Leserartikel Jonsplus Z20 MATX Gehäuse mit Tragegriff und platz für ATX Netzteil
Status
nofuture
Sep. 2010
Soll bei caseking erhältlich sein bald
https://www.jonsplus.com/products/z20b.html
Z20 Tempered Glass Version Black​
High-performance hardware compatibility / compact design​
Building a compact desktop mini-host is fun, but also comes with many trade-offs. As the case size shrinks, conflicts such as compatibility, heat dissipation, and installation experience gradually increase, hence only a minority of users with ample experience possess a clear building strategy and assembly skills. In view of this, we constantly contemplate how to optimize the design to maintain a compact hardware layout, while enhancing the internal hardware compatibility, ultimately allowing more users to experience the practicality and joy of small form factor models.
● Main body dimensions 370mm*186mm*295mm (length/width/height, excluding handles/feet and other protrusions), only about 20L in volume
● Frame integrated bending, with plate thickness up to 2mm / Equipped with removable portable handle
● Compatible with a 60mm thickness (30mm radiator + fan) performance grade 240 water cooler or 160mm height dual-tower air cooler
● Supports high-performance graphics cards up to 363mm in length & full-size Micro-ATX motherboards
● In air-cooled mode, supports ATX power supplies at least 15cm in length; in water-cooled mode, supports ATX power supplies at least 14cm in length
● Optimized installation experience design: flexible and variable hardware combinations within a small space
Status
