085701024 ns
[ 0.252575] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.252583] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.252590] pci 0000:00:1c.0: bridge window [mem 0xf0d00000-0xf14fffff]
[ 0.252595] pci 0000:00:1c.0: bridge window [mem 0xf0400000-0xf0bfffff 64bit pref]
[ 0.252604] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.252612] pci 0000:00:1c.1: bridge window [mem 0xf0c00000-0xf0cfffff]
[ 0.252625] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.252627] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.252629] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.252631] pci_bus 0000:00: resource 7 [mem 0xdfa00000-0xfebfffff window]
[ 0.252633] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed4bfff window]
[ 0.252635] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 0.252637] pci_bus 0000:02: resource 1 [mem 0xf0d00000-0xf14fffff]
[ 0.252638] pci_bus 0000:02: resource 2 [mem 0xf0400000-0xf0bfffff 64bit pref]
[ 0.252640] pci_bus 0000:03: resource 1 [mem 0xf0c00000-0xf0cfffff]
[ 0.252801] NET: Registered protocol family 2
[ 0.253143] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes,
linear)
[ 0.253206] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear
[ 0.253430] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.253577] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.253637] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.253673] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.253763] NET: Registered protocol family 1
[ 0.253770] NET: Registered protocol family 44
[ 0.253784] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000
dffff]
[ 0.254619] PCI: CLS 64 bytes, default 64
[ 0.254681] Trying to unpack rootfs image as initramfs...
[ 0.593617] Freeing initrd memory: 84496K
[ 0.593684] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.593687] software IO TLB: mapped [mem 0xc8922000-0xcc922000] (64MB)
[ 0.594007] check: Scanning for low memory corruption every 60 seconds
[ 0.597118] Initialise system trusted keyrings
[ 0.597130] Key type blacklist registered
[ 0.597172] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[ 0.599071] zbud: loaded
[ 0.599631] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.599861] fuse: init (API version 7.31)
[ 0.599884] *** VALIDATE fuse ***
[ 0.599887] *** VALIDATE fuse ***
[ 0.600020] Platform Keyring initialized
[ 0.608332] Key type asymmetric registered
[ 0.608334] Asymmetric key parser 'x509' registered
[ 0.608350] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.608410] io scheduler mq-deadline registered
[ 0.609189] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.609275] intel_idle: MWAIT substates: 0x21120
[ 0.609277] intel_idle: v0.4.1 model 0x3A
[ 0.609535] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.610076] ACPI: AC Adapter [AC] (on-line)
[ 0.610159] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/in
put0
[ 0.610210] ACPI: Lid Switch [LID]
[ 0.610254] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/
input1
[ 0.610289] ACPI: Sleep Button [SLPB]
[ 0.610351] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.610382] ACPI: Power Button [PWRF]
[ 0.612757] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.612758] ACPI: Thermal Zone [THM0] (60 C)
[ 0.612952] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.616043] Linux agpgart interface v0.103
[ 0.619871] loop: module loaded
[ 0.620147] libphy: Fixed MDIO Bus: probed
[ 0.620148] tun: Universal TUN/TAP device driver, 1.6
[ 0.620191] PPP generic driver version 2.4.2
[ 0.620274] VFIO - User Level meta-driver version: 0.3
[ 0.620849] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.620853] ehci-pci: EHCI PCI platform driver
[ 0.621863] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.621945] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.622254] ehci-pci 0000:00:1a.0: debug port 2
[ 0.626838] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.627176] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf151a000
[ 0.627420] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 0.641174] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.641290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice=
5.04
[ 0.641293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.641295] usb usb1: Product: EHCI Host Controller
[ 0.641297] usb usb1: Manufacturer: Linux 5.4.0-26-generic ehci_hcd
[ 0.641299] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.641547] hub 1-0:1.0: USB hub found
[ 0.641562] hub 1-0:1.0: 3 ports detected
[ 0.642101] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.642112] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.642133] ehci-pci 0000:00:1d.0: debug port 2
[ 0.646037] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.646061] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf1519000
[ 0.661174] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.661281] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice=
5.04
[ 0.661284] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.661286] usb usb2: Product: EHCI Host Controller
[ 0.661288] usb usb2: Manufacturer: Linux 5.4.0-26-generic ehci_hcd
[ 0.661290] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.661544] hub 2-0:1.0: USB hub found
[ 0.661559] hub 2-0:1.0: 3 ports detected
[ 0.661922] ehci-platform: EHCI generic platform driver
[ 0.661951] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.661959] ohci-pci: OHCI PCI platform driver
[ 0.661980] ohci-platform: OHCI generic platform driver
[ 0.661995] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.662207] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.662214] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.663297] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x0
00000000000b930
[ 0.663304] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.663515] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice=
5.04
[ 0.663516] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.663518] usb usb3: Product: xHCI Host Controller
[ 0.663520] usb usb3: Manufacturer: Linux 5.4.0-26-generic xhci-hcd
[ 0.663521] usb usb3: SerialNumber: 0000:00:14.0
[ 0.663673] hub 3-0:1.0: USB hub found
[ 0.663689] hub 3-0:1.0: 4 ports detected
[ 0.664436] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.664441] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.664445] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 0.664496] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice=
5.04
[ 0.664498] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.664499] usb usb4: Product: xHCI Host Controller
[ 0.664501] usb usb4: Manufacturer: Linux 5.4.0-26-generic xhci-hcd
[ 0.664502] usb usb4: SerialNumber: 0000:00:14.0
[ 0.664627] hub 4-0:1.0: USB hub found
[ 0.664642] hub 4-0:1.0: 4 ports detected
[ 0.665531] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,
12
[ 0.667176] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.667182] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.667334] mousedev: PS/2 mouse device common for all mice
[ 0.667550] rtc_cmos 00:02: RTC can wake from S4
[ 0.667808] rtc_cmos 00:02: registered as rtc0
[ 0.667829] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.667837] i2c /dev entries driver
[ 0.667895] device-mapper: uevent: version 1.0.3
[ 0.667995] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@red
hat.com
[ 0.668022] platform eisa.0: Probing EISA bus 0
[ 0.668024] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.668025] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.668027] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.668028] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.668030] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.668031] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.668032] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.668034] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.668035] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.668037] platform eisa.0: EISA: Detected 0 cards
[ 0.668045] intel_pstate: Intel P-state driver initializing
[ 0.668324] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.668410] drop_monitor: Initializing network drop monitor service
[ 0.668589] NET: Registered protocol family 10
[ 0.668654] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/inp
ut/input3
[ 0.677824] Segment Routing with IPv6
[ 0.677862] NET: Registered protocol family 17
[ 0.677926] Key type dns_resolver registered
[ 0.678216] RAS: Correctable Errors collector initialized.
