crawn
- Nov. 2003
Tag
Ich habe ein Problem, und zwar kann ich nichts hochladen.
Benutze SmartFTP, das Problem besteht jedoch bei allen PCs und auch mit CuteFTP funktionierts nicht.
Ich bekomme folgenden Log:
[18:04:53] SmartFTP v2.0.995.8
[18:04:53] Resolving host name "login-3.hoststar.ch"
[18:04:53] Connecting to 213.239.195.176 Port: 21
[18:04:53] Connected to login-3.hoststar.ch.
[18:04:53] 220 FTP Server ready.
[18:04:53] USER web383
[18:04:53] 331 Password required for web383.
[18:04:53] PASS (hidden)
[18:04:53] 230 User web383 logged in.
[18:04:53] SYST
[18:04:53] 215 UNIX Type: L8
[18:04:53] FEAT
[18:04:53] 211-Features:
[18:04:53] MDTM
[18:04:53] REST STREAM
[18:04:53] SIZE
[18:04:53] 211 End
[18:04:53] PWD
[18:04:53] 257 "/" is current directory.
[18:04:58] CWD /html/smarty
[18:04:58] 250 CWD command successful
[18:04:58] PWD
[18:04:58] 257 "/html/smarty" is current directory.
[18:04:58] Remote file exist check: "COPYING.lib".
[18:04:58] TYPE I
[18:04:58] 200 Type set to I
[18:04:58] SIZE COPYING.lib
[18:04:58] 550 COPYING.lib: No such file or directory
[18:04:58] PASV
[18:04:58] 227 Entering Passive Mode (213,239,195,176,179,164).
[18:04:58] Opening data connection to 213.239.195.176 Port: 45988
[18:04:58] STOR COPYING.lib
[18:04:58] 150 Opening BINARY mode data connection for COPYING.lib
[18:05:38] Transfer Timeout (40s). Closing data connection.
[18:05:38] 8192 bytes transferred. (204 Byte/s) (00:00:40)
[18:06:18] Timeout (40s).
[18:06:18] Active Help: http://www.smartftp.com/support/kb/index.php/74
[18:06:18] Client closed the connection.
[18:06:18] Transfer failed.
[18:06:18] Resolving host name "login-3.hoststar.ch"
[18:06:18] Connecting to 213.239.195.176 Port: 21
[18:06:18] Connected to login-3.hoststar.ch.
[18:06:18] 220 FTP Server ready.
[18:06:18] USER web383
[18:06:18] 331 Password required for web383.
[18:06:18] PASS (hidden)
[18:06:18] 230 User web383 logged in.
[18:06:18] SYST
[18:06:18] 215 UNIX Type: L8
[18:06:18] FEAT
[18:06:18] 211-Features:
[18:06:18] MDTM
[18:06:18] REST STREAM
[18:06:18] SIZE
[18:06:18] 211 End
[18:06:18] PWD
[18:06:18] 257 "/" is current directory.
[18:06:18] CWD /html/smarty
[18:06:18] 250 CWD command successful
[18:06:18] PWD
[18:06:18] 257 "/html/smarty" is current directory.
[18:06:18] TYPE A
[18:06:18] 200 Type set to A
[18:06:18] PASV
[18:06:18] 227 Entering Passive Mode (213,239,195,176,179,193).
[18:06:18] Opening data connection to 213.239.195.176 Port: 46017
[18:06:18] LIST -aL
[18:06:18] 150 Opening ASCII mode data connection for file list
[18:06:18] 312 bytes transferred. (19.0 KB/s) (16 ms)
[18:06:18] 226 Transfer complete.
An dieser stelle gehts nimmer weiter:
Das komische ist jedoch, dass es ab und an mal funktioniert und ein File hochladen kann das auch Originalgrösse hat. Manche Files sind dann 0kb gross.
Mein Provider ist Bluewin und mein Router der Linksys AG241-EU
Hab vor kurzem den Provider gewechselt und auch den neuen Router bekommen.
Freundliche Grüsse
[18:04:53] SYST
[18:04:53] FEAT
[18:04:53] MDTM
[18:04:53] SIZE
[18:04:53] 211 End
[18:04:53] PWD
[18:04:58] PWD
[18:04:58] TYPE I
[18:04:58] PASV
[18:06:18] SYST
[18:06:18] FEAT
[18:06:18] MDTM
[18:06:18] SIZE
[18:06:18] 211 End
[18:06:18] PWD
[18:06:18] PWD
[18:06:18] TYPE A
[18:06:18] PASV
[18:06:18] LIST -aL
Freundliche Grüsse
