Auf meinem Laptop stürzt minecraft immer nach dem Login ab und hinterlässt diese Fehlermeldung, weisse einer was ich jetzt beheben kann dass es funktioniert
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x4ecebf40, pid=4336, tid=5412
# JRE version: 7.0_21-b11
# Java VM: Java HotSpot(TM) Client VM (23.21-b01 mixed mode windows-x86 )
# Problematic frame:
# C 0x4ecebf40
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x4acd2000): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=5412, stack(0x4cbd0000,0x4cc20000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x00000008 0x4ecebf40
Registers:
EAX=0x34a4e0c6, EBX=0x4e556200, ECX=0x4e50b780, EDX=0x00000004
ESP=0x4cc1f3b4, EBP=0x4e4f2f84, ESI=0x4e3eedc0, EDI=0x4cc1f404
EIP=0x4ecebf40, EFLAGS=0x00010246
Top of Stack: (sp=0x4cc1f3b4)
0x4cc1f3b4: 690d3b4b 4e556200 4e4f2f84 00000000
0x4cc1f3c4: 4cc1f46c 4eccd920 00000004 4e4f4190
0x4cc1f3d4: 4eccd110 00000030 00000000 ffffffff
0x4cc1f3e4: 00000001 00000004 00010000 4e50b780
0x4cc1f3f4: 4ecebf40 00000000 4e556200 4e3eedc0
0x4cc1f404: 34a4e0c6 00000050 4e4e5098 69078bee
0x4cc1f414: 4e4eeb90 4cc1f430 4ccd7ef0 4e4eeb88
0x4cc1f424: 69089144 4cc1f404 00000000 00001fa0
Instructions: (pc=0x4ecebf40)
0x4ecebf20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x4ecebf30: 00 00 00 00 fc be ce 4e e4 04 00 00 01 00 00 00
0x4ecebf40: 55 8b ec 53 56 57 8b d9 8b ca 8b 75 08 81 e1 fc
0x4ecebf50: ff ff ff 66 66 66 66 66 66 66 90 66 66 66 66 66
Register to memory mapping:
EAX=0x34a4e0c6 is an unallocated location in the heap
EBX=0x4e556200 is an unknown value
ECX=0x4e50b780 is an unknown value
EDX=0x00000004 is an unknown value
ESP=0x4cc1f3b4 is pointing into the stack for thread: 0x4acd2000
EBP=0x4e4f2f84 is an unknown value
ESI=0x4e3eedc0 is an unknown value
EDI=0x4cc1f404 is pointing into the stack for thread: 0x4acd2000
Stack: [0x4cbd0000,0x4cc20000], sp=0x4cc1f3b4, free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x4ecebf40
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.GL11.nglClear(IJ)V+0
j org.lwjgl.opengl.GL11.glClear(I)V+15
j org.lwjgl.opengl.Display.initContext()V+16
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribsV+97
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormatV+9
j net.minecraft.client.Minecraft.a()V+177
j avv.a()V+94
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x4acd2000 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=5412, stack(0x4cbd0000,0x4cc20000)]
0x4acd1800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=5404, stack(0x4a8d0000,0x4a920000)]
0x4acd0400 JavaThread "Snooper Timer" daemon [_thread_blocked, id=5396, stack(0x4a860000,0x4a8b0000)]
0x4acd1400 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=5392, stack(0x4a600000,0x4a650000)]
0x4ab43000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=4420, stack(0x4cb60000,0x4cbb0000)]
0x0186a800 JavaThread "DestroyJavaVM" [_thread_blocked, id=4344, stack(0x00a30000,0x00a80000)]
0x4aa39800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4416, stack(0x4c720000,0x4c770000)]
0x4a96b400 JavaThread "TimerQueue" daemon [_thread_blocked, id=4412, stack(0x4c680000,0x4c6d0000)]
