Controller via USB wieder entfernen aus Win10?
Caine1
Aug. 2006
Hi, ich hatte früher 2-3 verschiedene Xbox und PS4 Controller angeschlossen, kann man diese Systemeinträge löschen? LG
Ja, kann man. Aber stören sich dich bei irgendwas?
USBDeview
USBDeview is a small utility that lists all USB devices that currently connected to your computer, as well as all USB devices that you previously used. For each USB device, extended information is displayed: Device name/description, device type, serial number (for mass storage devices), the date/time that device was added, VendorID, ProductID, and more..
USBDeview also allows you to uninstall USB devices that you previously used, disconnect USB devices that are currently connected to your computer, as well as to disable and enable USB devices.
You can also use USBDeview on a remote computer, as long as you login to that computer with admin user.
USBDeview | heise Download
ich sag auch kann man, fallssie dich stören such mal bei google nach "devicecleanup" damit kannst du alle aktuell nich angeschlossenen geräte löschen
