Hi my pc.
9900K stock turbo 4.7 . All auto settings in bios. VOLTAGE on AUTO.
Noctua NH-D15 .Temps 60-70C
2x16 GB DDR4 GSKILL 3000 XMP
Corsair 850RmX
Aorus 2080 Ti Xtreme , no oc,stock.
All stress tests passing fine. I dont have any crashes in game.
But few days ago, i go out to work, and i left running game BF 5. When i back,game was running 13 hours,and in 14 hour ( it was 3 am ) it crashed to desktop. Event viewer nothing said. No error message,no display crash. Just exit to desktop.
Game just was on 14 hours,and after moment it go to desktop withour error message. I dont touch anything,game was in campaign mode,when character is standing on the same place.
Now i am testing again and see if i can reproduce, but i cant. I am currently on 100 hour and not crashed again.
LOG:
It happened once after 14 hours be in game.
APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_ FAILURE_PROBLEM_CLASS: APPLICATION_FAULT FAILURE_SYMBOL_NAME: bfv.exe!UnknownEXCEPTION_RECORD: (.exr -1) ExceptionAddress: 0000000145de184d (bfv+0x0000000005de184d) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000 NumberParameters: 2 Parameter[0]: 0000000000000000 Parameter[1]: 0000000000000038 Attempt to read from address 0000000000000038 DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_bfv.exe!Unknown
BUCKET_ID: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_bfv+5de184d
Somebody said:" "Try to slightly increase your DRAM Voltage (something between +0,015v and +0,050v)! I would bet that the problem is solved after that. I saw a few users before having exact the same problem with the Hero XI and G.Skill Ram as u. Please inform us if it worked!"
But i run memtest86 8.2 for 4 passes no errors, and RAM TEST overnight no errors.
Thx
Corsair 850RmX
LOG:
Thx
