Ich weiß jetzt nicht genau, welche Datei davon, hier mal "Services"
# Copyright (c) 1993-1999 Microsoft Corp.
# Diese Datei enthält die Portnummern für bekannte Dienste gemäß IANA.
# Format:
# <Dienstname> <Portnummer>/<Protokoll> [Alias...] [#<Kommentar>]
echo 7/tcp
echo 7/udp
discard 9/tcp sink null
discard 9/udp sink null
systat 11/tcp users #Active users
daytime 13/tcp
daytime 13/udp
qotd 17/tcp quote #Quote of the day
qotd 17/udp quote #Quote of the day
chargen 19/tcp ttytst source #Character generator
chargen 19/udp ttytst source #Character generator
ftp-data 20/tcp #FTP, data
ftp 21/tcp #FTP. control
telnet 23/tcp
smtp 25/tcp mail #Simple Mail Transfer Protocol
time 37/tcp timserver
time 37/udp timserver
rlp 39/udp resource #Resource Location Protocol
nameserver 42/tcp name #Host Name Server
nameserver 42/udp name #Host Name Server
nicname 43/tcp whois
domain 53/tcp #Domain Name Server
domain 53/udp #Domain Name Server
bootps 67/udp dhcps #Bootstrap Protocol Server
bootpc 68/udp dhcpc #Bootstrap Protocol Client
tftp 69/udp #Trivial File Transfer
gopher 70/tcp
finger 79/tcp
http 80/tcp www www-http #World Wide Web
kerberos 88/tcp krb5 kerberos-sec #Kerberos
kerberos 88/udp krb5 kerberos-sec #Kerberos
hostname 101/tcp hostnames #NIC Host Name Server
iso-tsap 102/tcp #ISO-TSAP Class 0
rtelnet 107/tcp #Remote Telnet Service
pop2 109/tcp postoffice #Post Office Protocol - Version 2
pop3 110/tcp #Post Office Protocol - Version 3
sunrpc 111/tcp rpcbind portmap #SUN Remote Procedure Call
sunrpc 111/udp rpcbind portmap #SUN Remote Procedure Call
auth 113/tcp ident tap #Identification Protocol
uucp-path 117/tcp
nntp 119/tcp usenet #Network News Transfer Protocol
ntp 123/udp #Network Time Protocol
epmap 135/tcp loc-srv #DCE endpoint resolution
epmap 135/udp loc-srv #DCE endpoint resolution
netbios-ns 137/tcp nbname #NETBIOS Name Service
netbios-ns 137/udp nbname #NETBIOS Name Service
netbios-dgm 138/udp nbdatagram #NETBIOS Datagram Service
netbios-ssn 139/tcp nbsession #NETBIOS Session Service
imap 143/tcp imap4 #Internet Message Access Protocol
pcmail-srv 158/tcp #PCMail Server
snmp 161/udp #SNMP
snmptrap 162/udp snmp-trap #SNMP trap
print-srv 170/tcp #Network PostScript
bgp 179/tcp #Border Gateway Protocol
irc 194/tcp #Internet Relay Chat Protocol
ipx 213/udp #IPX over IP
ldap 389/tcp #Lightweight Directory Access Protocol
https 443/tcp MCom
https 443/udp MCom
microsoft-ds 445/tcp
microsoft-ds 445/udp
kpasswd 464/tcp # Kerberos (v5)
kpasswd 464/udp # Kerberos (v5)
isakmp 500/udp ike #Internet Key Exchange
exec 512/tcp #Remote Process Execution
biff 512/udp comsat
login 513/tcp #Remote Login
who 513/udp whod
cmd 514/tcp shell
syslog 514/udp
printer 515/tcp spooler
talk 517/udp
ntalk 518/udp
efs 520/tcp #Extended File Name Server
router 520/udp route routed
timed 525/udp timeserver
tempo 526/tcp newdate
courier 530/tcp rpc
conference 531/tcp chat
netnews 532/tcp readnews