[ 0.678246] microcode: sig=0x306a9, pf=0x10, revision=0x21
[ 0.678312] microcode: Microcode Update Driver: v2.2.
[ 0.678316] IPI shorthand broadcast: enabled
[ 0.678323] sched_clock: Marking stable (677248814, 1059498)->(684290806, -5982494)
[ 0.678431] registered taskstats version 1
[ 0.678439] Loading compiled-in X.509 certificates
[ 0.680684] Loaded X.509 cert 'Build time autogenerated kernel key: b559075f1a2deb823
2ccd540ea3b0eb9fdd57b46'
[ 0.680716] zswap: loaded using pool lzo/zbud
[ 0.680794] Key type ._fscrypt registered
[ 0.680795] Key type .fscrypt registered
[ 0.688935] Key type big_key registered
[ 0.692965] Key type encrypted registered
[ 0.692969] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.692975] ima: No TPM chip found, activating TPM-bypass!
[ 0.692981] ima: Allocated hash algorithm: sha1
[ 0.692989] ima: No architecture policies found
[ 0.693004] evm: Initialising EVM extended attributes:
[ 0.693004] evm: security.selinux
[ 0.693005] evm: security.SMACK64
[ 0.693006] evm: security.SMACK64EXEC
[ 0.693006] evm: security.SMACK64TRANSMUTE
[ 0.693006] evm: security.SMACK64MMAP
[ 0.693007] evm: security.apparmor
[ 0.693007] evm: security.ima
[ 0.693008] evm: security.capability
[ 0.693008] evm: HMAC attrs: 0x1
[ 0.693358] PM: Magic number: 6:768:339
[ 0.693479] rtc_cmos 00:02: setting system clock to 2022-09-09T17:20:03 UTC (16627440
03)
[ 0.694563] Freeing unused decrypted memory: 2040K
[ 0.694924] Freeing unused kernel image memory: 2712K
[ 0.729208] Write protecting the kernel read-only data: 22528k
[ 0.729751] Freeing unused kernel image memory: 2008K
[ 0.729994] Freeing unused kernel image memory: 1196K
[ 0.740418] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.740419] x86/mm: Checking user space page tables
[ 0.750478] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.750480] Run /init as init process
[ 0.842452] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910
(first instance was on PNP0C14:00)
[ 0.842623] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910
[ 0.848169] sdhci: Secure Digital Host Controller Interface driver
[ 0.848170] sdhci: Copyright(c) Pierre Ossman
[ 0.849819] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 0.849893] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F confli
cts with OpRegion 0x0000000000000400-0x000000000000047F (\_SB.PCI0.LPC.PMIO) (20190816/u
taddress-204)
[ 0.849900] ACPI: If an ACPI driver is available for this device, you should use it i
nstead of the native driver
[ 0.849906] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F confli
cts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPC.LPIO) (20190816/u
taddress-204)
[ 0.849911] ACPI: If an ACPI driver is available for this device, you should use it i
[ 0.849912] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F confli
taddress-204)
[ 0.849919] ACPI: If an ACPI driver is available for this device, you should use it i
[ 0.849920] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F confli
taddress-204)
[ 0.849932] ACPI: If an ACPI driver is available for this device, you should use it i
[ 0.849933] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 0.852330] sdhci-pci 0000:02:00.0: SDHCI controller found [1180:e823] (rev 4)
[ 0.852937] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[ 0.857864] mmc0: SDHCI controller on PCI [0000:02:00.0] using DMA
[ 0.904802] cryptd: max_cpu_qlen set to 1000
[ 0.906572] ahci 0000:00:1f.2: version 3.0
[ 0.906835] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1 impl SATA m
ode
[ 0.906838] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 0.912926] AVX version of gcm_enc/dec engaged.
[ 0.912927] AES CTR mode by8 optimization enabled
[ 0.913905] scsi host0: ahci
[ 0.916872] scsi host1: ahci
[ 0.918599] scsi host2: ahci
[ 0.918737] scsi host3: ahci
[ 0.918830] scsi host4: ahci
[ 0.918933] scsi host5: ahci
[ 0.918992] ata1: SATA max UDMA/133 abar m2048@0xf1518000 port 0xf1518100 irq 27
[ 0.918993] ata2: DUMMY
[ 0.918994] ata3: DUMMY
[ 0.918995] ata4: DUMMY
[ 0.918995] ata5: DUMMY
[ 0.918996] ata6: DUMMY
[ 0.941710] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 0.942800] Console: switching to colour dummy device 80x25
[ 0.953079] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.953080] [drm] Driver supports precise vblank timestamp query.
