PHP HTTPS in PHPStorm aktivieren
FrazeColder
Okt. 2013
Guten Tag zusammen,
ich habe bereits gegoogelt und ein paar Einstellungen vorgenommen, kann allerdings immer noch nichts von https Seiten mittels $dom->load(); laden... bekomme da immer diese Fehlermeldung:
Code:
PHP Warning:  DOMDocument::load(): Unable to find the wrapper "https" - did you forget to enable it when you configured PHP? in C:\Users\Jan\PhpstormProjects\censored\Test.php on line 16
PHP Warning:  DOMDocument::load(): I/O warning : failed to load external entity "censored" in C:\Users\Jan\PhpstormProjects\censored\Test.php on line 16
Vorgenommene Einstellungen bisher:
1. In der php.ini Datei extension=php_openssl.dll aktiviert! - Also das ";" entfernt.
2. Den Installationspfad von PHP zu PATH hinzugefügt.
Hier meine phpinfo():
Code:
PHP Version => 7.1.0
System => Windows NT JAN-PC 6.1 build 7601 (Windows 7 Professional Edition Service Pack 1) i586
Build Date => Dec  2 2016 05:23:52
Compiler => MSVC14 (Visual C++ 2015)
Architecture => x86
Configure Command => cscript /nologo configure.js  "--enable-snapshot-build" "--enable-debug-pack" "--disable-zts" "--with-pdo-oci=c:\php-sdk\oracle\x86\instantclient_12_1\sdk,shared" "--with-oci8-12c=c:\php-sdk\oracle\x86\instantclient_12_1\sdk,shared" "--enable-object-out-dir=../obj/" "--enable-com-dotnet=shared" "--with-mcrypt=static" "--without-analyzer" "--with-pgo"
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => C:\Windows
Loaded Configuration File => D:\Anwendung\PHP 7\php.ini
Scan this dir for additional .ini files => (none)
Additional .ini files parsed => (none)
PHP API => 20160303
PHP Extension => 20160303
Zend Extension => 320160303
Zend Extension Build => API320160303,NTS,VC14
PHP Extension Build => API20160303,NTS,VC14
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => disabled
Zend Memory Manager => enabled
Zend Multibyte Support => disabled
IPv6 Support => enabled
DTrace Support => disabled
Registered PHP Streams => php, file, glob, data, http, ftp, zip, compress.zlib, phar
Registered Stream Socket Transports => tcp, udp
Registered Stream Filters => convert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.1.0-dev, Copyright (c) 1998-2016 Zend Technologies
 _______________________________________________________________________
Configuration
bcmath
BCMath support => enabled
Directive => Local Value => Master Value
bcmath.scale => 0 => 0
calendar
Calendar support => enabled
Core
allow_url_fopen => On => On
allow_url_include => Off => Off
arg_separator.input => & => &
arg_separator.output => & => &
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => UTF-8 => UTF-8
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => no value => no value
display_errors => Off => Off
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => Off => Off
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => 22527 => 22527
expose_php => On => On
extension_dir => C:\php\ext => C:\php\ext
file_uploads => On => On
hard_timeout => 2 => 2
highlight.comment => <font style="color: #FF8000">#FF8000</font> => <font style="color: #FF8000">#FF8000</font>
highlight.default => <font style="color: #0000BB">#0000BB</font> => <font style="color: #0000BB">#0000BB</font>
highlight.html => <font style="color: #000000">#000000</font> => <font style="color: #000000">#000000</font>
highlight.keyword => <font style="color: #007700">#007700</font> => <font style="color: #007700">#007700</font>
highlight.string => <font style="color: #DD0000">#DD0000</font> => <font style="color: #DD0000">#DD0000</font>
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .;C:\php\pear => .;C:\php\pear
input_encoding => no value => no value
internal_encoding => no value => no value
log_errors => On => On
log_errors_max_len => 1024 => 1024