netwall 533/udp #For emergency broadcasts
uucp 540/tcp uucpd
klogin 543/tcp #Kerberos login
kshell 544/tcp krcmd #Kerberos remote shell
new-rwho 550/udp new-who
remotefs 556/tcp rfs rfs_server
rmonitor 560/udp rmonitord
monitor 561/udp
ldaps 636/tcp sldap #LDAP over TLS/SSL
doom 666/tcp #Doom Id Software
doom 666/udp #Doom Id Software
kerberos-adm 749/tcp #Kerberos administration
kerberos-adm 749/udp #Kerberos administration
kerberos-iv 750/udp #Kerberos version IV
kpop 1109/tcp #Kerberos POP
phone 1167/udp #Conference calling
ms-sql-s 1433/tcp #Microsoft-SQL-Server
ms-sql-s 1433/udp #Microsoft-SQL-Server
ms-sql-m 1434/tcp #Microsoft-SQL-Monitor
ms-sql-m 1434/udp #Microsoft-SQL-Monitor
wins 1512/tcp #Microsoft Windows Internet Name Service
wins 1512/udp #Microsoft Windows Internet Name Service
ingreslock 1524/tcp ingres
l2tp 1701/udp #Layer Two Tunneling Protocol
pptp 1723/tcp #Point-to-point tunnelling protocol
radius 1812/udp #RADIUS authentication protocol
radacct 1813/udp #RADIUS accounting protocol
nfsd 2049/udp nfs #NFS server
knetd 2053/tcp #Kerberos de-multiplexor
man 9535/tcp #Remote Man Server
________________
"Protocol"
# Diese Datei enthält die Internetprotokolle gemäß
# RFC 1700 (Assigned Numbers).
# Bearbeiten Sie diese Datei mit einem ASCII-Editor.
# Format:
# <Protokollname> <Nummer> [Alias...] [#<Kommentar>]
ip 0 IP # Internet Protocol
icmp 1 ICMP # Internet Control Message Protocol
ggp 3 GGP # Gateway-Gateway Protocol
tcp 6 TCP # Transmission Control Protocol
egp 8 EGP # Exterior Gateway Protocol
pup 12 PUP # PARC Universal Packet Protocol
udp 17 UDP # User Datagram Protocol
hmp 20 HMP # Host Monitoring Protocol
xns-idp 22 XNS-IDP # Xerox NS IDP
rdp 27 RDP # "Reliable Datagram" Protocol
rvd 66 RVD # MIT Remote Virtual Disk
_______________________
"Networks"
# In dieser Datei werden einzelnen Netzwerknamen die entsprechenden
# Netzwerknummern für lokale Netzwerke zugeordnet.
# Netzwerknummern werden in der punktierten Dezimalschreibweise
# angegeben.
# Format:
# <Netzwerkname> <Netzwerknummer> [Alias...] [#<Kommentar>]
# Beispiel:
# loopback 127
# standort 284.122.107
# london 284.122.108
loopback 127
________________
"hosts"
# Dies ist eine HOSTS-Beispieldatei, die von Microsoft TCP/IP
# für Windows 2000 verwendet wird.
# Diese Datei enthält die Zuordnungen der IP-Adressen zu Hostnamen.
# Jeder Eintrag muss in einer eigenen Zeile stehen. Die IP-
# Adresse sollte in der ersten Spalte gefolgt vom zugehörigen
# Hostnamen stehen.
# Die IP-Adresse und der Hostname müssen durch mindestens ein
# Leerzeichen getrennt sein.
# Zusätzliche Kommentare (so wie in dieser Datei) können in
# einzelnen Zeilen oder hinter dem Computernamen eingefügt werden,
# aber müssen mit dem Zeichen '#' eingegeben werden.
# Zum Beispiel:
# 102.54.94.97 rhino.acme.com # Quellserver
# 38.25.63.10 x.acme.com # x-Clienthost
127.0.0.1 localhost
______________-
Bei "lmhosts" stehen nur Beispiele...
