300_dB
- Feb. 2004
an die progamer unter euch
ist diese config okay?
meine leitung: DSL 2000/384
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
bind "TAB" "+showscores"
bind "ENTER" "messagemode"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+duckjump"
bind "+" "sizeup"
bind "-" "sizedown"
bind "." "say ._."
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "say ...sprach der n0Ob"
bind "=" "sizeup"
bind "[" "say skill ist, wenn luck zur gewohnheit wird
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "waffe_bombe"
bind "c" "+duck"
bind "d" "+moveright"
bind "e" "+use"
bind "g" "impulse 201"
bind "l" "handtoggle"
bind "r" "+reload"
bind "s" "+back"
bind "t" "chooseteam"
bind "u" "messagemode2"
bind "w" "+forward"
bind "~" "toggleconsole"
bind "BACKSPACE" "drop"
bind "SHIFT" "+speed"
bind "F1" "kaufen_deagle;ammo2"
bind "F2" "kaufen_mp5;ammo1"
bind "F3" "kaufen_ak47;ammo1"
bind "F4" "kaufen_awm;ammo1"
bind "F5" "buy"
bind "F6" "buyammo1"
bind "F7" "buyammo2"
bind "F8" "buyequip"
bind "F9" "Restock1"
bind "F10" "Restock2"
bind "F11" "Restock3"
bind "F12" "Restock4"
bind "DEL" "Restock5"
bind "PGDN" "radio3"
bind "PGUP" "radio2"
bind "HOME" "radio1"
bind "MWHEELDOWN" "fast_invprev"
bind "MWHEELUP" "fast_invnext"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE4" "hegren_direkt"
bind "MOUSE5" "flashbang_direkt"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1"
cl_allowdownload "1"
cl_allowupload "0"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "30"
cl_corpsestay "600.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "small"
cl_crosshair_translucent "1"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "0"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "80"
cl_vsmoothing "0.05"
cl_weather "0"
con_color "255 180 30"
console "1.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "99"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0.800000"
mp_decals "300.000000"
name "delu.X.e"
net_graph "3"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0.0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0.0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "3.520000"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.750000"
volume "0.040000"
setinfo "_vgui_menus" "0"
setinfo "_ah" "0"
+mlook
+jlook
exec userconfig.cfg
unbindall
bind "+" "sizeup"
bind "-" "sizedown"
bind "." "say ._."
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind "=" "sizeup"
bind "c" "+duck"
bind "e" "+use"
bind "r" "+reload"
bind "s" "+back"
bind "w" "+forward"
bind "F5" "buy"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bottomcolor "6"
brightness "1"
cl_allowupload "0"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "30"
cl_dlmax "128"
cl_himodels "0"
cl_lc "1"
cl_lw "1"
cl_minmodels "0"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "80"
cl_weather "0"
console "1.000000"
fastsprites "0"
fps_max "99"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "1"
hud_takesshots "0"
joystick "0"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
name "delu.X.e"
net_graph "3"
net_graphpos "1"
net_scale "5"
s_a3d "0.0"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0.0"
s_leafnum "0"
s_min_distance "5"
s_numpolys "200"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
skin ""
spec_pip "0"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
voice_enable "1"
voice_modenable "1"
volume "0.040000"
setinfo "_ah" "0"
+mlook
+jlook
exec userconfig.cfg
