100/50, Worst: 100 (Data = 65,0)
[A7] SSD Protect Mode: 100/50, Worst: 100 (Data = 156,0)
[A8] SATA PHY Error Count: 100/50, Worst: 100 (Data = 7000,0)
[A9] Total Bad Block Count: 100/50, Worst: 100 (Data = 98,0)
[AF] Program/ECC Fail Count: 100/50, Worst: 100
[B0] Erase Fail Count: 100/50, Worst: 100
[B1] Wear Leveling Count: 100/50, Worst: 100
[B2] Used Reserved Block Count (Chip): 100/50, Worst: 100
[B5] Program Fail Count (Total): 100/50, Worst: 100
[B6] Erase Fail Count (Total): 100/50, Worst: 100
[C0] Unsafe Shutdown Count: 100/50, Worst: 100 (Data = 98,0)
[C2] Temperature 100/50, Worst: 100 (36.0 °C)
[C3] ECC Error Rate: 100/50, Worst: 100 (Data = 5292,0)
[C4] Reallocation Event Count: 100/50, Worst: 100
[C5] Current Pending Sector Count: 100/50, Worst: 100
[C6] Off-Line Uncorrectable Sector Count: 100/50, Worst: 100
[C7] SATA CRC Error Count: 100/50, Worst: 100
[E8] Available Reserved Space: 100/50, Worst: 100 (Data = 100,0)
[F1] Total Host Writes: 100/50, Worst: 100 (Data = 516345,0)
[F2] Total Host Reads: 100/50, Worst: 100 (Data = 995041,0)
[F5] Cumulative Program NAND Pages: 100/50, Worst: 100 (Data = 840312,0)
Drive Remaining Life 98%
[Device Statistics]
Lifetime Power-On Resets: 729
Power-on Hours: 2264
Logical Sectors Written: 3774448742
Logical Sectors Read: 786502981
Number of Write Commands: 66475
Number of Read Commands: 318801
Used Endurance Indicator: 2%
ASUS DRW-24D5MT -----------------------------------------------------------
Drive Model: ASUS DRW-24D5MT
Drive Firmware Revision: 2.00
Firmware Date: 2019-06-17 10:49:
Serial Number: KM4JASB5027
Device Type: DVD+R DL
[Device Capabilities]
Drive can read: CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
Drive can write: CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
Network -------------------------------------------------------------------
Intel 82579V (Lewisville) Gigabit Network Connection ----------------------
Network Card: Intel 82579V (Lewisville) Gigabit Network Connection
Vendor Description: Intel(R) 82579V Gigabit Network Connection
MAC Address: 90-1B-0E-40-14-49
[Capabilities]
Maximum Link Speed: 100 Mbps
Transmit Buffer Size: 775168 Bytes
Receive Buffer Size: 389632 Bytes
Hardware ID: PCI\VEN_8086&DEV_1503&SUBSYS_11D91734&REV_04
[Driver Information]
Driver Manufacturer: Intel Corporation
Driver Description: Intel(R) 82579V Gigabit Network Connection
Driver Provider: Microsoft
Driver Version: 12.17.10.8
Driver Date: 12-Jun-2018
DeviceInstanceId PCI\VEN_8086&DEV_1503&SUBSYS_11D91734&REV_04\3&11583659&0&C8
Location Paths PCIROOT(0)#PCI(1900)
Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter ------------
Network Card: Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter
Vendor Description: Microsoft
MAC Address: 20-0D-B0-1E-61-76
[Capabilities]
Maximum Link Speed: 54 Mbps
Transmit Buffer Size: 9 Bytes
Receive Buffer Size: 9 Bytes
UNEXPECTED_KERNEL_MODE_TRAP | 0x0000007f |
meine Daten
[Current Computer]
[Operating System]
UEFI Boot: Present
[CPU Unit Count]
[Computer]
[Motherboard]
[PCH Features]
[BIOS]
[ME Host Status]
[Drive Geometry]
Number of Heads: 16
[Transfer Modes]
[Device flags]
LBA Mode: Supported
DMA Mode: Supported
IORDY: Supported
[Features]
[Security]
[Device Statistics]
[Capabilities]
[Capabilities]