[ 0.953795] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes
=io+mem:owns=io+mem
[ 0.977164] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.997165] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.006206] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice=
0.00
[ 1.006209] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.006671] hub 1-1:1.0: USB hub found
[ 1.006867] hub 1-1:1.0: 6 ports detected
[ 1.025759] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice=
0.00
[ 1.025761] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.026117] hub 2-1:1.0: USB hub found
[ 1.026203] hub 2-1:1.0: 8 ports detected
[ 1.068329] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 1.068923] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 1.070315] acpi device:00: registered as cooling_device4
[ 1.070395] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:
00/input/input6
[ 1.236454] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.237109] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1.237111] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered ou
t
[ 1.237112] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.238145] ata1.00: ATA-8: SanDisk SD5SG2256G1052E, 10.02.01, max UDMA/133
[ 1.238146] ata1.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.238890] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1.238892] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered ou
t
[ 1.238893] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.239928] ata1.00: configured for UDMA/133
[ 1.250225] scsi 0:0:0:0: Direct-Access ATA SanDisk SD5SG225 2.01 PQ: 0 ANSI
: 5
[ 1.250450] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.250557] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 1.250575] sd 0:0:0:0: [sda] Write Protect is off
[ 1.250577] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.250611] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't supp
ort DPO or FUA
[ 1.269601] sda: sda1 sda2 sda3
[ 1.270077] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.389944] fbcon: i915drmfb (fb0) is primary device
[ 1.625126] tsc: Refined TSC clocksource calibration: 2294.789 MHz
[ 1.625136] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2113fa90235, max
_idle_ns: 440795282686 ns
[ 1.625161] clocksource: Switched to clocksource tsc
[ 1.636414] psmouse serio1: synaptics: queried max coordinates: x [..5678], y [..4732
[ 1.667219] psmouse serio1: synaptics: queried min coordinates: x [1264..], y [1124..
[ 1.667234] psmouse serio1: synaptics: Your touchpad (PNP: LEN0030 PNP0f13) says it c
an support a different bus. If i2c-hid and hid-rmi are not used, you might want to try s
etting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 1.727172] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps:
0xd001a3/0x940300/0x127c00/0x0, board id: 2182, fw id: 1164733
[ 1.727189] psmouse serio1: synaptics: serio: Synaptics pass-through port at isa0060/
serio1/input0
[ 1.757244] usb 4-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.765504] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input
/input5
[ 1.778759] usb 4-2: New USB device found, idVendor=0781, idProduct=5583, bcdDevice=
1.00
[ 1.778765] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.778769] usb 4-2: Product: Ultra Fit
[ 1.778782] usb 4-2: Manufacturer: SanDisk
[ 1.778783] usb 4-2: SerialNumber: 05016124c5fd24a3170fc468efdd451bd51bc0cbb308c82188
4de1f7604bd2c05f860000000000000000000006f959d3ff0a161083558107a926e803
[ 1.782394] usb-storage 4-2:1.0: USB Mass Storage device detected
[ 1.782650] scsi host6: usb-storage 4-2:1.0
[ 1.782741] usbcore: registered new interface driver usb-storage
[ 1.783950] usbcore: registered new interface driver uas
[ 2.221794] Console: switching to colour frame buffer device 200x56
[ 2.241337] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 2.400454] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 2.595111] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/serio2/inp
ut/input7
[ 2.814918] scsi 6:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI
: 6
[ 2.815198] sd 6:0:0:0: Attached scsi generic sg1 type 0
[ 2.815549] sd 6:0:0:0: [sdb] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[ 2.816950] sd 6:0:0:0: [sdb] Write Protect is off
[ 2.816952] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 2.817591] sd 6:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't sup
port DPO or FUA
[ 2.849788] sdb: sdb1
[ 2.851415] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 58.548487] systemd[1]: Inserted module 'autofs4'
[ 58.583859] systemd[1]: systemd 245.4-4ubuntu3 running in system mode. (+PAM +AUDIT +
SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +L
Z4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 58.601299] systemd[1]: Detected architecture x86-64.
[ 58.622464] systemd[1]: Set hostname to <kubuntu>.
[ 58.622683] systemd[1]: Initializing machine ID from random generator.
[ 58.904674] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a
path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/
dbus/system_bus_socket; please update the unit file accordingly.
[ 58.942179] systemd[1]: Created slice system-modprobe.slice.
[ 58.942408] systemd[1]: Created slice User and Session Slice.
[ 58.942475] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 58.942684] systemd[1]: Set up automount Arbitrary Executable File Formats File Syste
m Automount Point.
[ 58.942717] systemd[1]: Reached target User and Group Name Lookups.
[ 58.942729] systemd[1]: Reached target Remote File Systems.
[ 58.942739] systemd[1]: Reached target Slices.
[ 58.942752] systemd[1]: Reached target Swap.
[ 58.942833] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 58.943240] systemd[1]: Listening on LVM2 poll daemon socket.
[ 58.943359] systemd[1]: Listening on Syslog Socket.
[ 58.943413] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 58.943734] systemd[1]: Listening on Journal Audit Socket.
[ 58.943821] systemd[1]: Listening on Journal Socket (/dev/log).
[ 58.943924] systemd[1]: Listening on Journal Socket.
[ 58.944035] systemd[1]: Listening on udev Control Socket.
[ 58.944120] systemd[1]: Listening on udev Kernel Socket.
[ 58.945004] systemd[1]: Mounting Huge Pages File System...
[ 58.946154] systemd[1]: Mounting POSIX Message Queue File System...
[ 58.947693] systemd[1]: Mounting Kernel Debug File System...
[ 58.949332] systemd[1]: Mounting Kernel Trace File System...
[ 58.951532] systemd[1]: Starting Journal Service...
[ 58.953012] systemd[1]: Starting Availability of block devices...
[ 58.954570] systemd[1]: Starting Set the console keyboard layout...
[ 58.956665] systemd[1]: Starting Create list of static device nodes for the current k
ernel...
[ 58.958117] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dme
ventd or progress polling...
[ 58.958194] systemd[1]: Condition check resulted in Load Kernel Module drm being skip
ped.
[ 58.996128] systemd[1]: Condition check resulted in Set Up Additional Binary Formats
being skipped.
[ 58.998108] systemd[1]: Starting Load Kernel Modules...
[ 58.999432] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 59.000673] systemd[1]: Starting udev Coldplug all Devices...
[ 59.002546] systemd[1]: Starting Uncomplicated firewall...
[ 59.004806] systemd[1]: Mounted Huge Pages File System.
[ 59.005035] systemd[1]: Mounted POSIX Message Queue File System.
[ 59.005254] systemd[1]: Mounted Kernel Debug File System.
[ 59.005459] systemd[1]: Mounted Kernel Trace File System.
[ 59.006203] systemd[1]: Finished Availability of block devices.
[ 59.050973] systemd[1]: Finished Create list of static device nodes for the current k
ernel.
[ 59.052405] systemd[1]: Finished Uncomplicated firewall.