0x4a9f0000 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=4408, stack(0x4c6d0000,0x4c720000)]
0x49cc7800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=4388, stack(0x4a350000,0x4a3a0000)]
0x49cc7000 JavaThread "AWT-Shutdown" [_thread_blocked, id=4384, stack(0x4a300000,0x4a350000)]
0x49c78800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4380, stack(0x4a2b0000,0x4a300000)]
0x49b6a800 JavaThread "Service Thread" daemon [_thread_blocked, id=4372, stack(0x49e10000,0x49e60000)]
0x49b5d800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4368, stack(0x49dc0000,0x49e10000)]
0x49b5c400 JavaThread "Attach Listener" daemon [_thread_blocked, id=4364, stack(0x49d70000,0x49dc0000)]
0x49b59c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4360, stack(0x49d20000,0x49d70000)]
0x01843800 JavaThread "Finalizer" daemon [_thread_blocked, id=4356, stack(0x49ad0000,0x49b20000)]
0x0183e800 JavaThread "Reference Handler" daemon [_thread_blocked, id=4352, stack(0x49a80000,0x49ad0000)]
Other Threads:
0x01838000 VMThread [stack: 0x49a30000,0x49a80000] [id=4348]
0x49b82c00 WatcherThread [stack: 0x49e60000,0x49eb0000] [id=4376]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 139776K [0x03870000, 0x0e310000, 0x18dc0000)
eden space 139776K, 100% used [0x03870000, 0x0c0f0000, 0x0c0f0000)
from space 17472K, 0% used [0x0c0f0000, 0x0c0f0000, 0x0d200000)
to space 17472K, 0% used [0x0d200000, 0x0d200000, 0x0e310000)
tenured generation total 349568K, used 0K [0x18dc0000, 0x2e320000, 0x43870000)
the space 349568K, 0% used [0x18dc0000, 0x18dc0000, 0x18dc0200, 0x2e320000)
compacting perm gen total 13568K, used 13516K [0x43870000, 0x445b0000, 0x47870000)
the space 13568K, 99% used [0x43870000, 0x445a3370, 0x445a3400, 0x445b0000)
No shared spaces configured.
Card table byte_map: [0x49670000,0x498a0000] byte_map_base: 0x49653c80
Polling page: 0x007e0000
Code Cache [0x01870000, 0x01b00000, 0x03870000)
total_blobs=1622 nmethods=1293 adapters=262 free_code_cache=30148Kb largest_free_block=30872192
Compilation events (10 events):
Event: 77.532 Thread 0x49b5d800 1283 java.util.WeakHashMap::remove (133 bytes)
Event: 77.533 Thread 0x49b5d800 nmethod 1283 0x01af86c8 code [0x01af8800, 0x01af8a64]
Event: 77.535 Thread 0x49b5d800 1285 sun.reflect.Reflection::quickCheckMemberAccess (10 bytes)
Event: 77.535 Thread 0x49b5d800 nmethod 1285 0x01af8f88 code [0x01af9080, 0x01af911c]
Event: 77.598 Thread 0x49b5d800 1286 java.security.MessageDigest::update (45 bytes)
Event: 77.599 Thread 0x49b5d800 nmethod 1286 0x01af9188 code [0x01af92b0, 0x01af9454]
Event: 77.637 Thread 0x49b5d800 1287 ! java.util.zip.ZipFile$ZipFileInputStream::close (110 bytes)
Event: 77.637 Thread 0x49b5d800 nmethod 1287 0x01af9588 code [0x01af96b0, 0x01af9b38]
Event: 77.690 Thread 0x49b5d800 1288 ! sun.security.util.ManifestEntryVerifier::setEntry (299 bytes)
Event: 77.692 Thread 0x49b5d800 nmethod 1288 0x01afd008 code [0x01afd300, 0x01afdd50]
GC Heap History (0 events):
No events
