[ 0.875930] pnp 00:0c: [mem 0xfec00000-0xffffffff]
[ 0.875966] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.875968] system 00:0c: [mem 0x000c0000-0x000cffff] has been reserved
[ 0.875970] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.875972] system 00:0c: [mem 0x00100000-0xcfffffff] could not be reserved
[ 0.875974] system 00:0c: [mem 0xfec00000-0xffffffff] could not be reserved
[ 0.875976] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.876052] pnp: PnP ACPI: found 13 devices
[ 0.876053] ACPI: ACPI bus type pnp unregistered
[ 0.881685] pci 0000:00:14.0: BAR 6: assigned [mem 0xf0000000-0xf00007ff pref]
[ 0.881688] pci 0000:00:02.0: PCI bridge to [bus 01-01]
[ 0.881690] pci 0000:00:02.0: bridge window [io 0xa000-0xafff]
[ 0.881693] pci 0000:00:02.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.881695] pci 0000:00:02.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.881698] pci 0000:03:01.0: PCI bridge to [bus 04-04]
[ 0.881700] pci 0000:03:01.0: bridge window [io disabled]
[ 0.881703] pci 0000:03:01.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.881706] pci 0000:03:01.0: bridge window [mem pref disabled]
[ 0.881710] pci 0000:03:02.0: PCI bridge to [bus 05-05]
[ 0.881712] pci 0000:03:02.0: bridge window [io 0xb000-0xcfff]
[ 0.881716] pci 0000:03:02.0: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.881718] pci 0000:03:02.0: bridge window [mem pref disabled]
[ 0.881722] pci 0000:02:00.0: PCI bridge to [bus 03-05]
[ 0.881724] pci 0000:02:00.0: bridge window [io 0xb000-0xcfff]
[ 0.881728] pci 0000:02:00.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.881730] pci 0000:02:00.0: bridge window [mem pref disabled]
[ 0.881734] pci 0000:00:03.0: PCI bridge to [bus 02-05]
[ 0.881736] pci 0000:00:03.0: bridge window [io 0xb000-0xcfff]
[ 0.881738] pci 0000:00:03.0: bridge window [mem 0xfe800000-0xfeafffff]
[ 0.881740] pci 0000:00:03.0: bridge window [mem pref disabled]
[ 0.881743] pci 0000:00:0a.0: PCI bridge to [bus 06-06]
[ 0.881744] pci 0000:00:0a.0: bridge window [io 0xd000-0xdfff]
[ 0.881747] pci 0000:00:0a.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.881749] pci 0000:00:0a.0: bridge window [mem pref disabled]
[ 0.881751] pci 0000:00:14.4: PCI bridge to [bus 07-07]
[ 0.881757] pci 0000:00:14.4: bridge window [io 0xe000-0xefff]
[ 0.881761] pci 0000:00:14.4: bridge window [mem disabled]
[ 0.881765] pci 0000:00:14.4: bridge window [mem pref disabled]
[ 0.881779] pci 0000:00:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.881782] pci 0000:00:02.0: setting latency timer to 64
[ 0.881787] pci 0000:00:03.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.881789] pci 0000:00:03.0: setting latency timer to 64
[ 0.881794] pci 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.881797] pci 0000:02:00.0: setting latency timer to 64
[ 0.881803] pci 0000:03:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.881806] pci 0000:03:01.0: setting latency timer to 64
[ 0.881811] pci 0000:03:02.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.881814] pci 0000:03:02.0: setting latency timer to 64
[ 0.881818] pci 0000:00:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.881820] pci 0000:00:0a.0: setting latency timer to 64
[ 0.881826] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.881827] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.881829] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.881830] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.881832] pci_bus 0000:00: resource 8 [mem 0xd0000000-0xdfffffff]
[ 0.881833] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.881835] pci_bus 0000:01: resource 0 [io 0xa000-0xafff]