[ 59.075066] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dme
[ 59.086689] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 59.087647] systemd[1]: Condition check resulted in Rebuild Hardware Database being s
kipped.
[ 59.087699] systemd[1]: Condition check resulted in Platform Persistent Storage Archi
val being skipped.
[ 59.088870] systemd[1]: Starting Load/Save Random Seed...
[ 59.092095] systemd[1]: Starting Create System Users...
[ 59.096467] systemd[1]: Finished Load/Save Random Seed.
[ 59.170162] systemd[1]: Finished Create System Users.
[ 59.171439] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 59.279442] systemd[1]: Finished Set the console keyboard layout.
[ 59.293112] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 59.293375] systemd[1]: Reached target Local File Systems (Pre).
[ 59.293470] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mountin
g anyway.
[ 59.294713] systemd[1]: Mounting /tmp...
[ 59.296219] systemd[1]: Starting udev Kernel Device Manager...
[ 59.309133] systemd[1]: Mounted /tmp.
[ 59.309398] systemd[1]: Reached target Local File Systems.
[ 59.309820] systemd[1]: Condition check resulted in Load AppArmor profiles being skip
ped.
[ 59.314593] systemd[1]: Starting Set console font and keymap...
[ 59.316123] systemd[1]: Starting Create final runtime dir for shutdown pivot root...
[ 59.319486] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 59.320964] systemd[1]: Starting Load AppArmor profiles managed internally by snapd..
[ 59.321045] systemd[1]: Condition check resulted in Store a System Token in an EFI Va
riable being skipped.
[ 59.321205] systemd[1]: Condition check resulted in Commit a transient machine-id on
disk being skipped.
[ 59.322130] systemd[1]: Finished Create final runtime dir for shutdown pivot root.
[ 59.350120] systemd[1]: Started Journal Service.
[ 59.402389] systemd-journald[1125]: Received client request to flush runtime journal.
[ 59.481287] lp: driver loaded but no devices found
[ 59.524110] ppdev: user-space parallel port driver
[ 62.246692] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl time
r
[ 62.246694] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 62.246695] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 62.246696] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 62.577703] Non-volatile memory driver v1.3
[ 62.838712] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[ 62.838713] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 62.838714] thinkpad_acpi: ThinkPad BIOS G6ETC1WW (2.81 ), EC G6HT24WW
[ 62.838715] thinkpad_acpi: Lenovo ThinkPad X1 Carbon, model 34602SG
[ 62.841818] thinkpad_acpi: radio switch found; radios are enabled
[ 62.841838] thinkpad_acpi: Tablet mode switch found (type: MHKG), currently in laptop
mode
[ 62.841876] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness contr
ol, supported by the ACPI video driver
[ 62.841877] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 62.860283] thinkpad_acpi: Standard ACPI backlight interface available, not loading n
ative one
[ 62.870436] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[ 62.870444] battery: new extension: ThinkPad Battery Extension
[ 62.870524] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/in
put8
[ 63.115953] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_
bind_ops [i915])
[ 63.171078] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 63.179661] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 63.368395] Intel(R) Wireless WiFi driver for Linux
[ 63.368397] Copyright(c) 2003- 2015 Intel Corporation
[ 63.368662] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 63.432547] kvm: disabled by bios
[ 63.445813] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (
0x14/0x0/0x0/0x0/0x0) type:speaker
[ 63.445816] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0
[ 63.445818] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 63.445820] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 63.445821] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 63.445823] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 63.445825] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 63.487514] kvm: disabled by bios
[ 63.543550] kvm: disabled by bios
[ 63.547361] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/
input9
[ 63.547494] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/
card0/input10
[ 63.547615] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/so
und/card0/input11
[ 63.556776] iwlwifi 0000:03:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[ 63.611221] kvm: disabled by bios
[ 63.821501] intel_rapl_common: Found RAPL domain package
[ 63.821503] intel_rapl_common: Found RAPL domain core
[ 63.821504] intel_rapl_common: Found RAPL domain uncore
[ 63.821510] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 64.088517] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 64.088519] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 64.088521] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 64.088523] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Advanced-N 6205S AGN,
REV=0xB0
[ 64.135664] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 64.182121] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 64.860209] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[ 65.163738] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[ 66.460790] audit: type=1400 audit(1662744069.259:2): apparmor="STATUS" operation="pr
ofile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1746 comm="appar
mor_parser"
[ 66.461245] audit: type=1400 audit(1662744069.259:3): apparmor="STATUS" operation="pr
ofile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capt
ure-helper" pid=1746 comm="apparmor_parser"
[ 168.222587] wlp3s0: authenticate with 24:65:11:51:17:30
[ 168.224605] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[ 168.228380] wlp3s0: authenticated
[ 168.229094] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[ 168.257382] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1)
[ 168.281667] wlp3s0: associated
[ 169.306269] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 631.447230] audit: type=1400 audit(1662744634.138:4): apparmor="STATUS" operation="pr
ofile_load" profile="unconfined" name="mysqld_akonadi" pid=8282 comm="apparmor_parser"
[ 4562.211947] perf: interrupt took too long (2528 > 2500), lowering kernel.perf_event_m
ax_sample_rate to 79000
[ 6395.324958] perf: interrupt took too long (3174 > 3160), lowering kernel.perf_event_m
ax_sample_rate to 63000
[ 8659.051605] perf: interrupt took too long (3974 > 3967), lowering kernel.perf_event_m
ax_sample_rate to 50250
[ 9163.830600] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[ 9167.810560] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[14276.512151] perf: interrupt took too long (5022 > 4967), lowering kernel.perf_event_m
ax_sample_rate to 39750
[14544.908831] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_VAL
ID)
[14548.172219] wlp3s0: authenticate with 24:65:11:51:17:30
[14548.173520] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[14548.177553] wlp3s0: authenticated
[14548.181287] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[14548.191810] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x31 status=0 aid=1)
[14548.222030] wlp3s0: associated
[15144.911676] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_VAL
ID)
[15147.961423] wlp3s0: authenticate with 24:65:11:51:17:30
[15147.964030] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[15147.967645] wlp3s0: authenticated
[15147.970565] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[15147.986545] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1)
[15148.012976] wlp3s0: associated
