Sarius87
Banned
- Mai 2016
Hilfe , habe ein mysqldump script getestet und seitdem geht meine Seite nicht mehr und phpmyadmin ist auch nicht mehr erreichbar... da steht nur error 403 forbidden und einloggen kann ich mich mit dem website ftp user auch nicht mehr . starte ich mysql mit
kommt das im log :
was ist das ?? was tun ?
Code:
service mysql start
kommt das im log :
Code:
160907 20:10:34 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
160907 20:10:34 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
160907 20:10:34 [Note] /usr/sbin/mysqld (mysqld 5.5.50-0+deb8u1) starting as process 27449 ...
160907 20:10:34 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
160907 20:10:34 [Note] Plugin 'FEDERATED' is disabled.
/usr/sbin/mysqld: Table 'plugin' is read only
160907 20:10:34 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
160907 20:10:34 InnoDB: The InnoDB memory heap is disabled
160907 20:10:34 InnoDB: Mutexes and rw_locks use GCC atomic builtins
160907 20:10:34 InnoDB: Compressed tables use zlib 1.2.8
160907 20:10:34 InnoDB: Using Linux native AIO
/usr/sbin/mysqld: Can't create/write to file '/tmp/ibVCxKO4' (Errcode: 13)
160907 20:10:34 InnoDB: Error: unable to create temporary file; errno: 13
160907 20:10:34 [ERROR] Plugin 'InnoDB' init function returned error.
160907 20:10:34 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
160907 20:10:34 [ERROR] Unknown/unsupported storage engine: InnoDB
160907 20:10:34 [ERROR] Aborting
160907 20:10:34 [Note] /usr/sbin/mysqld: Shutdown complete
160907 20:10:34 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
