Karten-USB-LW's vom Explorer entfernen
- Ersteller Orbas
BFF
¯\_(ツ)_/¯
- Okt. 2017
Du hast einen Kartenleser eingebaut und willst dessen Buchstaben nicht sehen solange keine Karte eingesteckt ist.
Dazu brauchst Du Dir nur USBDLM von Uwe Sieber installieren und konfigurieren. Dann klappt das.
https://www.uwe-sieber.de/usbdlm.html
Eine passende usbdlm.ini ist das hier. Zeile 9 nix drin nix anzeigen, Zeile 49 alles was angeploppt wird bekommt ab M, das naechste N usw.
BFF
Code:
; This is a sample for an USBDLM.INI
; Create a new USBDLM.INI or rename it to USBDLM.INI
; More informations in the help file USBDLM_ENG.CHM
;------------------------------ Settings -------------------------------------
[Settings]
; here you can let USBDLM remove driveletters of cardreaders as long
; as there is no media present
NoMediaNoLetter=0
; enforce executables being quoted if the commandline contains spaces, e.g.
; wrong: open=C:\Program Files\test.exe
; right: open="C:\Program Files\test.exe"
; wrong: open=C:\Tools\test.exe /X
; right: open="C:\Tools\test.exe" /X
SafeCommandLines=1
; here you can let USBDLM write a logfile, default is _USBDLM.LOG in
; the root of the Windows drive
WriteLogFile=0
LogFile=
LogLevel=3
; USBDLM can watch for new USB keyboards and ask the user on arrival if this is a real one.
; Manipulated "bad" USB devices can emulate a keyboard to simulate keystrokes
; for downloading and executing malware.
BadUsbWatchKbd=0
;---------------------------- BalloonTips -------------------------------------
[BalloonTips]
; this activates balloon tips and sets their show duration in milliseconds
Enabled=0
ShowSize=1
Timeout=6000
; this activates balloon tips for TrueCrypt/VeraCrypt volumes
ShowTrueCrypt=0
; this activates balloon tips for or any virtual volume as Subst and Network drives
ShowVirtual=0
[NetworkLetters]
Letter1=H
[StaticLetters]
Letters=C,F,Z
[DriveLetters]
Letters=M,N,O,P
; many other options are documented in the Help files
BFF
BlubbsDE
Fleet Admiral
- Juni 2011
Genau da ist die Einstellung eigentlich für da. Kartenleser Laufwerke ausblenden, wenn keine Karte drinnen steckt. Das macht Windows 10 per Default so. Vermutlich liegts am verbauten Kartenleser. Windows erkennt ihn vielleicht als solchen nicht.
Ich habe mir die Anleitung für USBDLM angesehen. Für mein Kenntnisstand klingt sie ein wenig kompliziert, so dass ich sie mir in Ruhe wieder vornehmen und dann umsetzen werde.
Auf die schnelle habe ich inzwischen in Computerverwaltung\Datenträgerverwaltung jeden der 4 USB-Kartenleser deaktiviert. Sie bleiben auch nach Neustart weg, womit wenn sonst keine negative Folgen dadurch noch entstehen, mein Problem soweit gelößt wäre.
Vielen Dank an Alle für die Hilfestellung!
BFF
¯\_(ツ)_/¯
- Okt. 2017
Von hinten durch die Brust ins Auge.
Vergiss aber nicht das Du die deaktiviert hast, wenn Du am naechsten Mittwoch eine SD-Karte rein steckst.
BFF
Genau das haben wir damals festgestellt (ganz besonders bei den 3,5"-Teilen von Fujitsu).
Jeder Slot schlug wie ein (echtes) Laufwerk auf und nicht als Wechsel-Laufwerk.
BFF
BFF
BlubbsDE schrieb:Vermutlich liegts am verbauten Kartenleser. Windows erkennt ihn vielleicht als solchen nicht.
BFF
