htaccess überschreiben
Cool Master
Fleet Admiral
Dez. 2005
Moin,
hab ein kleines Problem. Ich habe gerade eine Drupal 7 Seite auf Drupal 8 geupgraded. War auch kein Problem aber nun geht Piwik nicht mehr da ich ein 403 Forbidden bekomme :(
Ich nehme mal stark an es liegt an der neuen .htaccess für Drupal 8 mit diesen Eintrag:
Code:
# Protect files and directories from prying eyes.
<FilesMatch "\.(engine|inc|install|make|module|profile|po|sh|.*sql|theme|twig|tpl(\.php)?|xtmpl|yml)(~|\.sw[op]|\.bak|\.orig|\.save)?$|^(\.(?!well-known).*|Entries.*|Repository|Root|Tag|Template|composer\.(json|lock))$|^#.*#$|\.php(~|\.sw[op]|\.bak|\.orig|\.save)$">
  <IfModule mod_authz_core.c>
    Require all denied
  </IfModule>
  <IfModule !mod_authz_core.c>
    Order allow,deny
  </IfModule>
</FilesMatch>
Hier mal die gesamte .htacces:
Code:
# Apache/PHP/Drupal settings:
    Require all denied
  </IfModule>
    Order allow,deny
  </IfModule>
</FilesMatch>
# Don't show directory listings for URLs which map to a directory.
Options -Indexes
# Set the default handler.
DirectoryIndex index.php index.html index.htm
# Add correct encoding for SVGZ.
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
# Most of the following PHP settings cannot be changed at runtime. See
# sites/default/default.settings.php and
# Drupal\Core\DrupalKernel::bootEnvironment() for settings that can be
# changed at runtime.
# PHP 5, Apache 1 and 2.
<IfModule mod_php5.c>
  php_value assert.active                   0
  php_flag session.auto_start               off
  php_value mbstring.http_input             pass
  php_value mbstring.http_output            pass
  php_flag mbstring.encoding_translation    off
  # PHP 5.6 has deprecated $HTTP_RAW_POST_DATA and produces warnings if this is
  # not set.
  php_value always_populate_raw_post_data   -1
</IfModule>
# Requires mod_expires to be enabled.
<IfModule mod_expires.c>
  # Enable expirations.
  ExpiresActive On
  # Cache all files for 2 weeks after access (A).
  ExpiresDefault A1209600
  <FilesMatch \.php$>
    # Do not allow PHP scripts to be cached unless they explicitly send cache
    # headers themselves. Otherwise all scripts would have to overwrite the
    # headers set by mod_expires if they want another caching behavior. This may
    # fail if an error occurs early in the bootstrap process, and it may cause
    # problems if a non-Drupal PHP file is installed in a subdirectory.
    ExpiresActive Off
  </FilesMatch>
</IfModule>
# Set a fallback resource if mod_rewrite is not enabled. This allows Drupal to
# work without clean URLs. This requires Apache version >= 2.2.16. If Drupal is
# not accessed by the top level URL (i.e.: http://example.com/drupal/ instead of
# http://example.com/), the path to index.php will need to be adjusted.
<IfModule !mod_rewrite.c>
  FallbackResource /index.php
</IfModule>
# Various rewrite rules.
<IfModule mod_rewrite.c>
  RewriteEngine on
  # Set "protossl" to "s" if we were accessed via https://.  This is used later
  # if you enable "www." stripping or enforcement, in order to ensure that
  # you don't bounce between http and https.
  RewriteRule ^ - [E=protossl]
  RewriteCond %{HTTPS} on
  RewriteRule ^ - [E=protossl:s]
  # Make sure Authorization HTTP header is available to PHP
  # even when running as CGI or FastCGI.
  RewriteRule ^ - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
  # Block access to "hidden" directories whose names begin with a period. This
  # includes directories used by version control systems such as Subversion or
  # Git to store control files. Files whose names begin with a period, as well
  # as the control files used by CVS, are protected by the FilesMatch directive
  # above.
  # NOTE: This only works when mod_rewrite is loaded. Without mod_rewrite, it is
  # not possible to block access to entire directories from .htaccess because
  # <DirectoryMatch> is not allowed here.
  # If you do not have mod_rewrite installed, you should remove these
  # directories from your webroot or otherwise protect them from being
  # downloaded.
  RewriteRule "(^|/)\.(?!well-known)" - [F]
