~ $ sudo smartctl -a /dev/sdh
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-102-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WCC7K5YL7D70
LU WWN Device Id: 5 0014ee 20fedf2a6
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Apr 17 13:43:22 2024 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (45000) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 478) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 227 168 021 Pre-fail Always - 3616
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 168
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 039 039 000 Old_age Always - 44679
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 145
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 140
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 6372
194 Temperature_Celsius 0x0022 111 097 000 Old_age Always - 39
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 44678 -
# 2 Short offline Completed without error 00% 44442 -
# 3 Short offline Completed without error 00% 25018 -
# 4 Short offline Completed without error 00% 24948 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
~ $ sudo smartctl -a /dev/sdm
Serial Number: WD-WCC7K0VK6VPS
LU WWN Device Id: 5 0014ee 2ba99298b
Local Time is: Wed Apr 17 13:43:44 2024 CEST
was never started.
been run.
data collection: (45660) seconds.
command.
power-saving mode.
recommended polling time: ( 484) minutes.
3 Spin_Up_Time 0x0027 245 162 021 Pre-fail Always - 2733
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 174
9 Power_On_Hours 0x0032 043 043 000 Old_age Always - 42280
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 146
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 141
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 6529
194 Temperature_Celsius 0x0022 112 098 000 Old_age Always - 38
No Errors Logged
# 1 Extended offline Completed without error 00% 42280 -
# 2 Short offline Completed without error 00% 42044 -
# 3 Short offline Completed without error 00% 22630 -
# 4 Short offline Completed without error 00% 22560 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
~ $ sudo smartctl -a /dev/sdl
Serial Number: WD-WCC7K7VYNS5S
LU WWN Device Id: 5 0014ee 20fee1af3
Local Time is: Wed Apr 17 13:43:56 2024 CEST
was never started.
been run.
data collection: (44400) seconds.
command.
power-saving mode.
recommended polling time: ( 471) minutes.
3 Spin_Up_Time 0x0027 242 166 021 Pre-fail Always - 2875
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 169
9 Power_On_Hours 0x0032 044 044 000 Old_age Always - 41027
193 Load_Cycle_Count 0x0032 187 187 000 Old_age Always - 40775
194 Temperature_Celsius 0x0022 114 100 000 Old_age Always - 36
No Errors Logged
# 1 Extended offline Completed without error 00% 41026 -
# 2 Short offline Completed without error 00% 40790 -
# 3 Short offline Completed without error 00% 27415 -
# 4 Short offline Completed without error 00% 27345 -
# 5 Short offline Completed without error 00% 27252 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
~ $ sudo smartctl -a /dev/sdr
Device Model: WDC WD40EFZX-68AWUN0
Serial Number: WD-WX32D819VVCY
LU WWN Device Id: 5 0014ee 269dc4a4d
Firmware Version: 81.00B81
Device is: Not in smartctl database [for details use: -P showall]
Local Time is: Wed Apr 17 13:44:00 2024 CEST
was never started.
been run.
data collection: (40500) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
power-saving mode.
recommended polling time: ( 430) minutes.
3 Spin_Up_Time 0x0027 224 224 021 Pre-fail Always - 3800
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 129
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18893
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 127
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 103
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3488
No Errors Logged
# 1 Extended offline Completed without error 00% 18890 -
# 2 Extended offline Interrupted (host reset) 10% 18701 -
# 3 Short offline Completed without error 00% 18691 -
# 4 Short offline Completed without error 00% 46 -
Selective Self-tests/Logging not supported
~ $ sudo smartctl -a /dev/sds
Serial Number: WD-WXB2D71HTCJ6
LU WWN Device Id: 5 0014ee 2bf248eba
Local Time is: Wed Apr 17 13:44:06 2024 CEST
was never started.
been run.
data collection: (41280) seconds.
command.
power-saving mode.
recommended polling time: ( 438) minutes.
3 Spin_Up_Time 0x0027 233 222 021 Pre-fail Always - 3316
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 148
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18904
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 128
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 104
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 7919
194 Temperature_Celsius 0x0022 116 097 000 Old_age Always - 34
No Errors Logged
# 1 Extended offline Completed without error 00% 18902 -
# 2 Extended offline Interrupted (host reset) 10% 18712 -
# 3 Short offline Completed without error 00% 18703 -
~ $ sudo badblocks -sv /dev/sdh1
Checking blocks 0 to 3907013463
Checking for bad blocks (read-only test): done
Pass completed, 0 bad blocks found. (0/0/0 errors)
~ $ sudo badblocks -sv /dev/sdl1
~ $ sudo badblocks -sv /dev/sdm1
~ $ sudo badblocks -sv /dev/sds1
~ $ sudo badblocks -sv /dev/sdr1