[ 0.881836] pci_bus 0000:01: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 0.881838] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.881840] pci_bus 0000:02: resource 0 [io 0xb000-0xcfff]
[ 0.881841] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfeafffff]
[ 0.881843] pci_bus 0000:03: resource 0 [io 0xb000-0xcfff]
[ 0.881844] pci_bus 0000:03: resource 1 [mem 0xfe900000-0xfeafffff]
[ 0.881846] pci_bus 0000:04: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.881848] pci_bus 0000:05: resource 0 [io 0xb000-0xcfff]
[ 0.881849] pci_bus 0000:05: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.881851] pci_bus 0000:06: resource 0 [io 0xd000-0xdfff]
[ 0.881852] pci_bus 0000:06: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.881854] pci_bus 0000:07: resource 0 [io 0xe000-0xefff]
[ 0.881855] pci_bus 0000:07: resource 4 [io 0x0000-0x0cf7]
[ 0.881857] pci_bus 0000:07: resource 5 [io 0x0d00-0xffff]
[ 0.881858] pci_bus 0000:07: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.881860] pci_bus 0000:07: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.881861] pci_bus 0000:07: resource 8 [mem 0xd0000000-0xdfffffff]
[ 0.881863] pci_bus 0000:07: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.881886] NET: Registered protocol family 2
[ 0.882053] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.883191] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.885583] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.885870] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.885872] TCP reno registered
[ 0.885884] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.885935] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.886052] NET: Registered protocol family 1
[ 1.040050] pci 0000:01:00.0: Boot video device
[ 1.040115] PCI: CLS 64 bytes, default 64
[ 1.041439] PCI-DMA: Disabling AGP.
[ 1.041526] PCI-DMA: aperture base @ c4000000 size 65536 KB
[ 1.041528] PCI-DMA: using GART IOMMU.
[ 1.041530] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 1.044929] audit: initializing netlink socket (disabled)
[ 1.044943] type=2000 audit(1308305605.039:1): initialized
[ 1.054118] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.055280] VFS: Disk quotas dquot_6.5.2
[ 1.055314] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.055778] fuse init (API version 7.16)
[ 1.055829] msgmni has been set to 15998
[ 1.056038] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.056067] io scheduler noop registered
[ 1.056068] io scheduler deadline registered
[ 1.056094] io scheduler cfq registered (default)
[ 1.056211] pcieport 0000:00:02.0: setting latency timer to 64
[ 1.056239] pcieport 0000:00:02.0: irq 40 for MSI/MSI-X
[ 1.056323] pcieport 0000:00:03.0: setting latency timer to 64
[ 1.056340] pcieport 0000:00:03.0: irq 41 for MSI/MSI-X
[ 1.056410] pcieport 0000:00:0a.0: setting latency timer to 64
[ 1.056428] pcieport 0000:00:0a.0: irq 42 for MSI/MSI-X
[ 1.056500] pcieport 0000:02:00.0: setting latency timer to 64
[ 1.056528] pcieport 0000:02:00.0: irq 43 for MSI/MSI-X
[ 1.056609] pcieport 0000:03:01.0: setting latency timer to 64
[ 1.056637] pcieport 0000:03:01.0: irq 44 for MSI/MSI-X
[ 1.056721] pcieport 0000:03:02.0: setting latency timer to 64
[ 1.056749] pcieport 0000:03:02.0: irq 45 for MSI/MSI-X
[ 1.056816] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.056830] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.056923] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 1.190038] ACPI: Power Button [PWRB]
[ 1.190085] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.190088] ACPI: Power Button [PWRF]
[ 1.190203] ACPI: acpi_idle registered with cpuidle
[ 1.191272] ERST: Table is not found!