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 77.656 Thread 0x4acd2000 Threw 0x0bfe9ae8 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.656 Thread 0x4acd2000 Threw 0x0bfe9ea8 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.687 Thread 0x4acd2000 Threw 0x0c00aa30 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.687 Thread 0x4acd2000 Threw 0x0c00ae58 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.688 Thread 0x4acd2000 Threw 0x0c00ddd0 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.688 Thread 0x4acd2000 Threw 0x0c00e1c8 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.688 Thread 0x4acd2000 Threw 0x0c0112f8 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.688 Thread 0x4acd2000 Threw 0x0c011720 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.690 Thread 0x4acd2000 Threw 0x0c014d60 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 77.690 Thread 0x4acd2000 Threw 0x0c015120 at C:\jdk7u2_32P\jdk7u21\hotspot\src\share\vm\prims\jvm.cpp:1166
Events (10 events):
Event: 77.656 loading class 0x4d78a8b8
Event: 77.656 loading class 0x4d78a8b8 done
Event: 77.687 loading class 0x4acac668
Event: 77.687 loading class 0x4acac668 done
Event: 77.688 loading class 0x4d7887e8
Event: 77.688 loading class 0x4d7887e8 done
Event: 77.688 loading class 0x4acad158
Event: 77.688 loading class 0x4acad158 done
Event: 77.690 loading class 0x4ac3f4e8
Event: 77.690 loading class 0x4ac3f4e8 done
Dynamic libraries:
0x00b20000 - 0x00b4f000 C:\Program Files\Java\jre7\bin\javaw.exe
0x77aa0000 - 0x77c08000 C:\Windows\SYSTEM32\ntdll.dll
0x6bc90000 - 0x6bccf000 C:\Program Files\AVAST Software\Avast\snxhk.dll
0x75e80000 - 0x75f78000 C:\Windows\system32\KERNEL32.dll
0x75410000 - 0x754cd000 C:\Windows\system32\KERNELBASE.dll
0x75800000 - 0x758ae000 C:\Windows\system32\ADVAPI32.dll
0x756d0000 - 0x757f1000 C:\Windows\system32\USER32.dll
0x738f0000 - 0x73ae8000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16579_none_8937eec6860750f5\COMCTL32.dll
0x75f90000 - 0x76041000 C:\Windows\system32\msvcrt.dll
0x763e0000 - 0x76414000 C:\Windows\SYSTEM32\sechost.dll
0x76160000 - 0x76232000 C:\Windows\system32\RPCRT4.dll
0x76050000 - 0x7615a000 C:\Windows\system32\GDI32.dll
0x762e0000 - 0x7630b000 C:\Windows\system32\IMM32.DLL
0x76740000 - 0x7681d000 C:\Windows\system32\MSCTF.dll
0x5dd60000 - 0x5de1e000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x5da10000 - 0x5dd5f000 C:\Program Files\Java\jre7\bin\client\jvm.dll
0x70aa0000 - 0x70aa8000 C:\Windows\SYSTEM32\WSOCK32.dll
0x6a150000 - 0x6a171000 C:\Windows\SYSTEM32\WINMM.dll
0x77a90000 - 0x77a96000 C:\Windows\system32\PSAPI.DLL
0x76390000 - 0x763e0000 C:\Windows\system32\WS2_32.dll
0x6a120000 - 0x6a14a000 C:\Windows\SYSTEM32\WINMMBASE.dll
0x762d0000 - 0x762d8000 C:\Windows\system32\NSI.dll
0x5da00000 - 0x5da0c000 C:\Program Files\Java\jre7\bin\verify.dll
0x5d9e0000 - 0x5da00000 C:\Program Files\Java\jre7\bin\java.dll
0x5d9c0000 - 0x5d9d3000 C:\Program Files\Java\jre7\bin\zip.dll
0x5d870000 - 0x5d9b2000 C:\Program Files\Java\jre7\bin\awt.dll
0x76240000 - 0x762cb000 C:\Windows\system32\OLEAUT32.dll
0x75530000 - 0x75666000 C:\Windows\system32\combase.dll
0x719e0000 - 0x71a87000 C:\Windows\system32\apphelp.dll
0x74270000 - 0x74317000 C:\Windows\system32\uxtheme.dll
0x73b50000 - 0x73b69000 C:\Windows\SYSTEM32\dwmapi.dll
0x778f0000 - 0x77a09000 C:\Windows\system32\ole32.dll