mail.add_x_header => On => On
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => 128M => 128M
open_basedir => no value => no value
output_buffering => 0 => 0
output_encoding => no value => no value
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 16K => 16K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => GP => GP
sendmail_from => no value => no value
sendmail_path => no value => no value
serialize_precision => -1 => -1
short_open_tag => Off => Off
SMTP => localhost => localhost
smtp_port => 25 => 25
sql.safe_mode => Off => Off
sys_temp_dir => no value => no value
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 2M => 2M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => GPCS => GPCS
windows.show_crt_warning => Off => Off
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.assertions => -1 => -1
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
ctype
ctype functions => enabled
date
date/time support => enabled
"Olson" Timezone Database Version => 2016.10
Timezone Database => internal
Default timezone => UTC
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => no value => no value
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.4
HTML Support => enabled
XPath Support => enabled
XPointer Support => enabled
Schema Support => enabled
RelaxNG Support => enabled
filter
Input Validation and Filtering => enabled
Revision => $Id: 9cc4bdc40f4013d538d685f912be2e9698c649cc $
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support => Enabled
MHASH API Version => Emulated Support
iconv
iconv support => enabled
iconv implementation => "libiconv"
iconv library version => 1.14
iconv.input_encoding => no value => no value
iconv.internal_encoding => no value => no value
iconv.output_encoding => no value => no value
json
json support => enabled
json version => 1.5.0
libxml
libXML support => active
libXML Compiled Version => 2.9.4
libXML Loaded Version => 20904
libXML streams => enabled
mcrypt
mcrypt support => enabled
mcrypt_filter support => enabled
Version => 2.5.8
Api No => 20021217
Supported ciphers => cast-128 gost rijndael-128 twofish cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes arcfour
Supported modes => cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir => no value => no value
mcrypt.modes_dir => no value => no value
mysqlnd
mysqlnd => enabled
Version => mysqlnd 5.0.12-dev - 20150407 - $Id: d8daadaf41e3cd81d7c6ae96c6091fd15b2c9382 $
Compression => supported
core SSL => supported
extended SSL => not supported
Command buffer size => 4096
Read buffer size => 32768
Read timeout => 31536000
Collecting statistics => Yes
Collecting memory statistics => No
Tracing => n/a
Loaded plugins => mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password
API Extensions =>
mysqlnd statistics =>
bytes_sent => 0
bytes_received => 0
packets_sent => 0
packets_received => 0
protocol_overhead_in => 0
protocol_overhead_out => 0
bytes_received_ok_packet => 0
bytes_received_eof_packet => 0
bytes_received_rset_header_packet => 0
bytes_received_rset_field_meta_packet => 0
bytes_received_rset_row_packet => 0
bytes_received_prepare_response_packet => 0
bytes_received_change_user_packet => 0
packets_sent_command => 0
packets_received_ok => 0
packets_received_eof => 0
packets_received_rset_header => 0
packets_received_rset_field_meta => 0
packets_received_rset_row => 0
packets_received_prepare_response => 0
packets_received_change_user => 0
result_set_queries => 0
non_result_set_queries => 0
no_index_used => 0
bad_index_used => 0
slow_queries => 0
buffered_sets => 0
unbuffered_sets => 0
ps_buffered_sets => 0
ps_unbuffered_sets => 0
flushed_normal_sets => 0
flushed_ps_sets => 0
ps_prepared_never_executed => 0
ps_prepared_once_executed => 0
rows_fetched_from_server_normal => 0