[28679.896229] perf: interrupt took too long (6285 > 6277), lowering kernel.perf_event_m
ax_sample_rate to 31750
[53840.463938] perf: interrupt took too long (7866 > 7856), lowering kernel.perf_event_m
ax_sample_rate to 25250
[419995.524900] wlp3s0: authenticate with 24:65:11:51:17:30
[419995.527636] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[419995.533025] wlp3s0: authenticated
[419995.536098] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[419995.546185] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1)
[419995.570071] wlp3s0: associated
[429456.321512] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[447272.933339] usb 1-1.2: new high-speed USB device number 3 using ehci-pci
[447273.357355] usb 1-1.2: device not accepting address 3, error -71
[447273.645360] usb 1-1.2: new high-speed USB device number 4 using ehci-pci
[447273.676549] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevic
e= 2.09
[447273.676557] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[447273.676561] usb 1-1.2: Product: USB3.0 Device
[447273.676564] usb 1-1.2: Manufacturer: Intenso
[447273.676567] usb 1-1.2: SerialNumber: 201913136D768
[447273.678509] scsi host7: uas
[447273.680233] scsi 7:0:0:0: Direct-Access Intenso SCSI 0209 PQ: 0 ANS
I: 6
[447273.682973] sd 7:0:0:0: Attached scsi generic sg2 type 0
[447275.911996] sd 7:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[447275.912003] sd 7:0:0:0: [sdc] 4096-byte physical blocks
[447275.912671] sd 7:0:0:0: [sdc] Write Protect is off
[447275.912676] sd 7:0:0:0: [sdc] Mode Sense: 5f 00 00 08
[447275.913742] sd 7:0:0:0: [sdc] Disabling FUA
[447275.913754] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't sup
port DPO or FUA
[447275.914724] sd 7:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of
physical block size (4096 bytes)
[447275.944386] sdc: sdc1
[447275.949697] sd 7:0:0:0: [sdc] Attached SCSI disk
[447394.877241] sd 7:0:0:0: [sdc] tag#21 uas_zap_pending 0 uas-tag 2 inflight: CMD
[447394.877249] sd 7:0:0:0: [sdc] tag#21 CDB: Read(10) 28 00 00 00 0d 00 00 01 00 00
[447394.877261] sd 7:0:0:0: [sdc] tag#8 uas_zap_pending 0 uas-tag 3 inflight: CMD
[447394.877265] sd 7:0:0:0: [sdc] tag#8 CDB: Read(10) 28 00 74 70 54 00 00 02 00 00
[447394.877325] sd 7:0:0:0: [sdc] tag#21 FAILED Result: hostbyte=DID_NO_CONNECT driverby
te=DRIVER_OK
[447394.877331] sd 7:0:0:0: [sdc] tag#21 CDB: Read(10) 28 00 00 00 0d 00 00 01 00 00
[447394.877338] blk_update_request: I/O error, dev sdc, sector 3328 op 0x0:(READ) flags
0x80700 phys_seg 32 prio class 0
[447394.877369] sd 7:0:0:0: [sdc] tag#8 FAILED Result: hostbyte=DID_NO_CONNECT driverbyt
e=DRIVER_OK
[447394.877372] sd 7:0:0:0: [sdc] tag#8 CDB: Read(10) 28 00 74 70 54 00 00 02 00 00
[447394.877377] blk_update_request: I/O error, dev sdc, sector 1953518592 op 0x0:(READ)
flags 0x80700 phys_seg 64 prio class 0
[447394.877482] blk_update_request: I/O error, dev sdc, sector 1953518592 op 0x0:(READ)
flags 0x0 phys_seg 1 prio class 0
[447394.877490] Buffer I/O error on dev sdc1, logical block 244189568, async page read
[447394.889647] sd 7:0:0:0: [sdc] Synchronizing SCSI cache
[447395.141049] sd 7:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_ERR
OR driverbyte=DRIVER_OK
[447395.194577] usb 1-1.2: USB disconnect, device number 4
[525834.117521] perf: interrupt took too long (9837 > 9832), lowering kernel.perf_event_
max_sample_rate to 20250
[588268.733620] wlp3s0: authenticate with 24:65:11:51:17:30
[588268.734736] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[588268.738540] wlp3s0: authenticated
[588268.741422] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[588268.747284] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1)
[588268.767748] wlp3s0: associated
[1123963.674782] wlp3s0: authenticate with 24:65:11:51:17:30
[1123963.677455] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1123963.681423] wlp3s0: authenticated
[1123963.684037] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1123963.690238] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x31 status=0 aid=1)
[1123963.713444] wlp3s0: associated
[1126351.301961] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1126354.511639] wlp3s0: authenticate with 24:65:11:51:17:30
[1126354.513978] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1126354.518028] wlp3s0: authenticated
[1126354.520537] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1126354.527816] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x31 status=0 aid=1)
[1126354.548600] wlp3s0: associated
[1126951.324655] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1126954.588164] wlp3s0: authenticate with 24:65:11:51:17:30
[1126954.589493] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1126954.592885] wlp3s0: authenticated
[1126954.593830] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1126954.599423] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x31 status=0 aid=1)
[1126954.619261] wlp3s0: associated
[1129351.312478] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1129354.362205] wlp3s0: authenticate with 24:65:11:51:17:30
[1129354.363332] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1129354.366691] wlp3s0: authenticated
[1129354.368418] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1129354.376885] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x31 status=0 aid=1)
[1129354.401194] wlp3s0: associated
[1180003.272776] wlp3s0: authenticate with 24:65:11:51:17:30
[1180003.273972] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1180003.278910] wlp3s0: authenticated
[1180003.279689] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1180003.286118] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1180003.309411] wlp3s0: associated
[1182151.574909] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1182154.607878] wlp3s0: authenticate with 24:65:11:51:17:30
[1182154.609385] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1182154.613334] wlp3s0: authenticated
[1182154.614914] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1182154.626480] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1182154.646382] wlp3s0: associated
[1185151.579991] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1185154.785518] wlp3s0: authenticate with 24:65:11:51:17:30
[1185154.786639] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1185154.790383] wlp3s0: authenticated
[1185154.793157] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1185154.813872] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1185154.837804] wlp3s0: associated
[1191174.547639] usb 1-1.2: new high-speed USB device number 5 using ehci-pci
[1191174.579268] usb 1-1.2: New USB device found, idVendor=090c, idProduct=1000, bcdDevi
ce=11.00
[1191174.579276] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1191174.579279] usb 1-1.2: Product: Flash Drive
[1191174.579283] usb 1-1.2: Manufacturer: Samsung
[1191174.579286] usb 1-1.2: SerialNumber: 0309722040002986
[1191174.583879] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[1191174.584142] usb-storage 1-1.2:1.0: Quirks match for vid 090c pid 1000: 400
[1191174.584188] scsi host7: usb-storage 1-1.2:1.0
[1191177.268800] scsi 7:0:0:0: Direct-Access Samsung Flash Drive 1100 PQ: 0 AN
SI: 6
[1191177.270194] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1191177.271477] sd 7:0:0:0: [sdc] 250626566 512-byte logical blocks: (128 GB/120 GiB)
[1191177.272572] sd 7:0:0:0: [sdc] Write Protect is off
[1191177.272579] sd 7:0:0:0: [sdc] Mode Sense: 43 00 00 00
[1191177.273592] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't su
pport DPO or FUA
[1191177.294762] sdc: sdc1
[1191177.298874] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[1191212.200037] exfat: module is from the staging directory, the quality is unknown, yo
u have been warned.
