* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800030d5d00, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330d100
GetUlongFromAddress: unable to read from fffff8000330d1c0
0000000000000000 Nonpaged pool
CURRENT_IRQL: 2
FAULTING_IP:
nt!KiIdleLoop+90
fffff800`030d5d00 0000 add byte ptr [rax],al
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: System
TAG_NOT_DEFINED_c000000f: FFFFF88002F93FB0
TRAP_FRAME: fffff88002f8cbf0 -- (.trap 0xfffff88002f8cbf0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000004
rdx=0000000000187000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030d5d00 rsp=fffff88002f8cd80 rbp=00000000000000c0
r8=fffffa8003c770c8 r9=0000000000000000 r10=fffffffffffffffb
r11=fffffa8004166c58 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
nt!KiIdleLoop+0x90:
fffff800`030d5d00 0000 add byte ptr [rax],al ds:00000000`00000000=??
Resetting default scope
MISALIGNED_IP:
nt!KiIdleLoop+90
LAST_CONTROL_TRANSFER: from fffff800030dd569 to fffff800030ddfc0
STACK_TEXT:
nt!KeBugCheckEx
nt!KiBugCheckDispatch
nt!KiPageFault
nt!KiIdleLoop
SYMBOL_NAME: nt!KiIdleLoop+90
IMAGE_NAME: hardware
MODULE_NAME: hardware
FAILURE_BUCKET_ID: X64_IP_MISALIGNED