[ 1.191318] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.430251] Linux agpgart interface v0.103
[ 1.430924] brd: module loaded
[ 1.431229] loop: module loaded
[ 1.431284] i2c-core: driver [adp5520] using legacy suspend method
[ 1.431286] i2c-core: driver [adp5520] using legacy resume method
[ 1.431435] pata_acpi 0000:00:14.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.431458] pata_acpi 0000:00:14.1: setting latency timer to 64
[ 1.431695] Fixed MDIO Bus: probed
[ 1.431715] PPP generic driver version 2.4.2
[ 1.431737] tun: Universal TUN/TAP device driver, 1.6
[ 1.431739] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.431786] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.431827] ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.431848] ehci_hcd 0000:00:12.2: EHCI Host Controller
[ 1.431889] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.510047] ehci_hcd 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.510060] ehci_hcd 0000:00:12.2: applying AMD SB600/SB700 USB freeze workaround
[ 1.510072] ehci_hcd 0000:00:12.2: debug port 1
[ 1.510094] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfe6ff000
[ 1.530033] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.530131] hub 1-0:1.0: USB hub found
[ 1.530134] hub 1-0:1.0: 6 ports detected
[ 1.530267] ehci_hcd 0000:00:13.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.530279] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 1.530304] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 1.530331] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.530341] ehci_hcd 0000:00:13.2: applying AMD SB600/SB700 USB freeze workaround
[ 1.530352] ehci_hcd 0000:00:13.2: debug port 1
[ 1.530370] ehci_hcd 0000:00:13.2: irq 19, io mem 0xfe6fa800
[ 1.550030] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.550109] hub 2-0:1.0: USB hub found
[ 1.550111] hub 2-0:1.0: 6 ports detected
[ 1.550192] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.550264] ohci_hcd 0000:00:12.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.550275] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 1.550299] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 3
[ 1.550342] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfe6fe000
[ 1.614119] hub 3-0:1.0: USB hub found
[ 1.614128] hub 3-0:1.0: 3 ports detected
[ 1.614256] ohci_hcd 0000:00:12.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.614267] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 1.614296] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 4
[ 1.614327] ohci_hcd 0000:00:12.1: irq 16, io mem 0xfe6fd000
[ 1.674118] hub 4-0:1.0: USB hub found
[ 1.674127] hub 4-0:1.0: 3 ports detected
[ 1.674252] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.674264] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 1.674288] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 1.674327] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfe6fc000
[ 1.734132] hub 5-0:1.0: USB hub found
[ 1.734141] hub 5-0:1.0: 3 ports detected
[ 1.734264] ohci_hcd 0000:00:13.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.734277] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 1.734299] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 6
[ 1.734330] ohci_hcd 0000:00:13.1: irq 18, io mem 0xfe6fb000
[ 1.794151] hub 6-0:1.0: USB hub found
[ 1.794159] hub 6-0:1.0: 3 ports detected
[ 1.794283] ohci_hcd 0000:00:14.5: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.794294] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 1.794319] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 7
[ 1.794350] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfe6f9000
[ 1.850047] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 1.854130] hub 7-0:1.0: USB hub found
[ 1.854139] hub 7-0:1.0: 2 ports detected
[ 1.854206] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.930057] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.930059] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.930182] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.930245] mousedev: PS/2 mouse device common for all mice
[ 1.930323] rtc_cmos 00:03: RTC can wake from S4
[ 1.947038] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 2.030076] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 2.030100] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 2.030164] device-mapper: uevent: version 1.0.3
[ 2.030211] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07) initialised: dm-devel@redhat.com
[ 2.030291] device-mapper: multipath: version 1.2.0 loaded
[ 2.030294] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 2.030397] cpuidle: using governor ladder
[ 2.030399] cpuidle: using governor menu
[ 2.030547] TCP cubic registered
[ 2.030620] NET: Registered protocol family 10
[ 2.030950] NET: Registered protocol family 17
[ 2.030959] Registering the dns_resolver key type
[ 2.031011] powernow-k8: Found 1 AMD Phenom(tm) II X4 955 Processor (4 cpu cores) (version 2.20.00)
[ 2.031037] powernow-k8: 0 : pstate 0 (3200 MHz)
[ 2.031038] powernow-k8: 1 : pstate 1 (2500 MHz)
[ 2.031040] powernow-k8: 2 : pstate 2 (2100 MHz)
[ 2.031041] powernow-k8: 3 : pstate 3 (800 MHz)
[ 2.031643] PM: Hibernation image not present or could not be loaded.
