ich habe seit gestern ein Problem mit meinem IE6 (auf IE7 will ich nicht upgraden).
Seit gestern mittag habe ich Probleme eine Seite aufzurufen. (MSN, EMAIL,Skype, funktionieren tadelos).
Es kommt immer der Hinweis:
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
habe ich mir halt Morzilla installiert --> gleiches Problem:
The connection was reset
The connection to the server was reset while the page was loading.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
Was das erstaunlichste daran ist: wenn ich oft genug Refresh drücke, erscheinen die Seite (auf IE wie auf Morzilla) Beim installieren von Morzilla habe ich extra aufgepasst nichts vom IE zu übernehmen.
Wie gesagt Internet funzt tadelos, nur die HP-Seiten lassen sich nicht direkt aufrufen.
Einer eine Idee?
PS:Ich habe XP und nichts verstellt.
Internet Explorer
moments.
connection.
Einer eine Idee?
