PEASANT KING
- Okt. 2008
Hallo Leute,
ich habe mir ein kleines Applet geschrieben allerdings weist es Fehler auf, zumindest wenn ich es im Browser starte hier mal der Code:
Beim Aufruf im Browser bekomme ich die Meldung:
Allerdings verstehe ich nicht so ganz weshalb...
Grüße DJ
PHP:
import java.awt.event.ActionEvent;
import java.io.DataInputStream;
import java.io.IOException;
import java.io.PrintStream;
import java.net.Socket;
* To change this template, choose Tools | Templates
* and open the template in the editor.
* GFMChatApplet.java
* Created on 07.07.2011, 09:20:41
* @author *****
public class GFMChatApplet extends javax.swing.JApplet implements Runnable {
private static final long serialVersionUID = 1L;
public static final int PORT = 8765;
Socket socket;
DataInputStream in;
PrintStream out;
Thread thread;
/** Initializes the applet GFMChatApplet */
public void init() {
try {
java.awt.EventQueue.invokeAndWait(new Runnable() {
public void run() {
initComponents();
catch (Exception ex) {
ex.printStackTrace();
System.err.println("createGUI didn't successfully complete");
/** This method is called from within the init() method to
* initialize the form.
* WARNING: Do NOT modify this code. The content of this method is
* always regenerated by the Form Editor.
@SuppressWarnings("unchecked")
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
sendButton = new javax.swing.JButton();
jScrollPane1 = new javax.swing.JScrollPane();
outputField = new javax.swing.JTextArea();
inputField = new javax.swing.JTextField();
sendButton.setText("Senden");
outputField.setColumns(20);
outputField.setEditable(false);
outputField.setRows(5);
jScrollPane1.setViewportView(outputField);
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup()
.addContainerGap()
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.TRAILING)
.addComponent(jScrollPane1, javax.swing.GroupLayout.Alignment.LEADING, javax.swing.GroupLayout.DEFAULT_SIZE, 380, Short.MAX_VALUE)
.addGroup(layout.createSequentialGroup()
.addComponent(inputField, javax.swing.GroupLayout.DEFAULT_SIZE, 305, Short.MAX_VALUE)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
.addComponent(sendButton)))
.addContainerGap())
layout.setVerticalGroup(
.addContainerGap()
.addComponent(jScrollPane1, javax.swing.GroupLayout.DEFAULT_SIZE, 249, Short.MAX_VALUE)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(inputField, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE))
.addContainerGap())
}// </editor-fold>
// Variables declaration - do not modify
private javax.swing.JTextField inputField;
private javax.swing.JScrollPane jScrollPane1;
private javax.swing.JTextArea outputField;
private javax.swing.JButton sendButton;
// End of variables declaration
@Override
public void start() {
try {
socket = new Socket(this.getCodeBase().getHost(), PORT);
in = new DataInputStream(socket.getInputStream());
out = new PrintStream(socket.getOutputStream());
catch (IOException e) {
this.showStatus(e.toString());
say("Verbindung zum Server fehlgeschlagen!");
say("Verbindung zum Server aufgenommen..."); //Bemerkung java-forum.org: Sollte besser am Ende des try-Blockes stehen
if (thread == null) {
thread = new Thread(this);
thread.setPriority(Thread.MIN_PRIORITY);
thread.start();
@Override
public void run() {
String line;
try
while(true) {
line = in.readLine();
if(line!=null) {
outputField.append(line+'\n' );
say("Verbindung zum Server abgebrochen");
public boolean actionPerformed(ActionEvent e) {
if (e.getSource() == inputField) {
String inp= e.paramString();
out.println(inp);
inputField.setText("");
return true;
return false;
public void say(String msg) {
outputField.append("*** "+msg+" ***\n");
Code:
java.lang.reflect.InvocationTargetException
at com.sun.deploy.util.DeployAWTUtil.invokeAndWait(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.runOnEDT(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.security.AccessControlException: access denied (java.lang.RuntimePermission exitVM.0)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkExit(Unknown Source)
at javax.swing.JFrame.setDefaultCloseOperation(Unknown Source)
at GFMChatView.initComponents(GFMChatView.java:38)
at GFMChatView.<init>(GFMChatView.java:20)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$12.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Ausnahme: java.lang.reflect.InvocationTargetException
Grüße DJ