[ 2.031649] registered taskstats version 1
[ 2.031895] Magic number: 15:503:224
[ 2.031973] rtc_cmos 00:03: setting system clock to 2011-06-17 10:13:26 UTC (1308305606)
[ 2.031975] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 2.031976] EDD information not available.
[ 2.033156] Freeing unused kernel memory: 956k freed
[ 2.033350] Write protecting the kernel read-only data: 10240k
[ 2.033932] Freeing unused kernel memory: 184k freed
[ 2.037440] Freeing unused kernel memory: 1444k freed
[ 2.040055] Refined TSC clocksource calibration: 3200.113 MHz.
[ 2.040059] Switching to clocksource tsc
[ 2.050936] <30>udev[116]: starting version 167
[ 2.066816] sky2: driver version 1.28
[ 2.068617] sky2 0000:06:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 2.068628] sky2 0000:06:00.0: setting latency timer to 64
[ 2.068655] sky2 0000:06:00.0: Yukon-2 EC Ultra chip revision 3
[ 2.068731] sky2 0000:06:00.0: irq 46 for MSI/MSI-X
[ 2.069651] sky2 0000:06:00.0: eth0: addr 00:22:15:86:0a:74
[ 2.081395] ahci 0000:00:11.0: version 3.0
[ 2.081416] ahci 0000:00:11.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 2.081538] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[ 2.081540] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 2.082349] scsi0 : ahci
[ 2.083331] scsi1 : ahci
[ 2.083723] scsi2 : ahci
[ 2.083921] scsi3 : ahci
[ 2.083971] scsi4 : ahci
[ 2.084029] scsi5 : ahci
[ 2.084061] ata1: SATA max UDMA/133 irq_stat 0x00400000, PHY RDY changed irq 22
[ 2.084064] ata2: SATA max UDMA/133 abar m1024@0xfe6ff800 port 0xfe6ff980 irq 22
[ 2.084067] ata3: SATA max UDMA/133 abar m1024@0xfe6ff800 port 0xfe6ffa00 irq 22
[ 2.084069] ata4: SATA max UDMA/133 abar m1024@0xfe6ff800 port 0xfe6ffa80 irq 22
[ 2.084072] ata5: SATA max UDMA/133 abar m1024@0xfe6ff800 port 0xfe6ffb00 irq 22
[ 2.084075] ata6: SATA max UDMA/133 abar m1024@0xfe6ff800 port 0xfe6ffb80 irq 22
[ 2.084145] ahci 0000:05:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 2.084190] ahci 0000:05:00.0: irq 47 for MSI/MSI-X
[ 2.084234] ahci 0000:05:00.0: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 2.084237] ahci 0000:05:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 2.084240] ahci 0000:05:00.0: setting latency timer to 64
[ 2.084245] ahci 0000:05:00.0: port 0 can do FBS, forcing FBSCP
[ 2.084298] ahci 0000:05:00.0: port 1 can do FBS, forcing FBSCP
[ 2.084762] scsi6 : pata_atiixp
[ 2.084999] scsi8 : pata_atiixp
[ 2.085433] ata7: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 2.085435] ata8: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 2.085453] scsi7 : ahci
[ 2.085515] scsi9 : ahci
[ 2.085554] ata9: SATA max UDMA/133 abar m2048@0xfeaff800 port 0xfeaff900 irq 47
[ 2.085557] ata10: SATA max UDMA/133 abar m2048@0xfeaff800 port 0xfeaff980 irq 47
[ 2.430057] ata10: SATA link down (SStatus 0 SControl 370)
[ 2.430065] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.430099] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.430126] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.430154] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.560029] usb 4-2: new full speed USB device using ohci_hcd and address 2
[ 2.630037] ata3: softreset failed (device not ready)
[ 2.630040] ata9: SATA link up 3.0 Gbps (SStatus 123 SControl 370)
[ 2.630044] ata3: applying SB600 PMP SRST workaround and retrying
[ 2.630271] ata9.00: ATA-7: INTEL SSDSA2M080G2GN, 2CV102M3, max UDMA/133
[ 2.630274] ata9.00: 156301488 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 2.630507] ata9.00: configured for UDMA/133
[ 2.747124] hub 4-2:1.0: USB hub found
[ 2.749090] hub 4-2:1.0: 4 ports detected
[ 2.830044] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.833792] ata3.00: ATAPI: HL-DT-ST BDDVDRW GGC-H20L, 1.03, max UDMA/133
[ 2.838755] ata3.00: configured for UDMA/133
[ 3.030025] ata1: softreset failed (device not ready)
[ 3.030028] ata1: applying SB600 PMP SRST workaround and retrying
[ 3.100023] usb 4-3: new low speed USB device using ohci_hcd and address 3
