ModdingEPS 12v extending line for Seasonic X series
Thank you,
I need 2x EPS 12V output to support dual cpu. However, on my power supply, there is only one 8pin(on the power supply) to 8pin (plug on mainboard) port. The additional EPS 12v connection need to connect to PCIE power output port on the powersupply (which is a 12 pin on the power supply)
and I need such a line (according to seasonic) with one connection 12pin plug on the power and the other one 8pin to plug on the mainboad. And this line need to compact the standard of eps 12v.
sorry for my poor English and German!
Do you want to order in Germany or in England/ America?
Maybe you should ask Seasonic before you order, they are really kind and can help very successfully.
For Dual CPU you should buy a cable like this: http://www.aerocooler.com/products/CBLEPS8Y_m.jpg
Right?