[1191212.200867] exFAT: Version 1.3.0
[1191212.202315] [EXFAT] trying to mount...
[1191212.419771] [EXFAT] mounted successfully
[1191248.265953] [EXFAT] trying to unmount...
[1191248.265986] [EXFAT] unmounted successfully
[1191259.114484] usb 1-1.2: USB disconnect, device number 5
[1191259.415523] usb 1-1.2: new full-speed USB device number 6 using ehci-pci
[1191455.676129] usb 1-1.2: new high-speed USB device number 7 using ehci-pci
[1191455.747620] usb 1-1.2: New USB device found, idVendor=1058, idProduct=2621, bcdDevi
ce=10.34
[1191455.747627] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1191455.747631] usb 1-1.2: Product: Elements 2621
[1191455.747634] usb 1-1.2: Manufacturer: Western Digital
[1191455.747637] usb 1-1.2: SerialNumber: 57584A324138314C43565330
[1191455.749266] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[1191455.752537] scsi host7: usb-storage 1-1.2:1.0
[1191456.757724] scsi 7:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1191456.758519] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1191456.764726] sd 7:0:0:0: [sdc] Spinning up disk...
[1191457.780058] ...ready
[1191459.829864] sd 7:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1191459.831653] sd 7:0:0:0: [sdc] Write Protect is off
[1191459.831658] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[1191459.833249] sd 7:0:0:0: [sdc] No Caching mode page found
[1191459.833260] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[1191459.926601] sdc: sdc1
[1191459.931477] sd 7:0:0:0: [sdc] Attached SCSI disk
[1191464.909646] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[1193293.192982] usb 1-1.2: USB disconnect, device number 7
[1194151.655082] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1194151.871671] wlp3s0: authenticate with 24:65:11:51:17:30
[1194151.873322] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1194151.878503] wlp3s0: authenticated
[1194151.879951] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1194151.886062] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1194151.910155] wlp3s0: associated
[1201351.691276] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1201355.002964] wlp3s0: authenticate with 24:65:11:51:17:30
[1201355.006040] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1201355.009522] wlp3s0: authenticated
[1201355.011044] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1201355.017923] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1201355.041713] wlp3s0: associated
[1203151.705186] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1203154.910337] wlp3s0: authenticate with 24:65:11:51:17:30
[1203154.914060] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1203154.918127] wlp3s0: authenticated
[1203154.920185] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1203154.938674] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1203154.963099] wlp3s0: associated
[1203752.001052] wlp3s0: deauthenticated from 24:65:11:51:17:30 (Reason: 6=CLASS2_FRAME_
FROM_NONAUTH_STA)
[1203752.136437] wlp3s0: authenticate with 24:65:11:51:17:30
[1203752.137934] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1203752.147943] wlp3s0: authenticated
[1203752.148608] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1203752.164377] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1203752.190448] wlp3s0: associated
[1218795.675110] usb 1-1.2: new high-speed USB device number 8 using ehci-pci
[1218795.746383] usb 1-1.2: New USB device found, idVendor=1058, idProduct=2621, bcdDevi
ce=10.34
[1218795.746391] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1218795.746395] usb 1-1.2: Product: Elements 2621
[1218795.746398] usb 1-1.2: Manufacturer: Western Digital
[1218795.746401] usb 1-1.2: SerialNumber: 57584A324138314C43565330
[1218795.747826] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[1218795.749312] scsi host7: usb-storage 1-1.2:1.0
[1218796.760864] scsi 7:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1218796.761603] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1218796.767552] sd 7:0:0:0: [sdc] Spinning up disk...