[ 3.230039] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.236148] ata1.00: ATA-8: SAMSUNG HD204UI, 1AQ10001, max UDMA/133
[ 3.236150] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 3.242295] ata1.00: configured for UDMA/133
[ 3.242417] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HD204UI 1AQ1 PQ: 0 ANSI: 5
[ 3.242534] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.242590] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 3.242656] sd 0:0:0:0: [sda] Write Protect is off
[ 3.242659] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.242682] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.245690] scsi 2:0:0:0: CD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03 PQ: 0 ANSI: 5
[ 3.252220] sda: sda1
[ 3.252425] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.356475] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.356478] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.356562] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 3.356615] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 3.356788] scsi 7:0:0:0: Direct-Access ATA INTEL SSDSA2M080 2CV1 PQ: 0 ANSI: 5
[ 3.356878] sd 7:0:0:0: [sdb] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 3.356914] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 3.356922] sd 7:0:0:0: [sdb] Write Protect is off
[ 3.356924] sd 7:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3.356941] sd 7:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.357543] sdb: sdb1 sdb2 sdb3 < sdb5 >
[ 3.357801] sd 7:0:0:0: [sdb] Attached SCSI disk
[ 3.371289] input: Logitech USB RECEIVER as /devices/pci0000:00/0000:00:12.1/usb4/4-3/4-3:1.0/input/input3
[ 3.371382] generic-usb 0003:046D:C50E.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB RECEIVER] on usb-0000:00:12.1-3/input0
[ 3.371395] usbcore: registered new interface driver usbhid
[ 3.371414] usbhid: USB HID core driver
[ 3.381680] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[ 3.660027] usb 3-3: new low speed USB device using ohci_hcd and address 2
[ 3.911180] input: 4-Axis,12-Button with POV as /devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/input/input4
[ 3.911232] generic-usb 0003:0583:A00B.0002: input,hidraw1: USB HID v1.10 Joystick [4-Axis,12-Button with POV] on usb-0000:00:12.0-3/input0
[ 3.990121] usb 4-2.2: new low speed USB device using ohci_hcd and address 4
[ 4.123289] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:12.1/usb4/4-2/4-2.2/4-2.2:1.0/input/input5
[ 4.123351] generic-usb 0003:046D:C508.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:12.1-2.2/input0
[ 4.575969] EXT4-fs (sdb5): re-mounted. Opts: errors=remount-ro
[ 4.586942] <30>udev[376]: starting version 167
[ 4.597125] lp: driver loaded but no devices found
[ 4.619509] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[ 4.619512] Disabling lock debugging due to kernel taint
[ 4.623702] type=1400 audit(1308298409.085:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=462 comm="apparmor_parser"
[ 4.623950] type=1400 audit(1308298409.085:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=462 comm="apparmor_parser"
[ 4.624112] type=1400 audit(1308298409.085:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=462 comm="apparmor_parser"
[ 4.677379] xhci_hcd 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 4.677424] xhci_hcd 0000:04:00.0: setting latency timer to 64
[ 4.677427] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 4.677515] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 8
[ 4.701581] sky2 0000:06:00.0: eth0: enabling interface
[ 4.702595] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.715039] ACPI: resource piix4_smbus [io 0x0b00-0x0b07] conflicts with ACPI region SOR1 [io 0xb00-0xb0f]
[ 4.715042] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 4.717218] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01
[ 4.717335] SP5100 TCO timer: mmio address 0xfec000f0 already in use
[ 4.739543] [fglrx] Maximum main memory to use for locked dma buffers: 7768 MBytes.
