Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary:
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 2048
of the same hard drive for core.img. core.img is at this location and
looks in partition 85 for .
=> Grub2 (v1.99) is installed in the MBR of /dev/sdb and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
=> Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdc.
sda1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Debian GNU/Linux 9
Boot files: /boot/grub/grub.cfg /etc/fstab
sda2: __________________________________________________________________________
File system: BIOS Boot partition
Boot sector type: Grub2's core.img
Boot sector info:
sda3: __________________________________________________________________________
File system: vfat
Boot sector type: -
Boot sector info: According to the info in the boot sector, sda3 starts
at sector 2048. But according to the info from fdisk,
sda3 starts at sector 4096.
Operating System:
Boot files: /efi/debian/grubx64.efi
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sdb1: __________________________________________________________________________
File system: btrfs
Boot sector type: -
Boot sector info:
Boot files: /etc/fstab
sdb2: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sdc1: __________________________________________________________________________
File system: vfat
Boot sector type: SYSLINUX 4.07 2013-07-25
Boot sector info: Syslinux looks at sector 30146 of /dev/sdc1 for its
second stage. SYSLINUX is installed in the /uui
directory. No errors found in the Boot Parameter Block.
Operating System:
Boot files: /boot/grub/menu.lst
sdc4: __________________________________________________________________________
File system: iso9660
Boot sector type: Grub2 (v1.99)
Boot sector info: Grub2 (v1.99) is installed in the boot sector of sdc4
and looks at sector 0 of the same hard drive for
core.img, but core.img can not be found at this
location.
Operating System:
============================ Drive/Partition Info:
Drive: sda _____________________________________________________________________
Disk /dev/sda: 477 GiB, 512110190592 bytes, 1000215216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1 1,000,215,215 1,000,215,215 ee GPT
GUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System
/dev/sda1 1,083,392 414,703,615 413,620,224 Data partition (Linux)
/dev/sda2 2,048 4,095 2,048 BIOS Boot partition
/dev/sda3 4,096 1,083,391 1,079,296 EFI System partition
/dev/sda5 967,489,536 1,000,214,527 32,724,992 Swap partition (Linux)
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
/dev/sdb1 2,048 1,936,738,303 1,936,736,256 83 Linux
/dev/sdb2 1,936,738,304 1,953,523,711 16,785,408 82 Linux swap / Solaris
Drive: sdc _____________________________________________________________________
Disk /dev/sdc: 7,4 GiB, 7897874432 bytes, 15425536 sectors
Disklabel type: dos
/dev/sdc1 * 2,048 15,425,535 15,423,488 c W95 FAT32 (LBA)
/dev/sdc4 32,274 72,489 40,216 0 Empty
/dev/sdc1 overlaps with /dev/sdc4
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/nvme0n1
/dev/sda1 c78da6ea-e9cc-43da-84a2-e5baec08764d ext4
/dev/sda2
/dev/sda3 5905-B4CB vfat EFI
/dev/sda5 494bedca-4127-4185-b18e-18eecace3ad7 swap
/dev/sdb1 db879628-1284-4cd7-9672-1e3f203743e1 btrfs
/dev/sdb2 92dab836-e7e2-49a4-ba50-00b3f74c8311 swap
/dev/sdc1 161E-2C61 vfat UUI
/dev/sdc4 2018-11-01-16-41-09-00 iso9660 ISOIMAGE
================================ Mount points:
Device Mount_Point Type Options
/dev/sda1 / ext4 (rw,relatime,errors=remount-ro,data=ordered)
=========================== sda1/boot/grub/grub.cfg:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gptinsmod ext2
set root='hd0,gpt1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint
baremetal=ahci0,gpt1 c78da6ea-e9cc-43da-84a2-e5baec08764d
else
search --no-floppy --fs-uuid --set=root c78da6ea-e9cc-43da-84a2-e5baec08764d
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=de_DE
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
else
fi
insmod png
if background_image /usr/share/desktop-base/softwaves-theme/grub/grub-4x3.png; then
set color_normal=white/black
set color_highlight=black/white
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
menuentry 'Debian GNU/Linux' --class debian --class gnu-linux --class gnu --class os
$menuentry_id_option 'gnulinux-simple-c78da6ea-e9cc-43da-84a2-e5baec08764d' {
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1 c78da6ea-e9cc-43da-84a2-e5baec08764d
else
e5baec08764d
fi
echo 'Linux 4.9.0-8-amd64 wird geladen ...'
linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=c78da6ea
e9cc-43da-84a2-e5baec08764d ro quiet
echo 'Initiale Ramdisk wird geladen ...'
initrd /boot/initrd.img-4.9.0-8-amd64
submenu 'Erweiterte Optionen für Debian GNU/Linux' $menuentry_id_option 'gnulinux
advanced-c78da6ea-e9cc-43da-84a2-e5baec08764d' {
menuentry 'Debian GNU/Linux, mit Linux 4.9.0-8-amd64' --class debian --class
gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.0-8-amd64-advanced
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1 c78da6ea-e9cc-43da-84a2
e5baec08764d
else
fi
root=UUID=c78da6ea-e9cc-43da-84a2-e5baec08764d ro quiet
menuentry 'Debian GNU/Linux, with Linux 4.9.0-8-amd64 (recovery mode)' -
class debian --class gnu-linux --class gnu --class os $menuentry_id_option'gnulinux-4.9.0-8-amd64-recovery-c78da6ea-e9cc-43da-84a2-e5baec08764d' {
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
e5baec08764d
else
fi
root=UUID=c78da6ea-e9cc-43da-84a2-e5baec08764d ro single
menuentry 'Debian GNU/Linux, mit Linux 4.9.0-7-amd64' --class debian --class
gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.0-7-amd64-advanced
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
e5baec08764d
else
fi
echo 'Linux 4.9.0-7-amd64 wird geladen ...'
linux /boot/vmlinuz-4.9.0-7-amd64
initrd /boot/initrd.img-4.9.0-7-amd64
menuentry 'Debian GNU/Linux, with Linux 4.9.0-7-amd64 (recovery mode)' -
'gnulinux-4.9.0-7-amd64-recovery-c78da6ea-e9cc-43da-84a2-e5baec08764d' {
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt1'
if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 -
e5baec08764d
else
fi
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda1/etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installationUUID=c78da6ea-e9cc-43da-84a2-e5baec08764d / ext4 errors=remount-ro 0
1
# swap was on /dev/sda5 during installation
UUID=494bedca-4127-4185-b18e-18eecace3ad7 none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
=================== sda1: Location of files loaded by Grub:
GiB - GB File Fragment(s)
=============================== sdb1/etc/fstab:
1
=========================== sdc1/boot/grub/menu.lst:
# This Menu created with Universal USB Installer https://www.pendrivelinux.com
default 0
timeout 0
color NORMAL HIGHLIGHT HELPTEXT HEADING
foreground=FFFFFF
background=000000
title Boot swdl
set ISO=/uui/super_grub2_disk_hybrid_2.02s10.iso
find --set-root %ISO%
parttype (hd0,3) | set check=
set check=%check:~-5,4%
if "%check%"=="0x00" partnew (hd0,3) 0 0 0
if NOT "%check%"=="0x00" echo ERROR: Fourth partion table is not empty, please delete
it if you wish to use this method && pause --wait=5 && configfile /boot/grub/menu.lst
partnew (hd0,3) 0x00 %ISO%
map %ISO% (0xff)
map --hookroot (0xff)
chainloader (0xff)
=================== sdc1: Location of files loaded by Grub:
=========================== sdc4/boot/grub/grub.cfg:
# Super Grub Disk - grub.cfg
# Copyright (C) 2009,2010,2011,2012,2013,2014,2015 Adrian Gibanel Lopez.
# Super Grub Disk is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# Super Grub Disk is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with Super Grub Disk. If not, see <http://www.gnu.org/licenses/>.
insmod datehook
set sg2d_directory="${config_directory}/sgd"
export sg2d_directory
set afd_directory="${config_directory}"
export afd_directory
if [ "$MONTH" -eq "4" -a "$DAY" -eq "1" ] ; then
configfile "${afd_directory}/afd2012.cfg"
else
configfile "${sg2d_directory}/main.cfg"
fi
=================== sdc4: Location of files loaded by Grub:
=============================== StdErr Messages:
cat: /tmp/BootInfo-NTN4XeYY/Tmp_Log: Datei oder Verzeichnis nicht gefundencat: /tmp/BootInfo-NTN4XeYY/Tmp_Log: Datei oder Verzeichnis nicht gefunden
