vill weil die auflösung NICHT 1980*1020 sondern 1920*1080 is?
@ bettleduck: ja, sollte auch für das normale sum gehen
For the Battle for Middle-earth II go to "Documents and Settings\*User Name*\Application Data\My Battle for Middle-earth(tm) II Files" and open "Options.ini" with a text editor.
The folders may be hidden so you might have to enable "Show hidden files and folders" in "Folder Options".
Search for...
Resolution = **** ****
Change "****" to your desired widescreen resolution.
For the Rise of the Witch-King go to "Documents and Settings\*User Name*\Application Data\My The Lord of the Rings, The Rise of the Witch-king Files" and repeat the steps above.