[ 4.739622] [fglrx] vendor: 1002 device: 68b8 count: 1
[ 4.739975] [fglrx] ioport: bar 4, base 0xa000, size: 0x100
[ 4.739986] pci 0000:01:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 4.739991] pci 0000:01:00.0: setting latency timer to 64
[ 4.740376] [fglrx] Kernel PAT support is enabled
[ 4.740392] [fglrx] module loaded - fglrx 8.84.60 [Mar 24 2011] with 1 minors
[ 4.794170] MCE: In-kernel MCE decoding enabled.
[ 4.799337] EDAC MC: Ver: 2.1.0 Apr 11 2011
[ 4.801294] EDAC amd64_edac: v3.3.0
[ 4.824612] HDA Intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 4.824707] CA0106 0000:07:05.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 4.824730] snd-ca0106: Model 1012 Rev 00000000 Serial 10121102
[ 4.834927] xhci_hcd 0000:04:00.0: irq 16, io mem 0xfe9fe000
[ 4.834978] xhci_hcd 0000:04:00.0: irq 48 for MSI/MSI-X
[ 4.834982] xhci_hcd 0000:04:00.0: irq 49 for MSI/MSI-X
[ 4.834986] xhci_hcd 0000:04:00.0: irq 50 for MSI/MSI-X
[ 4.834989] xhci_hcd 0000:04:00.0: irq 51 for MSI/MSI-X
[ 4.834993] xhci_hcd 0000:04:00.0: irq 52 for MSI/MSI-X
[ 4.835079] usb usb8: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
[ 4.835155] xHCI xhci_add_endpoint called for root hub
[ 4.835157] xHCI xhci_check_bandwidth called for root hub
[ 4.835183] hub 8-0:1.0: USB hub found
[ 4.835186] hub 8-0:1.0: 4 ports detected
[ 4.847162] type=1400 audit(1308298409.305:5): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=792 comm="apparmor_parser"
[ 4.847417] type=1400 audit(1308298409.305:6): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=792 comm="apparmor_parser"
[ 4.847464] type=1400 audit(1308298409.305:7): apparmor="STATUS" operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" pid=791 comm="apparmor_parser"
[ 4.847585] type=1400 audit(1308298409.305:8): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=792 comm="apparmor_parser"
[ 4.847909] type=1400 audit(1308298409.305:9): apparmor="STATUS" operation="profile_load" name="/usr/bin/freshclam" pid=797 comm="apparmor_parser"
[ 4.849792] type=1400 audit(1308298409.305:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=798 comm="apparmor_parser"
[ 4.903894] HDA Intel 0000:01:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 4.903959] HDA Intel 0000:01:00.1: irq 53 for MSI/MSI-X
[ 4.903979] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 4.905191] k10temp 0000:00:18.3: unreliable CPU thermal sensor; monitoring disabled
[ 4.906010] EDAC amd64: DRAM ECC disabled.
[ 4.906017] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 4.906018] Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[ 4.906019] (Note that use of the override may cause unknown side effects.)