# Dies ist eine Beispieldatei für LMHOSTS, wie sie von Microsoft TCP/IP
# Sie ist mit der LMHOSTS-Datei von Microsoft TCP/IP für LAN Manager 2.x
# kompatibel.
# In dieser Datei werden einzelnen IP-Adressen die entsprechenden
# Computernamen (NetBIOS-Namen) zugeordnet. Jeder Eintrag sollte aus
# einer einzelnen Zeile bestehen.
# Die IP-Adresse wird in der ersten Spalte eingetragen, gefolgt vom
# zugehörigen Computer-Namen. Die Adresse und der Computer-Name müssen
# dabei durch mindestens ein Leerzeichen oder ein Tabulatorzeichen
# getrennt sein.
# Das Zeichen "#" wird gewöhnlich Kommentaren vorangestellt. Ausnahmen
# hiervon sind die folgenden Erweiterungen:
# #PRE
# #DOM:<Domäne>
# #INCLUDE <Dateiname>
# #BEGIN_ALTERNATE
# #END_ALTERNATE
# \0xnn (Unterstützung nichtdarstellbarer Zeichen)
# Die Erweiterung "#PRE" wird nach dem Computer-Namen angegeben, wenn
# dieser Eintrag bereits zu Anfang in den Namen-Cache geladen werden
# soll. Standardmäßig werden die Einträge nicht zu Anfang in den Namen-
# Cache geladen, sie werden jedoch auch nur dann ausgewertet, wenn die
# dynamische Namensauswertung fehlschlägt.
# Die Erweiterung "#DOM:<Domäne>" wird nach dem Computer-Namen angegeben,
# wenn der Eintrag mit einer Domäne verknüpft werden soll.
# Dies wirkt sich auf das Verhalten des Computer-Suchdienstes und des
# Anmeldedienstes in der TCP/IP-Umgebung aus.
# Die Erweiterung "DOM:<Domäne>" kann zusammen mit der Erweiterung "PRE"
# für einen Eintrag angegeben werden.
# Die Angabe von "#INCLUDE <Dateiname>" veranlasst den NetBIOS Helper-
# Dienst die angegebene Datei zu suchen und sie wie eine lokale Datei
# auszuwerten. Für <Dateiname> werden UNC-Namen akzeptiert. Dadurch ist
# es möglich, eine LMHOSTS-Datei zentral auf einem Server zu verwalten.
# Befindet sich der Server außerhalb des Broadcast-Bereichs, ist eine
# Adresszuordnung für diesen Server vor der "#INCLUDE"-Anweisung not-
# wendig.
# Die Anweisungen "#BEGIN_ALTERNATE" und "#END_ALTERNATE" ermöglichen die
# Gruppierung von mehreren "#INCLUDE"-Anweisungen.
# Ist eine "INCLUDE"-Anweisung erfolgreich, werden alle weiteren
# "INCLUDE-ANWEISUNGEN" übersprungen und die Gruppe verlassen.
# Nichtdarstellbare Zeichen können im Computer-Namen enhalten sein.
# Solche Zeichen müssen als Hex-Wert in der \0xnn-Notation angegeben
# werden und zusammen mit dem NetBIOS-Namen in Anführungszeichen
# eingeschlossen werden.
# Beispiel:
# 102.54.94.97 maestro #PRE #DOM:technik # DC von "Technik"
# 102.54.94.102 "spiele \0x14" # besonderer Server
# 102.54.94.123 nordpol #PRE # Server in 3/4317
# #BEGIN_ALTERNATE
# #INCLUDE \\lokal\public\lmhosts
# #INCLUDE \\maestro\public\lmhosts
# #END_ALTERNATE
# In diesem Beispiel enthält der Server "spiele" ein Sonderzeichen
# im Namen, und der Server "nordpol" wird bereits zu Anfang in den
# Namen-Cache geladen.
# Die Adresszuordnung für den Server "maestro" wird angegeben, um diesen
# Server weiter unten in der #INCLUDE-Gruppe verwenden zu können.
# Wenn der Server "lokal" nicht verfügbar ist, wird die zentrale LMHOSTS-
# Datei auf "maestro" verwendet.
# Beachten Sie, dass die gesamte Datei bei jeder Auswertung durchsucht wird,
# einschließlich der Kommentarzeilen. Es wird daher empfohlen, die obigen
# Kommentarzeilen zu entfernen.
