counterroot
- Feb. 2005
Hallo in die Runde,
I habe ein Problem beim nutzen von wvdial unter Fedora10_beta_x64. Das System ist up2date.
Die Simkarte ist von Vodafone:
Meine /etc/wvdial.conf welche mit Fedora 9 funktioniert hat:
Die PIN wird durch ein getrenntes Script gesetzt und hat auch funktioniert unter Fedora 9.
Aber ich bekomme jetzt beim Aufruf von "wvdial":
jemand eine Idee?
pmb µatthias
Code:
[Dialer Defaults]
Modem = /dev/ttyUSB0
Baud = 460800
#Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Init1 = ATZe1
Init2 = at+cgdcont=1,"IP","web.vodafone.de"
#Init3 = at+cgqreq=1,2,4,3,9,31
Area Code =
Phone = *99***1#
Username = VFD2
Password = WAP
Ask Password = 0
Dial Command = ATDT
Stupid Mode = 1
Compuserve = 0
Force Address =
Idle Seconds = 3000
DialMessage1 =
DialMessage2 =
ISDN = 0
Auto DNS = 1
Code:
# setpin
OK - PIN accepted
# wvdial
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZe1
ATZe1
OK
--> Sending: at+cgdcont=1,"IP","web.vodafone.de"
OK
--> Modem initialized.
--> Idle Seconds = 3000, disabling automatic reconnect.
--> Sending: ATDT*99***1#
--> Waiting for carrier.
ATDT*99***1#
CONNECT HSDPA 3.6
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Wed Nov 5 11:24:34 2008
--> Pid of pppd: 19580
--> Using interface ppp0
--> pppd: 1
--> pppd: 1
--> pppd: 1
--> pppd: 1
--> pppd: 1
--> pppd: 1
--> Disconnecting at Wed Nov 5 11:24:35 2008
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
Code:
# tail --lines 10 /var/log/messages
Nov 5 11:24:34 freechip kernel: PPP generic driver version 2.4.2
Nov 5 11:24:34 freechip pppd[19580]: pppd 2.4.4 started by root, uid 0
Nov 5 11:24:35 freechip pppd[19580]: Using interface ppp0
Nov 5 11:24:35 freechip pppd[19580]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 5 11:24:35 freechip pppd[19580]: CHAP authentication succeeded
Nov 5 11:24:35 freechip kernel: PPP Deflate Compression module registered
Nov 5 11:24:35 freechip pppd[19580]: Modem hangup
Nov 5 11:24:35 freechip pppd[19580]: Connection terminated.
Nov 5 11:24:35 freechip pppd[19580]: Exit.
jemand eine Idee?
pmb µatthias