[ 5.115673] EXT4-fs (sdb5): re-mounted. Opts: errors=remount-ro,commit=0
[ 5.143703] vesafb: framebuffer at 0xd0000000, mapped to 0xffffc90013400000, using 5824k, total 5824k
[ 5.143706] vesafb: mode is 1400x1050x32, linelength=5632, pages=0
[ 5.143708] vesafb: scrolling: redraw
[ 5.143710] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 5.143863] Console: switching to colour frame buffer device 175x65
[ 5.143885] fb0: VESA VGA frame buffer device
[ 5.146940] ppdev: user-space parallel port driver
[ 5.151513] usb 8-1: new SuperSpeed USB device using xhci_hcd and address 2
[ 5.174965] xhci_hcd 0000:04:00.0: WARN: short transfer on control ep
[ 5.176213] xhci_hcd 0000:04:00.0: WARN: short transfer on control ep
[ 5.177588] xhci_hcd 0000:04:00.0: WARN: short transfer on control ep
[ 5.178956] xhci_hcd 0000:04:00.0: WARN: short transfer on control ep
[ 5.194359] usbcore: registered new interface driver uas
[ 5.197555] Initializing USB Mass Storage driver...
[ 5.197748] scsi10 : usb-storage 8-1:1.0
[ 5.197855] usbcore: registered new interface driver usb-storage
[ 5.197857] USB Mass Storage support registered.
[ 5.364285] fglrx_pci 0000:01:00.0: irq 54 for MSI/MSI-X
[ 5.364743] [fglrx] Firegl kernel thread PID: 1333
[ 5.364798] [fglrx] Firegl kernel thread PID: 1334
[ 5.364834] [fglrx] Firegl kernel thread PID: 1335
[ 5.365070] [fglrx] IRQ 54 Enabled
[ 5.621837] [fglrx] Gart USWC size:1280 M.
[ 5.621839] [fglrx] Gart cacheable size:508 M.
[ 5.621844] [fglrx] Reserved FB block: Shared offset:0, size:1000000
[ 5.621845] [fglrx] Reserved FB block: Unshared offset:f8fd000, size:403000
[ 5.621847] [fglrx] Reserved FB block: Unshared offset:3fff4000, size:c000
[ 5.756653] HDMI hot plug event: Pin=3 Presence_Detect=1 ELD_Valid=0
[ 5.757023] HDMI hot plug event: Pin=3 Presence_Detect=0 ELD_Valid=1
[ 6.192134] scsi 10:0:0:0: Direct-Access USB 3.0 MassStorage 0010 PQ: 0 ANSI: 4
[ 6.192522] sd 10:0:0:0: Attached scsi generic sg3 type 0
[ 6.194892] sd 10:0:0:0: [sdc] 625138352 512-byte logical blocks: (320 GB/298 GiB)
[ 6.196254] sd 10:0:0:0: [sdc] Write Protect is off
[ 6.196256] sd 10:0:0:0: [sdc] Mode Sense: 0f 00 00 00
[ 6.199423] sd 10:0:0:0: [sdc] No Caching mode page present
[ 6.199426] sd 10:0:0:0: [sdc] Assuming drive cache: write through
[ 6.206723] sd 10:0:0:0: [sdc] No Caching mode page present
[ 6.206725] sd 10:0:0:0: [sdc] Assuming drive cache: write through
[ 6.421720] sky2 0000:06:00.0: eth0: Link is up at 100 Mbps, full duplex, flow control both
[ 6.422401] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6.541007] sdc: sdc1
[ 6.573848] sd 10:0:0:0: [sdc] No Caching mode page present
[ 6.573852] sd 10:0:0:0: [sdc] Assuming drive cache: write through
[ 6.573856] sd 10:0:0:0: [sdc] Attached SCSI disk
[ 7.533760] hda-intel: IRQ timing workaround is activated for card #2. Suggest a bigger bdl_pos_adj.
[ 14.181094] usb 8-1: reset SuperSpeed USB device using xhci_hcd and address 2
[ 14.204301] xhci_hcd 0000:04:00.0: WARN: short transfer on control ep
[ 14.204426] xhci_hcd 0000:04:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff88021d601c80
[ 14.204428] xhci_hcd 0000:04:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff88021d601cc0
[ 14.218580] xhci_hcd 0000:04:00.0: WARN: Stalled endpoint
[ 14.269652] EXT4-fs (sdb5): re-mounted. Opts: errors=remount-ro,commit=0
[ 16.460026] eth0: no IPv6 routers present
joshua@joshua-System-Product-Name:~$