[1218797.783131] ...ready
[1218799.832822] sd 7:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1218799.834345] sd 7:0:0:0: [sdc] Write Protect is off
[1218799.834350] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[1218799.836020] sd 7:0:0:0: [sdc] No Caching mode page found
[1218799.836032] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[1218799.925978] sdc: sdc1
[1218799.931321] sd 7:0:0:0: [sdc] Attached SCSI disk
[1218803.255033] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[1219471.391303] usb 1-1.2: USB disconnect, device number 8
[1299863.933080] wlp3s0: authenticate with 24:65:11:51:17:30
[1299863.934143] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1299863.938795] wlp3s0: authenticated
[1299863.939853] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1299863.957526] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1299863.981882] wlp3s0: associated
[1309144.826396] wlp3s0: authenticate with 24:65:11:51:17:30
[1309144.828013] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1309144.836405] wlp3s0: authenticated
[1309144.840501] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1309144.847220] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1309144.871757] wlp3s0: associated
[1312952.275604] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1312955.475632] wlp3s0: authenticate with 24:65:11:51:17:30
[1312955.477160] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312955.481668] wlp3s0: authenticated
[1312955.481819] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1312959.161854] wlp3s0: authenticate with 24:65:11:51:17:30
[1312959.163373] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312959.172277] wlp3s0: authenticated
[1312959.173651] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1312963.253149] wlp3s0: authenticate with 24:65:11:51:17:30
[1312963.255575] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312963.259486] wlp3s0: authenticated
[1312963.259618] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1312970.703617] wlp3s0: authenticate with 24:65:11:51:17:30
[1312970.705231] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312970.709746] wlp3s0: authenticated
[1312970.709912] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1312983.731885] wlp3s0: authenticate with 24:65:11:51:17:30
[1312983.740623] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312983.747575] wlp3s0: authenticated
[1312983.747881] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1312996.841522] wlp3s0: authenticate with 24:65:11:51:17:30
[1312996.843100] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1312996.852420] wlp3s0: authenticated
[1312996.852601] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1313009.947859] wlp3s0: authenticate with 24:65:11:51:17:30
[1313009.949099] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1313009.954947] wlp3s0: authenticated
[1313009.955105] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1313023.054453] wlp3s0: authenticate with 24:65:11:51:17:30
[1313023.056588] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1313023.060827] wlp3s0: authenticated
[1313023.061068] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1313036.162463] wlp3s0: authenticate with 24:65:11:51:17:30
[1313036.164976] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1313036.169071] wlp3s0: authenticated
[1313036.169234] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1313036.240367] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1313036.256847] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1313036.281416] wlp3s0: associated
[1313037.271645] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[1314752.293223] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1314755.463302] wlp3s0: authenticate with 24:65:11:51:17:30
[1314755.465054] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1314755.468353] wlp3s0: authenticated
[1314755.471609] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1314755.476927] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1314755.505789] wlp3s0: associated
[1315214.366169] usb 1-1.2: new high-speed USB device number 9 using ehci-pci
[1315214.395763] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315214.395770] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315214.395774] usb 1-1.2: Product: USB 2.0 Hub
[1315214.397161] hub 1-1.2:1.0: USB hub found
[1315214.397391] hub 1-1.2:1.0: 4 ports detected
[1315214.510431] hub 1-1.2:1.0: hub_ext_port_status failed (err = -71)
[1315214.519207] usb 1-1.2: Failed to suspend device, error -71
[1315214.639502] usb 1-1.2: USB disconnect, device number 9
[1315214.862174] usb 1-1.2: new high-speed USB device number 10 using ehci-pci
[1315214.891625] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315214.891631] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315214.891635] usb 1-1.2: Product: USB 2.0 Hub
[1315214.892680] hub 1-1.2:1.0: USB hub found
[1315214.893081] hub 1-1.2:1.0: 4 ports detected
[1315237.055267] hub 1-1.2:1.0: hub_ext_port_status failed (err = -71)
[1315237.066820] usb 1-1.2: Failed to suspend device, error -71
[1315237.199780] usb 1-1.2: USB disconnect, device number 10
[1315237.422097] usb 1-1.2: new high-speed USB device number 11 using ehci-pci
[1315237.451546] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315237.451553] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315237.451557] usb 1-1.2: Product: USB 2.0 Hub
[1315237.452307] hub 1-1.2:1.0: USB hub found
[1315237.452596] hub 1-1.2:1.0: 4 ports detected
[1315237.842074] usb 1-1.2.3: new high-speed USB device number 12 using ehci-pci
[1315237.873381] usb 1-1.2.3: New USB device found, idVendor=1058, idProduct=2621, bcdDe
vice=10.34
[1315237.873394] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1315237.873402] usb 1-1.2.3: Product: Elements 2621
[1315237.873409] usb 1-1.2.3: Manufacturer: Western Digital
[1315237.873413] usb 1-1.2.3: SerialNumber: 57584A324138314C43565330
[1315237.874705] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[1315237.875481] scsi host7: usb-storage 1-1.2.3:1.0
[1315238.899775] scsi 7:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1315238.901128] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1315238.907032] sd 7:0:0:0: [sdc] Spinning up disk...
[1315239.921990] ..ready
[1315240.947675] sd 7:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1315240.949481] sd 7:0:0:0: [sdc] Write Protect is off
[1315240.949489] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[1315240.950987] sd 7:0:0:0: [sdc] No Caching mode page found
[1315240.951000] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[1315241.057825] sdc: sdc1
[1315241.062695] sd 7:0:0:0: [sdc] Attached SCSI disk
[1315245.480742] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[1315528.781797] usb 1-1.2: USB disconnect, device number 11
[1315528.781805] usb 1-1.2.3: USB disconnect, device number 12
[1315529.065058] usb 1-1.2: new high-speed USB device number 13 using ehci-pci
[1315529.094503] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315529.094505] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315529.094507] usb 1-1.2: Product: USB 2.0 Hub
[1315529.094985] hub 1-1.2:1.0: USB hub found
[1315529.095194] hub 1-1.2:1.0: 4 ports detected
[1315529.481112] usb 1-1.2.3: new high-speed USB device number 14 using ehci-pci
[1315529.511871] usb 1-1.2.3: New USB device found, idVendor=1058, idProduct=2621, bcdDe
vice=10.34
[1315529.511878] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1315529.511882] usb 1-1.2.3: Product: Elements 2621
[1315529.511885] usb 1-1.2.3: Manufacturer: Western Digital
[1315529.511888] usb 1-1.2.3: SerialNumber: 57584A324138314C43565330
[1315529.512859] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[1315529.517313] scsi host8: usb-storage 1-1.2.3:1.0
[1315530.546747] scsi 8:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1315530.547114] sd 8:0:0:0: Attached scsi generic sg2 type 0
[1315530.548424] sd 8:0:0:0: [sdd] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1315530.549895] sd 8:0:0:0: [sdd] Write Protect is off
[1315530.549899] sd 8:0:0:0: [sdd] Mode Sense: 47 00 10 08
[1315530.551168] sd 8:0:0:0: [sdd] No Caching mode page found
[1315530.551174] sd 8:0:0:0: [sdd] Assuming drive cache: write through
[1315530.925120] sdd: sdd1
[1315530.929342] sd 8:0:0:0: [sdd] Attached SCSI disk
[1315540.818579] EXT4-fs (sdd1): recovery complete
[1315540.896747] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
[1315541.319595] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page w
rite
[1315541.319601] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[1315541.319603] Aborting journal on device sdc1-8.