0x74f20000 - 0x74f29000 C:\Windows\SYSTEM32\CRYPTBASE.dll
0x74ec0000 - 0x74f11000 C:\Windows\SYSTEM32\bcryptPrimitives.dll
0x76820000 - 0x778e6000 C:\Windows\system32\SHELL32.dll
0x75e40000 - 0x75e80000 C:\Windows\system32\SHLWAPI.dll
0x76310000 - 0x76385000 C:\Windows\SYSTEM32\shcore.dll
0x5d6b0000 - 0x5d865000 C:\Windows\system32\d3d9.dll
0x70ab0000 - 0x70ab8000 C:\Windows\SYSTEM32\VERSION.dll
0x72730000 - 0x72a06000 C:\Windows\SYSTEM32\atiumdag.dll
0x00010000 - 0x002c3000 C:\Windows\SYSTEM32\atiumdva.dll
0x5d670000 - 0x5d6a1000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x5d650000 - 0x5d664000 C:\Program Files\Java\jre7\bin\net.dll
0x74a30000 - 0x74a7a000 C:\Windows\system32\mswsock.dll
0x5d640000 - 0x5d64e000 C:\Program Files\Java\jre7\bin\nio.dll
0x6c5e0000 - 0x6c5f0000 C:\Windows\system32\napinsp.dll
0x6c5c0000 - 0x6c5d4000 C:\Windows\system32\pnrpnsp.dll
0x72f70000 - 0x72f80000 C:\Windows\system32\NLAapi.dll
0x748a0000 - 0x74915000 C:\Windows\SYSTEM32\DNSAPI.dll
0x6c5b0000 - 0x6c5b9000 C:\Windows\System32\winrnr.dll
0x71d40000 - 0x71d60000 C:\Windows\SYSTEM32\IPHLPAPI.DLL
0x71d20000 - 0x71d28000 C:\Windows\SYSTEM32\WINNSI.DLL
0x71770000 - 0x717af000 C:\Windows\System32\fwpuclnt.dll
0x6d120000 - 0x6d127000 C:\Windows\System32\rasadhlp.dll
0x74a80000 - 0x74a9a000 C:\Windows\SYSTEM32\CRYPTSP.dll
0x747e0000 - 0x7481e000 C:\Windows\system32\rsaenh.dll
0x749c0000 - 0x749db000 C:\Windows\SYSTEM32\USERENV.dll
0x75090000 - 0x750a1000 C:\Windows\SYSTEM32\profapi.dll
0x5d620000 - 0x5d640000 C:\Program Files\Java\jre7\bin\sunec.dll
0x77a10000 - 0x77a84000 C:\Windows\SYSTEM32\clbcatq.dll
0x737a0000 - 0x738eb000 C:\Windows\SYSTEM32\WindowsCodecs.dll
0x5d5f0000 - 0x5d620000 C:\Program Files\Java\jre7\bin\t2k.dll
0x5d5e0000 - 0x5d5e9000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x751a0000 - 0x75328000 C:\Windows\system32\CRYPT32.dll
0x75110000 - 0x75122000 C:\Windows\system32\MSASN1.dll
0x4a7f0000 - 0x4a85b000 C:\Users\Janis\AppData\Roaming\.minecraft\bin\natives\lwjgl.dll
0x63e40000 - 0x63f0e000 C:\Windows\SYSTEM32\OPENGL32.dll
0x6c0d0000 - 0x6c0f3000 C:\Windows\SYSTEM32\GLU32.dll
0x63d60000 - 0x63e39000 C:\Windows\SYSTEM32\DDRAW.dll
0x6c210000 - 0x6c217000 C:\Windows\SYSTEM32\DCIMAN32.dll
0x6c150000 - 0x6c156000 C:\Program Files\Java\jre7\bin\jawt.dll
0x69000000 - 0x69893000 C:\Windows\SYSTEM32\atioglxx.dll
0x64c60000 - 0x64d89000 C:\Windows\SYSTEM32\dbghelp.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\Janis\AppData\Roaming\.minecraft\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\AMD APP\bin\x86;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Java\jre7\bin
USERNAME=Janis
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 104 Stepping 2, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 8 Build 9200
CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 104 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnowpref, tsc
Memory: 4k page, physical 1964076k(1090824k free), swap 2619436k(1175212k free)
vm_info: Java HotSpot(TM) Client VM (23.21-b01) for windows-x86 JRE (1.7.0_21-b11), built on Apr 4 2013 04:43:10 by "java_re" with unknown MS VC++:1600
time: Wed Jun 05 20:36:34 2013
elapsed time: 77 seconds
