HDD smart report - kritisch?
AgentHawk
Mai 2012
Moin
ich bekomme bei unraid aktuell die Warnung zu einer Platte - habe dann den Test gemacht und werde da noch nicht so schlau draus.
Das ist eine meiner Parity Drives - Tauschen oder geht noch?
Code:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.10.28-Unraid] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E3DNLN1C
LU WWN Device Id: 5 0014ee 26362d556
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Sep  4 11:52:41 2021 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      ( 121)    The previous self-test completed having
                    the read element of the test failed.
Total time to complete Offline
data collection:         (51720) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 517) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    1089
  3 Spin_Up_Time            POS--K   180   171   021    -    7958
  4 Start_Stop_Count        -O--CK   098   098   000    -    2560
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   045   045   000    -    40425
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    256
192 Power-Off_Retract_Count -O--CK   200   200   000    -    174
193 Load_Cycle_Count        -O--CK   176   176   000    -    73000
194 Temperature_Celsius     -O---K   116   107   000    -    36
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    6
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      39  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 31 (device log contains only the most recent 24 errors)
    CR     = Command Register
    FEATR  = Features Register
    COUNT  = Count (was: Sector Count) Register
    LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
    LH     = LBA High (was: Cylinder High) Register    ]   LBA
    LM     = LBA Mid (was: Cylinder Low) Register      ] Register
    LL     = LBA Low (was: Sector Number) Register     ]
    DV     = Device (was: Device/Head) Register
    DC     = Device Control Register
    ER     = Error register
    ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 31 [6] occurred at disk power-on lifetime: 40179 hours (1674 days + 3 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 00 44 44 58 40 00  Error: UNC at LBA = 0x00444458 = 4473944
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 02 78 00 90 00 00 00 44 56 c8 40 08     00:01:48.795  READ FPDMA QUEUED
  60 02 c8 00 48 00 00 00 44 54 00 40 08     00:01:48.795  READ FPDMA QUEUED
  60 05 40 00 40 00 00 00 44 4e c0 40 08     00:01:48.790  READ FPDMA QUEUED
  60 00 28 00 88 00 00 00 44 4e 98 40 08     00:01:48.375  READ FPDMA QUEUED
  60 05 40 00 78 00 00 00 44 49 58 40 08     00:01:48.375  READ FPDMA QUEUED
Error 30 [5] occurred at disk power-on lifetime: 40032 hours (1668 days + 0 hours)
  40 -- 51 00 00 00 00 05 db 6d 80 40 00  Error: UNC at LBA = 0x05db6d80 = 98266496
  60 00 08 00 a8 00 01 61 ac 50 e0 40 08     00:11:35.405  READ FPDMA QUEUED
  60 05 40 00 a0 00 00 05 db 69 20 40 08     00:11:35.405  READ FPDMA QUEUED
  60 00 40 00 98 00 00 05 db 68 e0 40 08     00:11:35.395  READ FPDMA QUEUED
  60 05 40 00 90 00 00 05 db 63 a0 40 08     00:11:35.395  READ FPDMA QUEUED
  60 05 40 00 88 00 00 05 db 5e 60 40 08     00:11:34.952  READ FPDMA QUEUED
Error 29 [4] occurred at disk power-on lifetime: 38414 hours (1600 days + 14 hours)
  40 -- 51 00 00 00 00 01 33 83 60 40 00  Error: UNC at LBA = 0x01338360 = 20153184
  60 00 40 00 a0 00 00 01 33 83 30 40 08 24d+02:38:29.675  READ FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 e0 08 24d+02:38:29.660  FLUSH CACHE EXT
  61 00 08 00 68 00 00 01 8a c3 c8 40 08 24d+02:38:29.659  WRITE FPDMA QUEUED
  61 00 08 00 60 00 00 01 33 83 28 40 08 24d+02:38:29.652  WRITE FPDMA QUEUED
  60 00 08 00 58 00 00 01 8a c3 c8 40 08 24d+02:38:29.646  READ FPDMA QUEUED
Error 28 [3] occurred at disk power-on lifetime: 38337 hours (1597 days + 9 hours)
  40 -- 51 00 00 00 00 01 33 a3 70 40 00  Error: UNC at LBA = 0x0133a370 = 20161392
  60 00 08 00 b0 00 00 01 81 1f c8 40 08 20d+21:49:38.741  READ FPDMA QUEUED
  60 00 10 00 a0 00 00 01 33 a3 68 40 08 20d+21:49:38.741  READ FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 e0 08 20d+21:49:38.741  FLUSH CACHE EXT
  ea 00 00 00 00 00 00 00 00 00 00 e0 08 20d+21:49:38.162  FLUSH CACHE EXT
  61 00 08 00 98 00 01 61 b7 be 30 40 08 20d+21:49:38.162  WRITE FPDMA QUEUED