[1315541.319607] Buffer I/O error on dev sdc1, logical block 121667584, lost sync page w
rite
[1315541.319608] JBD2: Error -5 detected when updating journal superblock for sdc1-8.
[1315580.237243] usb 1-1.2: USB disconnect, device number 13
[1315580.237251] usb 1-1.2.3: USB disconnect, device number 14
[1315580.274744] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page w
rite
[1315580.274748] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
[1315580.274750] Aborting journal on device sdd1-8.
[1315580.274754] Buffer I/O error on dev sdd1, logical block 121667584, lost sync page w
rite
[1315580.274756] JBD2: Error -5 detected when updating journal superblock for sdd1-8.
[1315580.500855] usb 1-1.2: new high-speed USB device number 15 using ehci-pci
[1315580.530328] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315580.530331] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315580.530333] usb 1-1.2: Product: USB 2.0 Hub
[1315580.530901] hub 1-1.2:1.0: USB hub found
[1315580.531021] hub 1-1.2:1.0: 4 ports detected
[1315580.920974] usb 1-1.2.3: new high-speed USB device number 16 using ehci-pci
[1315580.952991] usb 1-1.2.3: New USB device found, idVendor=1058, idProduct=2621, bcdDe
vice=10.34
[1315580.952999] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1315580.953003] usb 1-1.2.3: Product: Elements 2621
[1315580.953006] usb 1-1.2.3: Manufacturer: Western Digital
[1315580.953009] usb 1-1.2.3: SerialNumber: 57584A324138314C43565330
[1315580.954028] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[1315580.956399] scsi host7: usb-storage 1-1.2.3:1.0
[1315581.970598] scsi 7:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1315581.971713] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1315581.973093] sd 7:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1315581.974524] sd 7:0:0:0: [sdc] Write Protect is off
[1315581.974532] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[1315581.976301] sd 7:0:0:0: [sdc] No Caching mode page found
[1315581.976308] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[1315582.372114] sdc: sdc1
[1315582.377099] sd 7:0:0:0: [sdc] Attached SCSI disk
[1315588.941202] usb 1-1.2: USB disconnect, device number 15
[1315588.941211] usb 1-1.2.3: USB disconnect, device number 16
[1315589.248866] usb 1-1.2: new high-speed USB device number 17 using ehci-pci
[1315589.278265] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevi
ce= 1.11
[1315589.278271] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[1315589.278275] usb 1-1.2: Product: USB 2.0 Hub
[1315589.279021] hub 1-1.2:1.0: USB hub found
[1315589.279331] hub 1-1.2:1.0: 4 ports detected
[1315589.668903] usb 1-1.2.3: new high-speed USB device number 18 using ehci-pci
[1315589.700146] usb 1-1.2.3: New USB device found, idVendor=1058, idProduct=2621, bcdDe
vice=10.34
[1315589.700154] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1315589.700159] usb 1-1.2.3: Product: Elements 2621
[1315589.700163] usb 1-1.2.3: Manufacturer: Western Digital
[1315589.700168] usb 1-1.2.3: SerialNumber: 57584A324138314C43565330
[1315589.700983] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[1315589.701676] scsi host7: usb-storage 1-1.2.3:1.0
[1315590.706479] scsi 7:0:0:0: Direct-Access WD Elements 2621 1034 PQ: 0 AN
SI: 6
[1315590.707283] sd 7:0:0:0: Attached scsi generic sg2 type 0
[1315590.708668] sd 7:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[1315590.710247] sd 7:0:0:0: [sdc] Write Protect is off
[1315590.710256] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[1315590.711608] sd 7:0:0:0: [sdc] No Caching mode page found
[1315590.711620] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[1315590.764579] sdc: sdc1
[1315590.769015] sd 7:0:0:0: [sdc] Attached SCSI disk
[1315599.360342] EXT4-fs (sdc1): recovery complete
[1315599.361346] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[1315895.425661] usb 1-1.2.3: USB disconnect, device number 18
[1316552.311592] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1316555.478854] wlp3s0: authenticate with 24:65:11:51:17:30
[1316555.480709] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1316555.484720] wlp3s0: authenticated
[1316555.487155] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1316555.495620] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1316555.519389] wlp3s0: associated
[1317752.315546] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1317755.402436] wlp3s0: authenticate with 24:65:11:51:17:30
[1317755.408561] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1317755.422911] wlp3s0: authenticated
[1317755.425170] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1317755.434873] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1317755.459667] wlp3s0: associated
[1318352.323579] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1318355.482223] wlp3s0: authenticate with 24:65:11:51:17:30
[1318355.483733] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1318355.488324] wlp3s0: authenticated
[1318355.490500] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1318355.499492] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1318355.531668] wlp3s0: associated
[1377522.905584] wlp3s0: authenticate with 24:65:11:51:17:30
[1377522.907334] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1377522.911820] wlp3s0: authenticated
[1377522.915817] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1377522.924321] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1377522.948477] wlp3s0: associated
[1380152.677903] wlp3s0: disassociated from 24:65:11:51:17:30 (Reason: 2=PREV_AUTH_NOT_V
ALID)
[1380163.840359] wlp3s0: authenticate with 24:65:11:51:17:30
[1380163.842415] wlp3s0: send auth to 24:65:11:51:17:30 (try 1/3)
[1380163.845885] wlp3s0: authenticated
[1380163.846189] wlp3s0: waiting for beacon from 24:65:11:51:17:30
[1380163.898983] wlp3s0: associate with 24:65:11:51:17:30 (try 1/3)
[1380163.906034] wlp3s0: RX AssocResp from 24:65:11:51:17:30 (capab=0x431 status=0 aid=1
[1380163.932398] wlp3s0: associated
