Doom [DOOM] Unhandled Exception
Bierdeife
Feb. 2014
zum dritten Mal erhalte ich jetzt eine "Unhandled Exception"-Fehlermeldung während ich DOOM spiele.
Hier Fehlermeldung #3:
Callstack Function(desc) Line Bytes File Process Address
wglewIsSupported() ... + 0x59b719a6 DOOMx64.exe
wglewIsSupported() ... + 0x59b69bcb DOOMx64.exe
wglewIsSupported() ... + 0x59b72ab9 DOOMx64.exe
wglewIsSupported() ... + 0x59b72fd8 DOOMx64.exe
wglewIsSupported() ... + 0x59b51d39 DOOMx64.exe
wglewIsSupported() ... + 0x59b2bd09 DOOMx64.exe
wglewIsSupported() ... + 0x59b21f7b DOOMx64.exe
wglewIsSupported() ... + 0x59b3dd00 DOOMx64.exe
wglewIsSupported() ... + 0x59b19be8 DOOMx64.exe
wglewIsSupported() ... + 0x59b1bce1 DOOMx64.exe
GetGameSystemInterface() ... + 0x59850ddd DOOMx64.exe
BaseThreadInitThunk() ... + 0x566b8102 KERNEL32.DLL
RtlUserThreadStart() ... + 0x58f1c5b4 ntdll.dll
Register Info
EDI: 0x00000000502AD200 ESI: 0x00000000502AD290 EAX: 0x000039180000100C
EBX: 0x00000000502AD250 ECX: 0x0000391800001000 EDX: 0x0000000000010000
EIP: 0x0000000159B719A6 EBP: 0x0000391800011000 SegCs: 0x0000000000000033
EFlags: 0x0000000000010287 ESP: 0x00000000079BFC40 SegSs: 0x000000000000002B
Exception Info
ExpCode: 0xC0000005 (Access Violation)
ExpFlags: 0
ExpAddress: 0x0000000159B719A6
Build & Runtime Info
User:
Version: 20160526-223240-denim-purple
File Path: C:\Program Files (x86)\Steam\steamapps\common\DOOM\DOOMx64.exe
System Time: 6/26/2016 18:34:46
Build String: 20160526-223240-denim-purple
VT File Path:
VMTR Override: generated/pagefiles
Launch Command: "C:\Program Files (x86)\Steam\steamapps\common\DOOM\DOOMx64.exe" +com_skipIntroVideo 1
Memory Info
In Use: 42%
MB Physical RAM: 16334
MB Physical Free: 9412
MB Paging File: 19278
MB Paging Free: 9395
MB User Address: 134217728
MB User Free: 134211802
CPU Info
Num Packages: 1
Num Cores: 4
Num Logical: 8
CPU ID: Generic
CPU MHz: 3299
Kennt sich damit jemand aus und kann mir sagen, welchen Fehler man herauslesen kann?
Das scheint eine Exception von OpenGL zu sein. Grafikkartentreiber aktuell? Temperaturen der Grafikkarte? Bissl mehr Info bitte...
greetz
hroessler
Sorry, bei so wenig Eigeninitiative steige ich aus. Welches System? Welche Grafikkarte? Welches OS? Himmel Poppo und Nähgarn! Wieso glauben alle, die CBler können Hellsehen...
@Edit: Und einfach raus! Das muss ja sehr von interesse sein. Ich klink mich aus...
greetz
hroessler
Er hat doch Eigeninitiative schon im Start Post gezeigt indem er den Fehler aufgelistet hat + Details zum Fehler. Das dass System nicht sofort gelistet wurde ist natürlich doof kann aber auch vergessen worden sein oder der TE hat schlicht nicht dran gedacht das dass wichtig ist. Nicht jeder weiß das die dazugehörige Hardware wichtig ist um einen Fehler festzustellen, es gibt Leute für die ist ein PC ein PC. Die machen keine unterscheide zwischen der Hardware.
@ TE, schau mal ob im Gerätemanager alle Treiber installiert sind, müsste dann so aussehen nur ohne Ausrufezeichen oder Fragezeichen:
Da es sich wie angemerkt wohl um einen open gl Fehler handelt, würde ich den Grafikkarten Treiber mit der neuesten Version von DDU entfernen und den aktuellsten Nvidia Treiber installieren.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Neueste Version von DDU steht unten gelistet.
Ich habe einfach nicht daran gedacht, tut mir leid.
Bei mir ist ein Gerät mit Ausrufezeichen gekennzeichnet. Ich weiß abe nicht, um welches Gerät es sich handelt. Ich habe zwei Screenshots angehängt.
Der Grafikkartentreiber ist der aktuellste, da ich das System neu aufgesetzt habe. Soll ich ihn trotzdem einmal komplett entfernen und neu installieren?
Würde ich einfach machen, schaden tut es nicht. Hast du von deinem Mainboard alle wichtigen Treiber runtergeladen und installiert? Würde ich wenn noch nicht gemacht einfach mal machen, einfach nach deinem Mainboard googlen und vom Board Hersteller die aktuellsten Treiber für Chipsatz, Sata, Audio, USB3 runterladen und installieren.
Nein, habe ich nicht. Vielleicht liegt es daran? Welche Treiber sind nötig?
Nr 1, 2, 3, 5 und 7. Der Rest unten sind nur tools die du nicht brauchst.
Den Vga brauchste nicht weil dein Prozessor keine Igpu hat.
Danke, ich hatte bis jetzt keine Fehlermeldung mehr! Wahrscheinlich lag es wohl wirklich an einem der Treiber.
