iperf3: TCP in schneller als TCP out
oicfar
Captain
Juni 2020
Hi, habe nach langer Zeit mal wieder iperf3 laufen lassen.
Die Messung läuft zwischen zwei NUCs, die am gleichen Switch (TP-Link TL-SG108) hängen.
NUC1:
  • OS: Ubuntu 22.04.3 LTS x86_64
  • Host: NUC11ATKC4
  • Kernel: 6.2.0-39-generic
  • CPU: Intel Celeron N5105 (4) @ 2.900GHz
  • Memory: 32GB
  • Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
    • driver=r8169 driverversion=6.2.0-39-generic duplex=full firmware=rtl8168h-2_0.0.2
  • BIOS: ATJSLCPX.0042.2023.0809.1538
  • iperf 3.9 (cJSON 1.7.13)
Code:
Settings for eno1:
    Supported ports: [ TP     MII ]
    Supported link modes:   10baseT/Half 10baseT/Full
                            100baseT/Half 100baseT/Full
                            1000baseT/Full
    Supported pause frame use: Symmetric Receive-only
    Supports auto-negotiation: Yes
    Supported FEC modes: Not reported
    Advertised link modes:  10baseT/Half 10baseT/Full
                            1000baseT/Full
    Advertised pause frame use: Symmetric Receive-only
    Advertised auto-negotiation: Yes
    Advertised FEC modes: Not reported
    Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                         1000baseT/Full
    Link partner advertised pause frame use: Symmetric
    Link partner advertised auto-negotiation: Yes
    Link partner advertised FEC modes: Not reported
    Speed: 1000Mb/s
    Duplex: Full
    Auto-negotiation: on
    master-slave cfg: preferred slave
    master-slave status: slave
    Port: Twisted Pair
    PHYAD: 0
    Transceiver: external
    MDI-X: Unknown
    Supports Wake-on: pumbg
    Wake-on: d
    Link detected: yes
NUC2:
  • Host: NUC8i5BEH
  • CPU: Intel i5-8259U (8) @ 3.800GHz
  • Memory: 32GB
  • Ethernet controller: Intel Corporation Ethernet Connection (6) I219-V (rev 30)
    • driver=e1000e driverversion=6.2.0-39-generic duplex=full firmware=0.4-4
  • BIOS: BECFL357.86A.0095.2023.0918.1953
Code:
Settings for eno1:
    Supported ports: [ TP ]
                            1000baseT/Full
    Supported pause frame use: No
                            1000baseT/Full
    Advertised pause frame use: No
    Speed: 1000Mb/s
    Duplex: Full
    Port: Twisted Pair
    PHYAD: 1
    Transceiver: internal
    MDI-X: off (auto)
    Wake-on: g
        Current message level: 0x00000007 (7)
                               drv probe link
    Link detected: yes
Code:
24 packets transmitted, 24 received, 0% packet loss, time 23296ms
rtt min/avg/max/mdev = 0.288/0.987/2.206/0.730 ms
Auf beiden starte ich
Code:
iperf3 -s
UDP sieht soweit gleich aus.
Code:
[ ID] Interval           Transfer     Bitrate         Total Datagrams
[  5]   0.00-10.00  sec  1.25 MBytes  1.05 Mbits/sec  906
[  5]  10.00-20.00  sec  1.25 MBytes  1.05 Mbits/sec  905
[  5]  20.00-30.00  sec  1.25 MBytes  1.05 Mbits/sec  905
[  5]  30.00-40.00  sec  1.25 MBytes  1.05 Mbits/sec  905
[  5]  40.00-50.00  sec  1.25 MBytes  1.05 Mbits/sec  905
[  5]  50.00-60.00  sec  1.25 MBytes  1.05 Mbits/sec  906
[ ID] Interval           Transfer     Bitrate         Jitter    Lost/Total Datagrams
[  5]   0.00-60.00  sec  7.50 MBytes  1.05 Mbits/sec  0.000 ms  0/5432 (0%)  sender
[  5]   0.00-60.04  sec  7.50 MBytes  1.05 Mbits/sec  0.275 ms  0/5431 (0%)  receiver
Code:
[  5]   0.00-60.04  sec  7.50 MBytes  1.05 Mbits/sec  0.233 ms  0/5431 (0%)  receiver
Frage mich, wieso es beim TCP nicht gleich aussieht.
Code:
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-10.00  sec   885 MBytes   742 Mbits/sec    0    607 KBytes
[  5]  10.00-20.00  sec   882 MBytes   740 Mbits/sec    0    607 KBytes
[  5]  20.00-30.00  sec   879 MBytes   737 Mbits/sec    0    607 KBytes
[  5]  30.00-40.00  sec   879 MBytes   737 Mbits/sec    0    930 KBytes
[  5]  40.00-50.00  sec   876 MBytes   735 Mbits/sec    0    930 KBytes
[  5]  50.00-60.00  sec   878 MBytes   736 Mbits/sec    0    930 KBytes
[  5]   0.00-60.00  sec  5.15 GBytes   738 Mbits/sec    0             sender
[  5]   0.00-60.04  sec  5.15 GBytes   737 Mbits/sec                  receiver
Code:
[  5]   0.00-10.00  sec  1.09 GBytes   935 Mbits/sec    0    397 KBytes
[  5]  10.00-20.00  sec  1.09 GBytes   935 Mbits/sec    0    574 KBytes
[  5]  20.00-30.00  sec  1.09 GBytes   935 Mbits/sec    0   1.24 MBytes
[  5]  30.00-40.00  sec  1.09 GBytes   934 Mbits/sec    0   1.24 MBytes
[  5]  40.00-50.00  sec  1.09 GBytes   934 Mbits/sec    0   1.24 MBytes
[  5]  50.00-60.00  sec  1.09 GBytes   934 Mbits/sec    0   1.24 MBytes
[  5]   0.00-60.00  sec  6.53 GBytes   935 Mbits/sec    0             sender
[  5]   0.00-60.04  sec  6.53 GBytes   934 Mbits/sec                  receiver
Habe noch 10GB Datei mit scp kopiert.
Code:
cat /proc/sys/net/ipv4/tcp_window_scaling
1
Code:
10gb.img     100%   10GB 100.3MB/s   01:42
Code:
10gb.img   100%   10GB 110.9MB/s   01:32
Das Gleiche beobachte ich von anderem NUC mit Intel Pentium Silver N6005 (4) @ 3.300GHz der an anderen Switch hängt.
Ich versuche rauszubekommen/verstehen wieso raus es nur ~200Mbits weniger läuft.
Wenn
der Grund sein sollte, wieso es rein schnell geht.
OK, es wird wohl am RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller liegen. Die NUCs, die den Ethernet Controller haben, performen hier nicht so gut.