rows_fetched_from_server_ps => 0
rows_buffered_from_client_normal => 0
rows_buffered_from_client_ps => 0
rows_fetched_from_client_normal_buffered => 0
rows_fetched_from_client_normal_unbuffered => 0
rows_fetched_from_client_ps_buffered => 0
rows_fetched_from_client_ps_unbuffered => 0
rows_fetched_from_client_ps_cursor => 0
rows_affected_normal => 0
rows_affected_ps => 0
rows_skipped_normal => 0
rows_skipped_ps => 0
copy_on_write_saved => 0
copy_on_write_performed => 0
command_buffer_too_small => 0
connect_success => 0
connect_failure => 0
connection_reused => 0
reconnect => 0
pconnect_success => 0
active_connections => 0
active_persistent_connections => 0
explicit_close => 0
implicit_close => 0
disconnect_close => 0
in_middle_of_command_close => 0
explicit_free_result => 0
implicit_free_result => 0
explicit_stmt_close => 0
implicit_stmt_close => 0
mem_emalloc_count => 0
mem_emalloc_amount => 0
mem_ecalloc_count => 0
mem_ecalloc_amount => 0
mem_erealloc_count => 0
mem_erealloc_amount => 0
mem_efree_count => 0
mem_efree_amount => 0
mem_malloc_count => 0
mem_malloc_amount => 0
mem_calloc_count => 0
mem_calloc_amount => 0
mem_realloc_count => 0
mem_realloc_amount => 0
mem_free_count => 0
mem_free_amount => 0
mem_estrndup_count => 0
mem_strndup_count => 0
mem_estrdup_count => 0
mem_strdup_count => 0
mem_edupl_count => 0
mem_dupl_count => 0
proto_text_fetched_null => 0
proto_text_fetched_bit => 0
proto_text_fetched_tinyint => 0
proto_text_fetched_short => 0
proto_text_fetched_int24 => 0
proto_text_fetched_int => 0
proto_text_fetched_bigint => 0
proto_text_fetched_decimal => 0
proto_text_fetched_float => 0
proto_text_fetched_double => 0
proto_text_fetched_date => 0
proto_text_fetched_year => 0
proto_text_fetched_time => 0
proto_text_fetched_datetime => 0
proto_text_fetched_timestamp => 0
proto_text_fetched_string => 0
proto_text_fetched_blob => 0
proto_text_fetched_enum => 0
proto_text_fetched_set => 0
proto_text_fetched_geometry => 0
proto_text_fetched_other => 0
proto_binary_fetched_null => 0
proto_binary_fetched_bit => 0
proto_binary_fetched_tinyint => 0
proto_binary_fetched_short => 0
proto_binary_fetched_int24 => 0
proto_binary_fetched_int => 0
proto_binary_fetched_bigint => 0
proto_binary_fetched_decimal => 0
proto_binary_fetched_float => 0
proto_binary_fetched_double => 0
proto_binary_fetched_date => 0
proto_binary_fetched_year => 0
proto_binary_fetched_time => 0
proto_binary_fetched_datetime => 0
proto_binary_fetched_timestamp => 0
proto_binary_fetched_string => 0
proto_binary_fetched_json => 0
proto_binary_fetched_blob => 0
proto_binary_fetched_enum => 0
proto_binary_fetched_set => 0
proto_binary_fetched_geometry => 0
proto_binary_fetched_other => 0
init_command_executed_count => 0
init_command_failed_count => 0
com_quit => 0
com_init_db => 0
com_query => 0
com_field_list => 0
com_create_db => 0
com_drop_db => 0
com_refresh => 0
com_shutdown => 0
com_statistics => 0
com_process_info => 0
com_connect => 0
com_process_kill => 0
com_debug => 0
com_ping => 0
com_time => 0
com_delayed_insert => 0
com_change_user => 0
com_binlog_dump => 0
com_table_dump => 0
com_connect_out => 0
com_register_slave => 0
com_stmt_prepare => 0
com_stmt_execute => 0
com_stmt_send_long_data => 0
com_stmt_close => 0
com_stmt_reset => 0
com_stmt_set_option => 0
com_stmt_fetch => 0
com_deamon => 0
bytes_received_real_data_normal => 0
bytes_received_real_data_ps => 0
pcre
PCRE (Perl Compatible Regular Expressions) Support => enabled
PCRE Library Version => 8.38 2015-11-23
PCRE JIT Support => enabled
pcre.backtrack_limit => 1000000 => 1000000
pcre.jit => 1 => 1
pcre.recursion_limit => 100000 => 100000
PDO
PDO support => enabled
PDO drivers =>
Phar
Phar: PHP Archive support => enabled
Phar EXT version => 2.0.2
Phar API version => 1.1.1
