will ein iso image mit imageburn brennen. habe die version 2.5.7.0 und eben den bh10ls30 brenner.
ich nehme verbatim 50gb rohlinge aus japan. vermutlich lth...
mit 25gb rohlingen von verbatim (lth) und mediarange (4x speed, vermutlich philips rohlinge) hatte ich nie probleme.
habe auch eben ein firmware update gemacht und jetzt schon 2 rohlinge zerschossen...
bevor jetzt noch mehr rohlinge (vor allem bei den preisen) dran glauben... vielleicht kann mir ja einer helfen:
I 20:34:38 Writing LeadIn...
W 20:36:38 Failed to Write Sectors 0 - 31 - Reason: No Seek Complete
W 20:36:38 Retrying (1 of 20)...
I 20:36:38 Writing LeadIn...
W 20:38:01 Failed to Write Sectors 928 - 959 - Reason: Power Calibration Area Error
W 20:38:01 Retrying (1 of 20)...
W 20:38:01 Retry Failed - Reason: Invalid Address For Write
W 20:38:01 Retrying (2 of 20)...
W 20:38:01 Retrying (3 of 20)...
W 20:38:01 Retrying (4 of 20)...
W 20:38:01 Retrying (5 of 20)...
W 20:38:01 Retrying (6 of 20)...
W 20:38:01 Retrying (7 of 20)...
W 20:38:01 Retrying (8 of 20)...
W 20:38:01 Retrying (9 of 20)...
W 20:38:01 Retrying (10 of 20)...
W 20:38:01 Retrying (11 of 20)...
W 20:38:01 Retrying (12 of 20)...
W 20:38:01 Retrying (13 of 20)...
W 20:38:01 Retrying (14 of 20)...
W 20:38:01 Retrying (15 of 20)...
W 20:38:01 Retrying (16 of 20)...
W 20:38:02 Retry Failed - Reason: Invalid Address For Write
W 20:38:02 Retrying (17 of 20)...
W 20:38:02 Retrying (18 of 20)...
W 20:38:02 Retrying (19 of 20)...
W 20:38:02 Retrying (20 of 20)...
W 20:38:13 Retrying (21)...
W 20:38:13 Retry Failed - Reason: Invalid Address For Write
W 20:38:14 Retrying (22)...
W 20:38:14 Retry Failed - Reason: Invalid Address For Write
E 20:38:15 Failed to Write Sectors 928 - 959 - Reason: Power Calibration Area Error
E 20:38:15 Next Writable Address: 0
I 20:38:15 Synchronising Cache...
W 20:38:19 User opted to skip the 'Close Track/Session/Disc' functions.
E 20:38:19 Failed to Write Image!
E 20:38:19 Operation Failed! - Duration: 00:03:43
habe es auch noch mit der mitgelieferten blu ray disc suite probiert:
14.5.2012
Task Type : Disc-Image brennen
20:52:33, File(cl_DiscCopy.cpp), Line(8431)
-> Begin burning process
Current drive: <D: HL-DT-ST BD-RE BH10LS30 1.01>
====== Disc Info =======
Disc Type: BD-R Sequential Recording
Disc Status: Blank, Appendable
Num. of Sessions: 1 Num. of Tracks: 1
Disc Capacity: 24438784LBs
Free Size: 24438784LBs Used Size: 0LBs
Current writing speed(x): 2.0
-> Burn from image
20:52:33, file(cl_DiscCopy.cpp), line(8641)
-> Quick/Background Format
20:52:34, file(cl_DiscCopy.cpp), line(8854)
-> Prepare writing disc
Burn option: w/ buffer underrun protection
Burn option: w/o simulation
Burn option: w/o close disc
Burn option: w/o verify disc
20:53:12, File(cl_DiscCopy.cpp), Line(1248)
-> Burning Fail, ErrCode: 0xeb020b9c
-> End burning process
Error Code : 0xeb020b9c
14.5.2012
-> Burn from image
