Command and Conquer - Alarmstufe ROT 2
Yuri08
Dez. 2007
ich habe diese Woche: Command and Conquer - Alarmstufe ROT 2 installiert.
Leider kann ich das Spiel nur auf mittlerer Grafikauflösung spielen - es ruckelt wenn ich auf Grafik 1024x768 stelle.
Mein System ist WIN8,1 rest siehe Signatur.
Der Rechner hat bestimmt genug Power :-D
Ich bin mir recht sicher, dass dieses Spiel keine 3D-Beschleunigung braucht. Darum könnte man das auch in einer Windows XP VM (z.B. VirtualBox) installieren.
Ansonsten das übliche:
1. Kompatibilitätsmodus XP SP3
2. Grafische Erweiterungen deaktiveren
3. Spiel Starten und "explorer.exe" im Taskmanager Killen (kann hinterher als neuer Task wieder gestartet werden)
http://www.obelisk.ro/YuriScreenResolution.zip
laying over TCP/UDP
Along with the launch of Windows Vista in 2007, in order to play on the network, users had to install the IPX/SPX networking support manually. Following the launch of Windows 7 in 2010, IPX/SPX could no longer be installed, therefor Red Alert 2 could no longer be played on a network.
The problem can easily be fixed using "Scorpio9a's winsock.dll IPX over UDP wrapper". Just download the DLL (extract it from archive if in a zip) and place it in the game directory. Do the same for all the computers on the network who wish to play, and you'll have yourself a nice LAN party.
Scorpio9a's winsock.dll will also allow for over internet LAN play, through services like Tunngle or you very own VPN server.
I didn't include Scorpio9a's winsock.dll because of possible copyright infringement (I hope the author will allow it, until then...).
Fix game stuttering and slowdown
Using the latest game patches, after a while during network play, Red Alert 2 would start stuttering and slowdown. The problem can easily be fixed by setting VideoBackBuffer=no in ra2.ini and ra2md.ini.
Or, you can apply this fix automatically by using the "YuriScreenResolution.zip" app included in this post.
Füg mal in der RA2.ini bei [Video] die folgende Zeile ein:
VideoBackBuffer=no
Des Weiteren kannst du in der Datei auch die Auflösung höher stelle als in dem Spiel selbst zur Auswahl steht. Ich zocke es seit der Origin Aktion ebenfalls ohne Lags auf 1920x1080. Leider scheint es nach intensiver Forensuche nicht so einfach zu sein die Geschwindigkeit in der Kampagne herunterzustellen. Diese läuft zu schnell :mad:
Soweit ich weiß, basierte das Spiel aus dem Jahr 2000(!) auf Bitmap-Graphic.
Es ist somit Pre-XP Zeit (Entweder Windows 2000 oder Windows 98SE/Windows ME Kompatibel).
DirectX war da noch auf Version 7.
Es gibt da ein Tool: DXGL, welches auf normaler heutiger Hardware DX7 emuliert.
Alternativ würde ich es wirklich mal in einer VM mit eben den genannten Systemen laufen lassen.
Ich habe Windows 10 und habe mir das Spiel ebenfalls vor kurzem installiert.
Du benötigst normalerweise keine Kompatibilitätseinstellungen und ähnliches.
Suche die "ra2.ini" die du im Programmordner von Red Alert 2 findest
VideoBackBuffer=no
Und schwupps ruckelt es nicht mehr ;-)
Im Übrigen kannst du dort auch die Auflösung festlegen...Ich empfehle aber nicht mehr als 1920x1080, weil alles echt klein wird.
Das kostenlose aber offenbar problembehaftete Game hat bei mir unter Win 7 zu schweren Problemen geführt. Es lies sich einfach nicht richtig beenden, und Windows hat danach gestockt ohne Ende. Was könnte das sein?
Bei mir haben die .ini-Einträge allein nicht geholfen. Zusätzlich zu den bereits erwähnten Fixes habe ich alle .exe-Files im Spielordner in den Windows XP SP2 Kompatibilitätsmodus versetzt. Dann noch als Administrator ausführen und - was ganz wichtig zu sein schien - Modus mit reduzierten Farben auf 16 Bit gestellt. Seitdem läuft es 1A in FullHD.
Lediglich per alt-tab zurück ins Windows schalten und dann wieder zurück klappt nicht, da bleibt das Bild schwarz, nur der Ton läuft weiter. Aber wenn man das weiß und es einfach nicht tut, ists kein Problem :)
EINHEIT BEREIT
Ich spiele unter Windows 10
Ich habe im Spieleordner die ra2.ini Datei gesucht und gleich unter Video die Auflösung geändert und die Zeile "VideoBackBuffer=no" eingefügt. Das wars!
Ich meine in der RA2.ini kann man auch die Spielgeschwindigkeit ändern... Bin mir aber nicht so sicher ;)
EINHEIT BEFÖRDERT :D
Ich habs auch gratis über Origin ge"kauft" und installiert, gleich die datei YuriScreenResolution.exe
ins Spielverzeichnis ( bei mir F:\Win7Prox64Installs\Origin Games\Command and Conquer Red Alert II ) kopiert und gestartet, dann bei laufendem Origin das Spiel gestartet.
Ingame Grafik auf 1024x768 und maximum gestellt (gibt ja fast nixzum Einstellen).
Spiel lief fullscreen und ganz normal, wie früher halt aus Erinnerungen (damals halt mit 17" Monitor, der 1280*1024 hat).
Ahja, "Fix slowdowns during play" hab ich auch geklickt vorher. keine Ahnung ab dies einen Unterschied gemacht hat.
Später bin ich dann drauf gekommen, dass der Resolution Fix gar nicht aktiv war (1920*1200), denn als ich links neben der Auflösung auf den Button "Set game resolution to:" geklickt und das Spiel dann gestartet hatte, war alles viel kleiner!
Ingame trotz maximaler Scrollgeschwindigkeit (für mich) unspielbar! Und verdammt klein auch alles.
Also ich werds dann halt mit nativen 1024*768 spielen oder maximal auf 1280*960 stellen, damit ein bisschen herausgezoomt ist, man mehr sieht, scrollen aber trotzdem noch ok läuft.
Muss ich erst probieren, aber hab vor wenigen Tagen gleich mal 3 Missionen gezockt.
Rockt wie damals! :)
VideoBackBuffer=no
dieser Eintrag hat geholfen - jetzt läuft es flüssig.
ein neues Problem - wenn ich das reinschreibe wird das Spiel ca. 30-50mal so schnell.
Änderungen beim Eintrag "gamespeed" bringt keine Änderungen.
Hat wer das gleiche bzw. ne Lösung
Danke - das trifft auf alles zu.
Auf das Gefecht und auf die Kampagne.
