Fedora 10 x64 - Xen Hypervisor
counterroot
Feb. 2005
Hallo in die Runde,
ich habe ein Problem mit dem XEN-Hypervisor der aktuellen Version Fedora 10_beta_x64. System ist up2date.
Wenn ich versuche den XEN-Hypervisor mit dem virt-manager zu connecten bekomme ich:
Unable to open connection to hypervisor URI 'xen:///':
<class 'libvirt.libvirtError'> internal error failed to connect to xend
Traceback (most recent call last):
File "/usr/share/virt-manager/virtManager/connection.py", line 483, in _open_thread
None], flags)
File "/usr/lib64/python2.5/site-packages/libvirt.py", line 99, in openAuth
if ret is None:raise libvirtError('virConnectOpenAuth() failed')
libvirtError: internal error failed to connect to xend
$ /etc/init.d/libvirtd status
libvirtd (pid 2740) is running...
# yum install xen*
Loaded plugins: refresh-packagekit
Setting up Install Process
Parsing package install arguments
Package xen-3.3.0-1.fc10.x86_64 already installed and latest version
Package xen-devel-3.3.0-1.fc10.x86_64 already installed and latest version
Package xen-hypervisor-3.3.0-1.fc10.x86_64 already installed and latest version
Package xen-runtime-3.3.0-1.fc10.x86_64 already installed and latest version
Package xenwatch-0.5.3-1.fc10.x86_64 already installed and latest version
Package xenner-0.46-3.fc10.x86_64 already installed and latest version
Package xen-libs-3.3.0-1.fc10.x86_64 already installed and latest version
Nothing to do
jemand eine Idee?
pmb µatthias
// EDIT 08-11-05_11-37:
# xend
ERROR Internal error: Could not obtain handle on privileged command interface (2 = No such file or directory)
File "/usr/sbin/xend", line 16, in <module>
from xen.xend.server import SrvDaemon
File "/usr/lib64/python2.5/site-packages/xen/xend/server/SrvDaemon.py", line 26, in <module>
import relocate
File "/usr/lib64/python2.5/site-packages/xen/xend/server/relocate.py", line 28, in <module>
from xen.xend import XendDomain
File "/usr/lib64/python2.5/site-packages/xen/xend/XendDomain.py", line 35, in <module>
from xen.xend import XendOptions, XendCheckpoint, XendDomainInfo
File "/usr/lib64/python2.5/site-packages/xen/xend/XendCheckpoint.py", line 20, in <module>
from xen.xend import balloon, sxp, image
File "/usr/lib64/python2.5/site-packages/xen/xend/image.py", line 44, in <module>
xc = xen.lowlevel.xc.xc()
xen.lowlevel.xc.Error: (1, 'Internal error', 'Could not obtain handle on privileged command interface (2 = No such file or directory)')
Moin moin ;)
der auszug der xendd komplett:
habe aber außerdem eher schlechte nachrichten: http://forums.fedoraforum.org/showthread.php?t=203288
Code:
$ cat /usr/sbin/xend -n
     1  #!/usr/bin/python2.5
     2  #  -*- mode: python; -*-
     3  #=======================================================================
     4  # Copyright (C) 2004 Mike Wray <mike.wray@hp.com>
     5  # Copyright (C) 2005-2006 XenSource Inc
     6  #=======================================================================
     7
     8  """Xen management daemon.
     9     Provides console server and HTTP management api.
    10
    11     The daemon should reconnect to device control interfaces
    12     and recover its state when restarted.
    13  """
    14  import sys
    15
    16  from xen.xend.server import SrvDaemon
    17
    18  def main():
    19      daemon = SrvDaemon.instance()
    20      return daemon.start()
    21
    22  if __name__ == '__main__':
    23      sys.exit(main())
pmb µatthias
»Fedora 10 will ship with Xen i686 and x86_64 DomU support enabled in the stock kernel - i.e. there is no more kernel-xen. «
Jupp, das dachte ich mir schon fast, dass auch Fedora 10 vorerst keinen Dom0 Kernel mitliefern wird. Ähnlich sieht es bei der aktuellen Ubuntu und sogar Debian Lenny / Sid aus, wo sogar schon im Sommer bekannt wurde, dass wohl kein Dom0-Kernel mehr Einzug in das nächste Release finden wird.
Was bleibt? Tja, Ich hab deswegen noch immer Debian Etch installiert .... aber das ist auf Dauer auch keine gescheite Lösung.
Ich sehe in deiner Signatur, dass du Fedora 9 mit als Dom0 laufen lässt? Bleib doch bei Fedora 9!
Ubuntu jedenfalls scheint eher auf den KVM Zug aufgesprungen zu sein - jedoch hab ich das selbst noch nicht getestet, weiß also nicht, wie sich die Performance, gerade was I/O-Geschichten anbelangt, im vergleich zu Xen schlängt.
Schaut man in die Sources von Xen (3.3.x?) rein, so stellt man schnell fest, dass es noch immer auf einen 2.6.18er Kernel hin ausgelegt ist. Also Stand von vor 2 Jahren etwa.
ja hey. das is mal ein post... Jurymitglied counterroot vergibt 100 Punkte :D.
Spaß beiseite...
Hmm... Jepps mit Fedora 9 hats nach ein paar modifikationen hingehauen.
Ich bin halt gerne einer der viel experimentiert und so wollte ich das mit Fedora 10 auch schaffen. Dacht mir halt, why not...
2.6.18... schon hart. Das ist ja Debian-Like...
danke für die Rückinfo. Hilft schonmal weiter.
gruß und schönen abend, µatthias