Error 27 [2] occurred at disk power-on lifetime: 38161 hours (1590 days + 1 hours)
  40 -- 51 00 00 00 00 76 40 2a b8 40 00  Error: WP at LBA = 0x76402ab8 = 1983916728
  61 00 78 00 28 00 01 61 b8 44 d8 40 08 13d+14:09:45.473  WRITE FPDMA QUEUED
  60 02 c0 00 20 00 00 76 40 2e a8 40 08 13d+14:09:45.455  READ FPDMA QUEUED
  60 05 40 00 18 00 00 76 40 29 68 40 08 13d+14:09:45.451  READ FPDMA QUEUED
  60 00 e0 00 f8 00 00 76 40 28 88 40 08 13d+14:09:45.437  READ FPDMA QUEUED
  60 01 e0 00 b8 00 00 76 40 26 a8 40 08 13d+14:09:45.433  READ FPDMA QUEUED
Error 26 [1] occurred at disk power-on lifetime: 38161 hours (1590 days + 1 hours)
  40 -- 51 00 00 00 00 76 40 09 a8 40 00  Error: UNC at LBA = 0x764009a8 = 1983908264
  60 05 40 00 78 00 00 76 40 11 68 40 08 13d+14:09:41.608  READ FPDMA QUEUED
  60 05 40 00 70 00 00 76 40 0c 28 40 08 13d+14:09:41.606  READ FPDMA QUEUED
  60 02 08 00 68 00 00 76 40 0a 20 40 08 13d+14:09:41.602  READ FPDMA QUEUED
  60 01 98 00 60 00 00 76 40 08 88 40 08 13d+14:09:41.206  READ FPDMA QUEUED
  60 01 e0 00 58 00 00 76 40 06 a8 40 08 13d+14:09:41.205  READ FPDMA QUEUED
Error 25 [0] occurred at disk power-on lifetime: 37811 hours (1575 days + 11 hours)
  40 -- 51 00 00 00 00 01 33 a9 70 40 00  Error: UNC at LBA = 0x0133a970 = 20162928
  60 05 40 00 70 00 00 01 33 a9 90 40 08 48d+16:22:40.041  READ FPDMA QUEUED
  60 05 00 00 60 00 00 01 33 a4 90 40 08 48d+16:22:40.029  READ FPDMA QUEUED
  60 00 08 00 58 00 01 61 b7 aa 20 40 08 48d+16:22:37.922  READ FPDMA QUEUED
  61 00 08 00 50 00 01 5c 8a 9f 58 40 08 48d+16:22:37.922  WRITE FPDMA QUEUED
  61 00 08 00 48 00 01 5c 8a 9f 48 40 08 48d+16:22:37.922  WRITE FPDMA QUEUED
Error 24 [23] occurred at disk power-on lifetime: 37618 hours (1567 days + 10 hours)
  40 -- 51 00 00 00 00 01 33 ae 48 40 00  Error: WP at LBA = 0x0133ae48 = 20164168
  61 00 30 00 88 00 00 01 58 b5 70 40 08 40d+15:29:40.386  WRITE FPDMA QUEUED
  61 01 40 00 80 00 00 01 53 e7 10 40 08 40d+15:29:40.384  WRITE FPDMA QUEUED
  61 01 80 00 78 00 00 01 53 e5 50 40 08 40d+15:29:40.384  WRITE FPDMA QUEUED
  61 00 c0 00 70 00 00 01 53 ec d0 40 08 40d+15:29:40.379  WRITE FPDMA QUEUED
  61 00 08 00 58 00 00 01 53 ec 50 40 08 40d+15:29:40.379  WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%     40423         4477480
# 2  Short offline       Completed: read failure       40%     40423         4477480
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
Device State:                        Active (0)
Current Temperature:                    36 Celsius
Power Cycle Min/Max Temperature:     28/37 Celsius
Lifetime    Min/Max Temperature:      3/45 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (288)
Index    Estimated Time   Temperature Celsius
 289    2021-09-04 03:55    37  ******************
 ...    ..(114 skipped).    ..  ******************
 404    2021-09-04 05:50    37  ******************
 405    2021-09-04 05:51    36  *****************
 ...    ..(155 skipped).    ..  *****************
  83    2021-09-04 08:27    36  *****************
  84    2021-09-04 08:28    37  ******************
 ...    ..( 53 skipped).    ..  ******************
 138    2021-09-04 09:22    37  ******************
 139    2021-09-04 09:23    36  *****************
 ...    ..( 86 skipped).    ..  *****************
 226    2021-09-04 10:50    36  *****************
 227    2021-09-04 10:51    37  ******************
 ...    ..( 60 skipped).    ..  ******************
 288    2021-09-04 11:52    37  ******************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4       164102  Vendor specific
Smart Werte schauen besser aus nutzt man Crystal Disk Info
Reaktionen: AgentHawk
Die Fehlermeldungen und #ID 3 bzw. 200 zeigen, dass sie gelegentlich Probleme beim Lesen und Schreiben hat.
Problematische Sektoren oder CRC-Fehler gibt es jedoch scheinbar nicht.
Damit scheint der Lese/Schreibkopf die Probleme zu haben.
Ich denke, dass ist noch nicht kritisch, aber mit 40k Stunden (4,5 Jahre) ist sie aber auch nicht mehr die juengste .
Das ist jedoch nur meine Interpretation.
Ich wuerde die Daten sichern und sie zeitnah in den verdienten Ruhestand schicken.
Der letzte Eintrag ist bereits 246 Betriebsstunden her, das war Einer der gemeldeten 1089 Lesefehler.
Der letzte Schreibfehler der 6 Gelisteten war bei 38161 Betriebsstunden.
Mehr als @Scientist gibts nicht zu sagen.