SVN revision => $Id: 81596423ffe39dd3d0a0432acb536431a8ece4a7 $
Phar-based phar archives => enabled
Tar-based phar archives => enabled
ZIP-based phar archives => enabled
gzip compression => enabled
bzip2 compression => disabled (install pecl/bz2)
OpenSSL support => disabled (install ext/openssl)
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list => no value => no value
phar.readonly => On => On
phar.require_hash => On => On
readline
Readline Support => enabled
Readline library => WinEditLine
cli.pager => no value => no value
cli.prompt => \b \>  => \b \>
Reflection
Reflection => enabled
Version => $Id: 1169bb682cad04b7bbd318db9d45ba1f61652a38 $
session
Session Support => enabled
Registered save handlers => files user
Registered serializer handlers => php_serialize php php_binary wddx
session.auto_start => Off => Off
session.cache_expire => 180 => 180
session.cache_limiter => nocache => nocache
session.cookie_domain => no value => no value
session.cookie_httponly => Off => Off
session.cookie_lifetime => 0 => 0
session.cookie_path => / => /
session.cookie_secure => Off => Off
session.gc_divisor => 1000 => 1000
session.gc_maxlifetime => 1440 => 1440
session.gc_probability => 1 => 1
session.lazy_write => On => On
session.name => PHPSESSID => PHPSESSID
session.referer_check => no value => no value
session.save_handler => files => files
session.save_path => no value => no value
session.serialize_handler => php => php
session.sid_bits_per_character => 5 => 5
session.sid_length => 26 => 26
session.upload_progress.cleanup => On => On
session.upload_progress.enabled => On => On
session.upload_progress.freq => 1% => 1%
session.upload_progress.min_freq => 1 => 1
session.upload_progress.name => PHP_SESSION_UPLOAD_PROGRESS => PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix => upload_progress_ => upload_progress_
session.use_cookies => On => On
session.use_only_cookies => On => On
session.use_strict_mode => On => On
session.use_trans_sid => 0 => 0
SimpleXML
Simplexml support => enabled
Revision => $Id: 7870377687a27bedb19e5ca689b798e93a222a29 $
Schema support => enabled
SPL
SPL support => enabled
Interfaces => Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support => enabled
Internal Sendmail Support for Windows => enabled
assert.active => 1 => 1
assert.bail => 0 => 0
assert.callback => no value => no value
assert.exception => 0 => 0
assert.quiet_eval => 0 => 0
assert.warning => 1 => 1
auto_detect_line_endings => 0 => 0
default_socket_timeout => 60 => 60
session.trans_sid_hosts => no value => no value
session.trans_sid_tags => a=href,area=href,frame=src,form= => a=href,area=href,frame=src,form=
url_rewriter.hosts => no value => no value
url_rewriter.tags => form= => form=
user_agent => no value => no value
tokenizer
Tokenizer Support => enabled
wddx
WDDX Support => enabled
WDDX Session Serializer => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.4
xmlreader
XMLReader => enabled
xmlwriter
XMLWriter => enabled
zip
Zip => enabled
Zip version => 1.13.5
Libzip version => 1.1.2
zlib
ZLib Support => enabled
Stream Wrapper => compress.zlib://
Stream Filter => zlib.inflate, zlib.deflate
Compiled Version => 1.2.8
Linked Version => 1.2.8
zlib.output_compression => Off => Off
zlib.output_compression_level => -1 => -1
zlib.output_handler => no value => no value
Additional Modules
Module Name
Environment
Variable => Value
ALLUSERSPROFILE => C:\ProgramData
APPDATA => C:\Users\Jan\AppData\Roaming
asl.log => Destination=file
CommonProgramFiles => C:\Program Files (x86)\Common Files
CommonProgramFiles(x86) => C:\Program Files (x86)\Common Files
CommonProgramW6432 => C:\Program Files\Common Files
COMPUTERNAME => JAN-PC
ComSpec => C:\Windows\system32\cmd.exe
CUDA_PATH => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
