Crysis Crysis 2 Console Commands
Dikus
Nov. 2010
Hab ich durch Zufall in der Demo gefunden:
Könnte sein das man diese Dinge später in der Admin-Server MP Console gebrauchen könnte:
net_enable_tfrc = 0 []
g_battleDust_enable = 0 []
sv_bandwidth = 30000 []
g_fpDbaManagementEnable = 0 []
g_hitDeathReactions_streaming = 2 []
g_distanceForceNoIk = 35 []
g_telemetryConfig = MP []
g_telemetrySampleRatePerformance = 1 []
g_telemetrySampleRateBandwidth = 3 []
g_telemetrySampleRateMemory = 2 []
net_packetsendrate = 20 []
e_ViewDistRatio = 25 []
e_ViewDistRatioVegetation = 12 []
e_VegetationMinSize = 0.1 [REQUIRE_LEVEL_RELOAD]
pl_melee.impulses_enable = 1 []
pl_melee.angle_limit_from_behind = 70 []
pl_melee.melee_snap_angle_limit = 55 []
pl_melee.melee_snap_move_speed_multiplier = 12 []
pl_melee.melee_snap_target_select_range = 3 []
pl_melee.melee_snap_end_position_range = 1 []
pl_melee.mp_victim_screenfx_blendout_duration = 0.25 []
pl_melee.mp_victim_screenfx_duration = 0.1 []
pl_airFrictionPerk_control.triggerAutomatically = 0 []
pl_airFrictionPerk_control.fall_activation_height = 0 []
pl_impulseEnabled = 1 []
sv_AISystem = 0 [REQUIRE_APP_RESTART]
e_StreamCgfPoolSize = 28 []
aim_assistMinTurnScale = 0.5 []
aim_assistMinTurnScale_IronSight = 0.4 []
aim_assistSlowStartFadeinDistance = 1 []
aim_assistSlowStopFadeinDistance = 3 []
aim_assistSlowFalloffStartDistance = 40 []
aim_assistMaxDistance = 75 []
aim_assistMaxDistance_IronSight = 100 []
aim_assistSlowThresholdOuter = 2.5 []
aim_assistStrength = 0.7 []
aim_assistStrength_IronSight = 0.75 []
aim_assistInputForFullFollow_Ironsight = 0.2 []
aim_assistFalloffDistance = 70 []
pl_jump_maxTimerValue = 0 []
net_log = 1 []
g_spawn_vistable_numLineTestsPerFrame = 3 []
net_breakage_sync_entities = 0 []
g_breakageMinAxisInertia = 1 []
g_glassAutoShatterMinArea = 0.5 []
s_ObstructionMaxPierecability = 50 []
g_actorViewDistRatio = 255 []
controller_multiplier_x = 3 [RESTRICTEDMODE]
controller_multiplier_z = 4 [RESTRICTEDMODE]
g_playerLowHealthThreshold = 20 []
g_playerMidHealthThreshold = 60 []
p_max_entity_cells = 10000 []
e_VegetationSprites = 0 []
r_MotionBlurShutterSpeed = 0.002 []
pl_movement.speedScaleWithoutNanosuit = 1.03 []
pl_movement.sprint_SpeedScaleWithoutNanosuit = 1.61 []
pl_movement.strafe_SpeedScaleWithoutNanosuit = 0.75 []
pl_movement.sprint_timeInAirToStopSprinting = 0.5 []
pl_stealth_shotgunDamageCap = 40 []
pl_stealth_maxSpreadOnFire = 1 []
pl_jump_quickPressThresh = 0.12 []
pl_swimSpeedSprintSpeedMul = 1.5 []
pl_swimUpSprintSpeedMul = 1.5 []
pl_swimNoSuitSprintSpeedMul = 1.25 []
Ergänzung zu Grafikeinstellungen/-Probleme Hier ein Paar Lösungen für diverse "Probleme". Eine Verknüpfung von der Crysis2Demo.exe erstellen und den Pfad beliebig modifieren.