  # If your site can be accessed both with and without the 'www.' prefix, you
  # can use one of the following settings to redirect users to your preferred
  # URL, either WITH or WITHOUT the 'www.' prefix. Choose ONLY one option:
  # To redirect all users to access the site WITH the 'www.' prefix,
  # (http://example.com/foo will be redirected to http://www.example.com/foo)
  # uncomment the following:
  # RewriteCond %{HTTP_HOST} .
  # RewriteCond %{HTTP_HOST} !^www\. [NC]
  # RewriteRule ^ http%{ENV:protossl}://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
  # To redirect all users to access the site WITHOUT the 'www.' prefix,
  # (http://www.example.com/foo will be redirected to http://example.com/foo)
  # RewriteCond %{HTTP_HOST} ^www\.(.+)$ [NC]
  # RewriteRule ^ http%{ENV:protossl}://%1%{REQUEST_URI} [L,R=301]
  # Modify the RewriteBase if you are using Drupal in a subdirectory or in a
  # VirtualDocumentRoot and the rewrite rules are not working properly.
  # For example if your site is at http://example.com/drupal uncomment and
  # modify the following line:
  # RewriteBase /drupal
  # If your site is running in a VirtualDocumentRoot at http://example.com/,
  # uncomment the following line:
  # RewriteBase /
  # Redirect common PHP files to their new locations.
  RewriteCond %{REQUEST_URI} ^(.*)?/(install.php) [OR]
  RewriteCond %{REQUEST_URI} ^(.*)?/(rebuild.php)
  RewriteCond %{REQUEST_URI} !core
  RewriteRule ^ %1/core/%2 [L,QSA,R=301]
  # Rewrite install.php during installation to see if mod_rewrite is working
  RewriteRule ^core/install.php core/install.php?rewrite=ok [QSA,L]
  # Pass all requests not referring directly to files in the filesystem to
  # index.php.
  RewriteCond %{REQUEST_FILENAME} !-f
  RewriteCond %{REQUEST_FILENAME} !-d
  RewriteCond %{REQUEST_URI} !=/favicon.ico
  RewriteRule ^ index.php [L]
  # For security reasons, deny access to other PHP files on public sites.
  # Note: The following URI conditions are not anchored at the start (^),
  # because Drupal may be located in a subdirectory. To further improve
  # security, you can replace '!/' with '!^/'.
  # Allow access to PHP files in /core (like authorize.php or install.php):
  RewriteCond %{REQUEST_URI} !/core/[^/]*\.php$
  # Allow access to test-specific PHP files:
  RewriteCond %{REQUEST_URI} !/core/modules/system/tests/https?.php
  # Allow access to Statistics module's custom front controller.
  # Copy and adapt this rule to directly execute PHP files in contributed or
  # custom modules or to run another PHP application in the same directory.
  RewriteCond %{REQUEST_URI} !/core/modules/statistics/statistics.php$
  # Deny access to any other PHP files that do not match the rules above.
  # Specifically, disallow autoload.php from being served directly.
  RewriteRule "^(.+/.*|autoload)\.php($|/)" - [F]
  # Rules to correctly serve gzip compressed CSS and JS files.
  # Requires both mod_rewrite and mod_headers to be enabled.
  <IfModule mod_headers.c>
    # Serve gzip compressed CSS files if they exist and the client accepts gzip.
    RewriteCond %{HTTP:Accept-encoding} gzip
    RewriteCond %{REQUEST_FILENAME}\.gz -s
    RewriteRule ^(.*)\.css $1\.css\.gz [QSA]
    # Serve gzip compressed JS files if they exist and the client accepts gzip.
    RewriteRule ^(.*)\.js $1\.js\.gz [QSA]
    # Serve correct content types, and prevent mod_deflate double gzip.
    RewriteRule \.css\.gz$ - [T=text/css,E=no-gzip:1]
    RewriteRule \.js\.gz$ - [T=text/javascript,E=no-gzip:1]
    <FilesMatch "(\.js\.gz|\.css\.gz)$">
      # Serve correct encoding type.
      Header set Content-Encoding gzip
      # Force proxies to cache gzipped & non-gzipped css/js files separately.
      Header append Vary Accept-Encoding
    </FilesMatch>
  </IfModule>
</IfModule>
# Add headers to all responses.
  # Disable content sniffing, since it's an attack vector.
  Header always set X-Content-Type-Options nosniff
</IfModule>
Meine Frage daher wie kann ich für den Ordner /piwik diese Regel umgehen? Für andere Ordner z.B. /ilias welche auch eine index.php haben macht er keine Probleme.
Ich habe es schon mit dem hier versucht:
Code:
<Directory /piwik/> // Alternativ auch mit full path probiert.
       Order Deny,Allow
       Allow from all
</Directory>
Aber das hat kein Auswikung in der vhost config und in der .htaccess sagt mir mein Log "<Directory not allowed here" und ich bekomme ein 500 interal server error.
eine direkte Lösung kann ich dir nicht geben, aber einen Vorschlag (der das Problem dann auch gleich Löst):
ich nutze Piwik auch mit mehren Projekten und habe Piwik daher eine Subdomain gegeben - unter der gleichen Domain von der es auch aufgerufen wird (bei 5 Webseiten/Domains, also 5 Subdomains - aber gleiche Installation)
Wichtig: wenn du schon dabei bist: verzichte auf piwik in der URL/Domain! Jeder Adblocker blockt das Standardmäßig. Nimm z.b. pywuek.deinedomain.tld .... auf der Aufruf piwik.php sollte per htaccess z.b. auf abc.php geändert werden. Es gibt wirklich viele die Adblocker nutzen - das siehst dann bei einer gut frequentierten Seite nach der Änderung sofort, weil die Zugriffe hoch gehen ;)
1. Punkt:
So habe ich es auch auf einem anderen Server aber das ist nicht möglich bei diesem Projekt.
2. Punkt:
Werde ich niemals machen. So ein vorgehen ist beschämend und wenn jemand das Tracking blocken will ist es sein gutes recht. Sei es nun über Adblock oder andere Blocker.
Habe es btw. gelöst:
Code:
#Piwik erlauben
RewriteCond %{REQUEST_URI} "/piwik/"
RewriteRule (.*) $1 [L]