CUDA_PATH_V6_5 => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
FP_NO_HOST_CHECK => NO
HOMEDRIVE => C:
HOMEPATH => \Users\Jan
LOCALAPPDATA => C:\Users\Jan\AppData\Local
LOGONSERVER => \\JAN-PC
NUMBER_OF_PROCESSORS => 4
NVCUDASAMPLES6_5_ROOT => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
NVCUDASAMPLES_ROOT => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
OS => Windows_NT
Path => c:\program files\nvidia gpu computing toolkit\cuda\v6.5\bin;c:\program files\nvidia gpu computing toolkit\cuda\v6.5\libnvvp;c:\program files (x86)\intel\icls client\;c:\program files\intel\icls client\;c:\program files (x86)\common files\microsoft shared\windows live;c:\programdata\oracle\java\javapath;c:\program files (x86)\google\chrome\application;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0\;c:\program files (x86)\common files\apple\mobile device support\;c:\program files (x86)\common files\apple\apple application support;c:\program files\microsoft sql server\110\tools\binn\;c:\program files\intel\intel(r) management engine components\dal;c:\program files\intel\intel(r) management engine components\ipt;c:\program files (x86)\intel\intel(r) management engine components\dal;c:\program files (x86)\intel\intel(r) management engine components\ipt;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Anwendung\Skype\Phone\;C:\Program Files (x86)\QuickTime\QTSystem\;D:\Programmieren\Git\cmd;D:\Anwendung\PHP 7;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
PATHEXT => .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PP22_EXE4J_JAVA_HOME => C:\Program Files (x86)\Java\jre1.8.0_25
PROCESSOR_ARCHITECTURE => x86
PROCESSOR_ARCHITEW6432 => AMD64
PROCESSOR_IDENTIFIER => Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
PROCESSOR_LEVEL => 6
PROCESSOR_REVISION => 3a09
ProgramData => C:\ProgramData
PSModulePath => C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC => C:\Users\Public
SESSIONNAME => Console
SystemDrive => C:
SystemRoot => C:\Windows
TEMP => C:\Users\Jan\AppData\Local\Temp
TMP => C:\Users\Jan\AppData\Local\Temp
USERDOMAIN => Jan-PC
USERNAME => Jan
USERPROFILE => C:\Users\Jan
windir => C:\Windows
windows_tracing_flags => 3
windows_tracing_logfile => C:\BVTBin\Tests\installpackage\csilogfile.log
PHP Variables
Variable => Value
$_SERVER['ALLUSERSPROFILE'] => C:\ProgramData
$_SERVER['APPDATA'] => C:\Users\Jan\AppData\Roaming
$_SERVER['asl_log'] => Destination=file
$_SERVER['CommonProgramFiles'] => C:\Program Files (x86)\Common Files
$_SERVER['CommonProgramFiles(x86)'] => C:\Program Files (x86)\Common Files
$_SERVER['CommonProgramW6432'] => C:\Program Files\Common Files
$_SERVER['COMPUTERNAME'] => JAN-PC
$_SERVER['ComSpec'] => C:\Windows\system32\cmd.exe
$_SERVER['CUDA_PATH'] => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
$_SERVER['CUDA_PATH_V6_5'] => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
$_SERVER['FP_NO_HOST_CHECK'] => NO
$_SERVER['HOMEDRIVE'] => C:
$_SERVER['HOMEPATH'] => \Users\Jan
$_SERVER['LOCALAPPDATA'] => C:\Users\Jan\AppData\Local
$_SERVER['LOGONSERVER'] => \\JAN-PC
$_SERVER['NUMBER_OF_PROCESSORS'] => 4
$_SERVER['NVCUDASAMPLES6_5_ROOT'] => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
$_SERVER['NVCUDASAMPLES_ROOT'] => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
$_SERVER['OS'] => Windows_NT