+cl_fov 65 (Sichtfeld)
+r_glow 0 (starkes hdr/überstrahlen aus, wenn man zb in den Himmel schaut)
+i_mouse_accel 0 (Mausbeschleunigung aus)
+g_SkipIntro 1 (Intro/Logos überspringen)
+r_motionblur 0 (Bewegungsunschärfe aus)
+cl_crouchToggle 0 (original ist Ducken auf AN/AUS pro Klick, wer lieber die Duckentaste gedrückt hält und beim loslassen wieder aufrecht stehen möchte (wie ich) der setzt den Wert auf 0)
+cl_zoomToggle 1 (original muss die zweite Maustaste gedrückt gelassen werden zum zoomen, wenn der Wert auf 1 ist, dann ist es auf AN/AUS pro klick)
+pl_movement.power_sprint_targetFov 65 (ranzoomen (verkleinertes Sichtfeld) beim sprinten deaktivieren)
Ein Beispiel (eigenen Spielepfad beachten! Gänsefüsschen und Leerzeichen beachten):
"C:\Program Files (x86)\Electronic Arts\Crytek\Crysis 2 Demo\bin32\Crysis2Demo.exe" +cl_fov 65 +r_glow 0 +g_SkipIntro 1 +r_motionblur 0 +cl_crouchToggle 0 +cl_zoomToggle 1 +pl_movement.power_sprint_targetFov 65
von Dr. Massive Load
Wie bist du an die Einträge gekommen? Hast du die nigel Datei entpackt?
es sollte für derartige Threads einen "bedanken" Button geben! aber dann mach ich's halt auf alt hergebrachtem Weg!
Danke!
Das war schon vorher bekannt. Bist nicht der Erste...
Bei mir klappt das Spiel mit meinem USA-Key. Allerdings funktionieren jetzt viele Commands nicht mehr :(
nicht mal r_displayinfo 1 funktioniert, obwohl dieser Command sogar in der originalen System.cfg drinnen steht.
Hab rausgefunden, dass folgende Commands auf jeden Fall funktionieren:
cl_fov = 65 (FIELD OF VIEW)
pl_movement.power_sprint_targetFov = 65 (FIELD OF VIEW BEIM SPRINTEN)
g_language = English (SPRACHE)
cl_sensitivity = 4 (MAUSGESCHWINDIGKEIT)
i_mouse_smooth = 0 (MAUSSMOOTHING)
Bringt nur nichts, denn in der Verkaufsversion funktionieren 98 % der Befehle nicht mehr. Dazu gehören auch alle möglichen Feineinstellungen der Grafik die mit "r_" beginnen.
con_restricted = 0
*Intros
g_skipIntro=1
*FieldOfView
cl_fov=65
pl_movement.power_sprint_targetFov=65
*Maus
i_mouse_accel=0
i_mouse_accel_max=0
i_mouse_smooth=0
cl_sensitivity=4
*Motionblur
r_motionblur=0
g_radialBlur=0
r_MotionBlurShutterSpeed=0
*Graphic
sys_spec_shading=3
sys_spec_gameeffects=3
sys_spec_objectdetail=3
sys_spec_particles=3
sys_spec_physics=3
sys_spec_postprocessing=3
sys_spec_shadows=3
sys_spec_sound=3
sys_spec_texture=3
sys_spec_water=3
e_shadows=1
r_driver=dx10
r_HDRRendering=1
r_SSAO=1
q_ShaderHDR=1
r_ColorGrading=1
*AntiAliasing etc.
r_UseEdgeAA=3
r_PostMSAA=2
r_TexMaxAnisotropy=16
d3d9_TextureFilter=trilinear
*Sonstiges
cl_zoomToggle=1
cl_crouchtoggle=1
r_MultiGPU=0
r_VSync=0
g_useHitSoundFeedback=1
r_Fullscreen=1
HF&GL by DeMeP :)
Meine Config ;)
Ich hoffe ihr versteht die vielen Commands ;) Ansonsten fragt einfach.
Funktionieren tun sie alle, man muss nur eine autoexec.cfg erstellen und diese reinkopieren.
Nein sie funktionieren NICHT
Sag mal was bildest du dir eig. ein, einfach dreist zu behaupten es würde doch gehen. Schau doch einfach mal selbst in die Console nachdem du dein Spiel gestartet hast, bei wievielen Befehlen das Spiel mit der Nachricht "Unknown Command" kontert.
Ganz ehrlich, es ist einfach typisch Deutsch (bin auch einer) das man einfach immer irgendwas schreibt ohne Ahung zu haben. Was sagte Dieter Nuhr? Wenn man keine Ahung hat.....
@chefcod2
Sag mal redest du mit mir?!
ALLE Befehle kennt die Console und es steht bei KEINEM meiner geposteten Befehle "Unknown Command". Also mach mal halblang und erkundige dich mal ! Du darfst auch nicht vergessen, dass du diese Befehle nicht in die System.cfg einfügen darfst, sondern eine autoexec.cfg erstellen muss.
.....einfach mal Fresse halten !
Richtig so DeMep:cool_alt:
Antworten
3
Aufrufe
3.583
Mr. Snoot
M
