AW_CompBase
- Nov. 2012
Ich möchte RAM
Corsair CMSX16GX3M2A1600C10
http://www.corsair.com/en/vengeance...p-memory-upgrade-kit-cmsx16gx3m2a1600c10.html
in ein Notebook Dell XPS15 L501X mit Prozessor Intel i5-560M Arrandale 1. Generation
http://ark.intel.com/products/49653/Intel-Core-i5-560M-Processor-3M-Cache-2_66-GHz
einbauen.
Geht das ?
Kann ich wenigstens 1 Modul mit 8GB einbauen.
Der Prozessor hat folgenden System Memory Support:
• One or two channels of DDR3 memory with a maximum of one SO-DIMM per channel
• Single- and dual-channel memory organization modes
• Data burst length of eight for all memory organization modes
• Memory DDR3 data transfer rates of 800 MT/s (SV, LV, ULV) and 1066 MT/s (SV,LV)
• 64-bit wide channels
• DDR3 I/O Voltage of 1.5 V
• Non-ECC, unbuffered DDR3 SO-DIMMs only
• Theoretical maximum memory bandwidth of:
— 12.8 GB/s in dual-channel mode assuming DDR3 800 MT/s
— 17.1 GB/s in dual-channel mode assuming DDR3 1066 MT/s
• 1-Gb, and 2-Gb DDR3 DRAM technologies are supported for x8 and x16 devices
• Using 2-Gb device technologies, the largest memory capacity possible is 8 GB, assuming dual-channel mode with two x8, double-sided, un-buffered, non-ECC, SO-DIMM memory configuration
• Up to 32 simultaneous open pages, 16 per channel (assuming 4 Ranks of 8 Bank Devices)
• Memory organizations:
— Single-channel modes
— Dual-channel modes - Intel® Flex Memory Technology:
Dual-channel symmetric (Interleaved)
Dual-channel asymmetric
• Command launch modes of 1n/2n
• Partial Writes to memory using Data Mask (DM) signals
• On-Die Termination (ODT)
• Intel® Fast Memory Access (Intel® FMA):
— Just-in-Time Command Scheduling
— Command Overlap
— Out-of-Order Scheduling
Muss ich dazu die BIOS-Einstellungen im CMOS-Speicher löschen ? Wie macht man das bei einem Notebook von Dell ? Im Service-Handbuch steht dazu nichts. Stützbatterie raus.
Gruss AW
einbauen.
Geht das ?
— Command Overlap
Gruss AW