$_SERVER['Path'] => c:\program files\nvidia gpu computing toolkit\cuda\v6.5\bin;c:\program files\nvidia gpu computing toolkit\cuda\v6.5\libnvvp;c:\program files (x86)\intel\icls client\;c:\program files\intel\icls client\;c:\program files (x86)\common files\microsoft shared\windows live;c:\programdata\oracle\java\javapath;c:\program files (x86)\google\chrome\application;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0\;c:\program files (x86)\common files\apple\mobile device support\;c:\program files (x86)\common files\apple\apple application support;c:\program files\microsoft sql server\110\tools\binn\;c:\program files\intel\intel(r) management engine components\dal;c:\program files\intel\intel(r) management engine components\ipt;c:\program files (x86)\intel\intel(r) management engine components\dal;c:\program files (x86)\intel\intel(r) management engine components\ipt;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Anwendung\Skype\Phone\;C:\Program Files (x86)\QuickTime\QTSystem\;D:\Programmieren\Git\cmd;D:\Anwendung\PHP 7;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
$_SERVER['PATHEXT'] => .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
$_SERVER['PP22_EXE4J_JAVA_HOME'] => C:\Program Files (x86)\Java\jre1.8.0_25
$_SERVER['PROCESSOR_ARCHITECTURE'] => x86
$_SERVER['PROCESSOR_ARCHITEW6432'] => AMD64
$_SERVER['PROCESSOR_IDENTIFIER'] => Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
$_SERVER['PROCESSOR_LEVEL'] => 6
$_SERVER['PROCESSOR_REVISION'] => 3a09
$_SERVER['ProgramData'] => C:\ProgramData
$_SERVER['ProgramFiles'] => C:\Program Files (x86)
$_SERVER['ProgramFiles(x86)'] => C:\Program Files (x86)
$_SERVER['ProgramW6432'] => C:\Program Files
$_SERVER['PSModulePath'] => C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
$_SERVER['PUBLIC'] => C:\Users\Public
$_SERVER['SESSIONNAME'] => Console
$_SERVER['SystemDrive'] => C:
$_SERVER['SystemRoot'] => C:\Windows
$_SERVER['TEMP'] => C:\Users\Jan\AppData\Local\Temp
$_SERVER['TMP'] => C:\Users\Jan\AppData\Local\Temp
$_SERVER['USERDOMAIN'] => Jan-PC
$_SERVER['USERNAME'] => Jan
$_SERVER['USERPROFILE'] => C:\Users\Jan
$_SERVER['windir'] => C:\Windows
$_SERVER['windows_tracing_flags'] => 3
$_SERVER['windows_tracing_logfile'] => C:\BVTBin\Tests\installpackage\csilogfile.log
$_SERVER['PHP_SELF'] => C:\Users\Jan\PhpstormProjects\censored\Test.php
$_SERVER['SCRIPT_NAME'] => C:\Users\Jan\PhpstormProjects\censored\Test.php
$_SERVER['SCRIPT_FILENAME'] => C:\Users\Jan\PhpstormProjects\censored\Test.php
$_SERVER['PATH_TRANSLATED'] => C:\Users\Jan\PhpstormProjects\censored\Test.php
$_SERVER['DOCUMENT_ROOT'] =>
$_SERVER['REQUEST_TIME_FLOAT'] => 1483376749.589
$_SERVER['REQUEST_TIME'] => 1483376749
$_SERVER['argv'] => Array
    [0] => C:\Users\Jan\PhpstormProjects\censored\Test.php
$_SERVER['argc'] => 1
PHP License
This program is free software; you can redistribute it and/or modify
it under the terms of the PHP License as published by the PHP Group
and included in the distribution in the file:  LICENSE
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any
questions about PHP licensing, please contact license@php.net.
Vielen Dank und MfG!
Schaut also danach aus als wäre es nicht geladen. Sicher das du die richtige PHP.ini erwischt hast?
Ggf. mal unter C:\Windows\ schauen: Configuration File (php.ini) Path => C:\Windows
Bei XAMP Installationen hab ich das schon gesehen das die von dort genommen wurde, obwohl bei Loaded was anderes steht.
In Stackoverflow war noch einer der meinte das allow_url_include = On neben allow_url_fopen = On nötig ist. Aber das kannst du ja schnell testen.
Wurde der Server nach der Konfigurationsänderung neu gestartet?
Ich habe mal jetzt noch angeschaltet. Geht aber trotzdem nicht... - Ist die richtige PHP.ini Datei!
Da ich PHPStorm benutzte, habe ich ja keinen externen Server installiert... Habe das Programm halt neu gestartet. Bekomme jetzt aber:
Code:
PHP Startup: Unable to load dynamic library 'C:\php\ext\php_openssl.dll' - Das angegebene Modul wurde nicht gefunden.
Okay, geht jetzt. Habe den Pfad mal angelegt und den Ordner ext mit dem dll da mal reinkopiert. Allerdings habe ich dazu eine Frage.
Wie kann ich PHP Storm sagen, dass diese dll im Installationsordner liegt?
In der php.ini
Code:
