Einige Probleme beim Firefox unter Win 7
Stefan99
Banned
Jan. 2021
hallo
sehr oft bei einigen Seiten wenn ich z.b ein Ticket kaufe oder bei anderen Seiten werde ich weiter geleitet zu
One last step​
For the extension to execute external commands (start the external download manager for instance and send links to it) one extra step is required. Please download, unzip and install this minimal native client to allow the extension to communicate with the external side.
  • Click here to download the ZIP package for your operating system or click here to browse all available download options.
  • Extract the downloaded package into a local directory
  • Now double-click the install.bat file
This extension only integrates your browser with the external download manager. You need to have the actual download manager for the extension to operate.
The installer script copies a few files to two different locations for your browser to be able to detect this native client. If you already have NodeJS in your system, the installed version of NodeJS will be used. So please make sure you have an up-to-date version of NodeJS installed. If you don't have this application, the included portable version will be used. Read more here.
To completely remove this native client, run uninstall.bat.
To check the native client's accessibility, click on the "Check Connection" button. If you still get this page even when the "Check Button" reports successful connection, it means the application cannot be accessed (application's path is not correct in the options page). If the path to the executable is correct and the native client is connected, you can debug the connection by enabling console logs.
There is no need for administration permission for the native client to operate.
Installation Guide:
wer kennt das?
Da wir irgendein Addon rum fummeln. Denn Firefox mal im Safemmodus starten. Wenn es dann klappt, bei den Addons aufräumen.
Reaktionen: piepenkorn
Jo, klingt nach add ons evtl mal die ganzen setting von Firefox durschauen und mal unter win Programme und Funktionen schauen ob Dreck mit in der Liste steht der sich installiert hat?
Und Windows 7 nicht mehr ins Internet lassen
Reaktionen: netzgestaltung, adAstra, tha_mos und 5 andere
Der Fehler kommt vom 'Open In' addon (siehe links zur Installationsvideo am Ende des Beitrags)
