hey folks,
at least ive done everything below to fix this graphic driver crash issue with no success:
determine hardware problems:
ive installed memtest86 on a cd and run it 10 hours. no failures detected.
ive installed prime95 and run it about 14 hours.
then i tryed to lower my gpu to standards (cause its an oc card) with no effect
after this i chose to reinstall windows. at first windows 10 with the new upgrade.
installed only all windows updates and teamspeak. then download the whole game from ubi and installed it. i started opened up a terrorist hunt in matchmaking mode and crashed ingame after a couples of minutes.
then i runed sfc /scannow. this leads me to an error with opencl.dll which i fixed with an install.wim of a windows 10 iso and dism.
afetr this i checked if the problem persists and yea it still persists.
i checked directx installed the websetup, checked the problem again leads me to another crash.
soive looked what causes the crash in the watchdog dumpfiles. this leads me into the error message "VIDEO-ENGINE-TIMEOUT-DETECTED" so i try to update my drivers with no success.
then i expand the timeout (tdrDelay) to 60 seconds but nothing, it just crashed anyway.
now i installed win8 and upgraded it to 8.1. updated directx, updated drivers and still the crash happens.
i dont know if its windows, nvidia, or directx or just maybe the game.
if someone got any else solution i would appreciate it to test.
my actual rig:
windows 8.1 x64
intel i 7 2600k
Gigabyte ga-z68x-ud3h-b3
Gigybyte Nvidia GTX 660Ti OC
SAMSUNG HD252HJ
650W Powersuply
my actual rig:
windows 8.1 x64
intel i 7 2600k
SAMSUNG HD252HJ
650W Powersuply
